I am having the same problem as Jeeves. After entering my user/password on the http://api.yosmart.com/oauth/v2/authorization.htm “YoSmart Auth” web page, I get: “Account info not match,Login failed.”
I used the same user (my email) and password to link the google home app, so I know I have the right credentials. Any suggestions on how to debug?
Thanks @Eric-YoLink for getting the integration out to the world. I have integrated my two motion sensors, I have one question. Periodically my Yolink Hub will go down as in loose internet connection. Is there a way to create an automation in Home Assistant to alert me if that hub goes down. I do not think so as I do not think HA sees the hub (Devices → Yolink → only 2 devices the two motion sensors )
But I was wondering if there was a way. I can simply switch a setting in Yolink to send me an email but I wanted to keep everything inside of HA.
I’ve been struggling to get a relay working out in my back yard - the YoLink was the ONLY one that would work, but I can’t seem to get it to talk to Home assistant. Should it be working?? It’s connected to a solenoid valve that supplies water to my hot tub. It works fine through the YoLink app. I really need it to work with HA! :-). It’s a YS5706-UC. I’ve restarted everything and it’s the first time a new YoLink device hasn’t immediate shown up! Help!
Is anyone else having problems linking their Yolink account to Home Assistant via the Home Assistant integration? Getting the error below. Account was setup today and devices added via YoLink.
Yep, had that same problem. After a few days of pondering, I got it to work by logging into ha via https, rather than http. At least I think that is what I did After getting to work, I it works independent of weather you use http or https.
Thanks that helped! Used the app on my phone and it worked.
Picked up the outdoor sensors. They have data for motion and battery, notice it doesn’t pull temperature. Hopefully, that gets added at some point. Or maybe the goal is for us to buy another sensor?
I just had to try and retry 3 times or so to get it to work but once you are up and running it’s great! There were a couple of hiccups when it was brand new… but it’s been extremely reliable now…
I just got my first YoLink system and am trying to setup the Leak Sensors. I created and linked everything together, but HA is not being notified/triggered when the leak sensor is triggered. The yolink app works correctly and updates, but HA does not. Any insight on what might be going on would be helpful. Thanks!
I’m seeing a pretty good delay with the motion sensors most of the time. At times the motion sensor registers motion with HA in a few seconds, other times it takes a few minutes. Just seems to be very random.
No. I’m not having this issue. Is it any faster in the app? If it is, the issue is probably on the HA side. Is this the same issue with all of your YoLink sensors or just motion sensors? If it is only specific-type sensors, are the sensors of the same type all experiencing the same lag?
Are you in our Discord developer/API group? That might help, if not. And/or you can email [email protected] with the problem. They will ask for the IDs for the sensors in question.
