I got a notification that ZUI has an update available to go from 13.11 to 13.12 but it won’t install.
Oddly ZUI shows I’m on the following:
zwave-js-ui: 9.18.1
zwave-js: 13.2.0
Is anyone else having this issue?
zwave-js-ui: 9.18.1
zwave-js: 13.2.0
You need to provide your installation method. Add-on? Container?
Sorry:
Running on NUC i3 Win10 with Oracle Virtual Box VM.
Ok, so the add-on. What does “won’t install” mean? Do you get an error? Does it just silently do nothing? Does the add-on even say there’s an update available? (Latest add-on version is v3.12.0).
I’m on Z-Wave JS UI v13.11 and when I try to upgrade to v13.12 it presents a spinner but never completes the installation of the upgrade unless this is supposed to take more than 30 minutes and I’m being impatient. There is no status bar or percentage shown, just a spinner.
v13.11 and v13.12 are the driver versions, not Z-Wave JS UI.
If you are using the add-on, the latest is v3.12.0. You would be upgrading the add-on, is that what you’re doing? You never upgrade Z-Wave JS (driver) yourself.
Perhaps a screenshot might help.
So yes, you are upgrading the add-on. It should only take a few minutes to upgrade. You might have to check supervisor logs to see if there is an issue.
It completely locked up creating the need to restart the Virtual Box and HA Virtual Machine but still didn’t update.
I don’t think there’s much to see in this log:
e[32m2024-09-24 13:20:06.600 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: qemux86-64e[0m
e[32m2024-09-24 13:20:06.615 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.09.1e[0m
e[32m2024-09-24 13:20:06.679 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initializee[0m
e[32m2024-09-24 13:20:06.685 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-09-24 13:20:06.686 INFO (MainThread) [__main__] Setting up Supervisore[0m
e[32m2024-09-24 13:20:07.009 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2e[0m
e[32m2024-09-24 13:20:07.202 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitore[0m
e[32m2024-09-24 13:20:07.210 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.e[0m
e[32m2024-09-24 13:20:07.217 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.ose[0m
e[32m2024-09-24 13:20:07.218 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1e[0m
e[32m2024-09-24 13:20:07.225 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1e[0m
e[32m2024-09-24 13:20:07.226 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManagere[0m
e[32m2024-09-24 13:20:07.227 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauce[0m
e[32m2024-09-24 13:20:07.227 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1e[0m
e[32m2024-09-24 13:20:07.228 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1e[0m
e[32m2024-09-24 13:20:07.228 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1e[0m
e[32m2024-09-24 13:20:08.124 INFO (MainThread) [supervisor.host.services] Updating service informatione[0m
e[32m2024-09-24 13:20:08.140 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio informatione[0m
e[33m2024-09-24 13:20:08.161 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio servere[0m
e[32m2024-09-24 13:20:08.445 INFO (MainThread) [supervisor.host.network] Updating local network informatione[0m
e[32m2024-09-24 13:20:08.673 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}e[0m
e[32m2024-09-24 13:20:08.704 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitore[0m
e[32m2024-09-24 13:20:08.705 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.jsone[0m
e[32m2024-09-24 13:20:08.827 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.07.0e[0m
e[32m2024-09-24 13:20:08.856 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugine[0m
e[32m2024-09-24 13:20:08.868 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli applicatione[0m
e[32m2024-09-24 13:20:10.225 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2024.07.0 - 172.30.32.5e[0m
e[32m2024-09-24 13:20:10.273 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0e[0m
e[32m2024-09-24 13:20:10.342 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugine[0m
e[32m2024-09-24 13:20:10.382 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns applicatione[0m
e[32m2024-09-24 13:20:12.240 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0 - 172.30.32.3e[0m
e[32m2024-09-24 13:20:12.241 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.confe[0m
e[32m2024-09-24 13:20:12.271 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0e[0m
e[32m2024-09-24 13:20:12.304 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugine[0m
e[32m2024-09-24 13:20:12.348 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio applicatione[0m
e[32m2024-09-24 13:20:14.553 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4e[0m
e[32m2024-09-24 13:20:14.591 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0e[0m
e[32m2024-09-24 13:20:14.657 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0e[0m
e[32m2024-09-24 13:20:14.751 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugine[0m
e[32m2024-09-24 13:20:14.771 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_multicast applicatione[0m
e[32m2024-09-24 13:20:16.218 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0 - Hoste[0m
e[32m2024-09-24 13:20:16.274 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secretse[0m
e[32m2024-09-24 13:20:16.354 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version 2024.9.3e[0m
e[32m2024-09-24 13:20:16.836 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 13.1 / BootSlot Be[0m
e[32m2024-09-24 13:20:19.372 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/cb646a50 repositorye[0m
e[32m2024-09-24 13:20:19.374 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repositorye[0m
e[32m2024-09-24 13:20:19.377 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d5369777 repositorye[0m
e[32m2024-09-24 13:20:19.389 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repositorye[0m
e[32m2024-09-24 13:20:19.393 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/0521a35e repositorye[0m
e[32m2024-09-24 13:20:19.405 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repositorye[0m
e[32m2024-09-24 13:20:22.289 INFO (MainThread) [supervisor.store] Loading add-ons from store: 82 all - 82 new - 0 removee[0m
e[32m2024-09-24 13:20:22.557 INFO (MainThread) [supervisor.addons.manager] Found 8 installed add-onse[0m
e[32m2024-09-24 13:20:22.685 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-mosquitto with version 6.4.1e[0m
e[32m2024-09-24 13:20:22.697 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-configurator with version 5.8.0e[0m
e[32m2024-09-24 13:20:22.700 INFO (MainThread) [supervisor.docker.interface] Attaching to mrw298/toggledbits-reactor-amd64 with version 0.0.8e[0m
e[32m2024-09-24 13:20:22.736 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-samba with version 12.3.2e[0m
e[32m2024-09-24 13:20:22.758 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-duckdns with version 1.18.0e[0m
e[32m2024-09-24 13:20:22.762 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/hacs/amd64-addon-get with version 1.3.1e[0m
e[32m2024-09-24 13:20:22.770 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-ssh with version 9.14.0e[0m
e[32m2024-09-24 13:20:22.780 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/zwave-js-ui/amd64 with version 3.11.0e[0m
e[32m2024-09-24 13:20:23.546 INFO (MainThread) [supervisor.backups.manager] Found 24 backup filese[0m
e[31m2024-09-24 13:20:23.726 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/989602e9.tar: "filename './backup.json' not found"e[0m
e[31m2024-09-24 13:20:23.774 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/49cef8c4.tar: unexpected end of datae[0m
e[31m2024-09-24 13:20:23.866 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/69c7b24f.tar: "filename './backup.json' not found"e[0m
e[32m2024-09-24 13:20:24.004 INFO (MainThread) [supervisor.discovery] Loaded 1 messagese[0m
e[32m2024-09-24 13:20:24.004 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessionse[0m
e[32m2024-09-24 13:20:24.005 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setupe[0m
e[32m2024-09-24 13:20:24.005 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addone[0m
e[32m2024-09-24 13:20:24.005 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addone[0m
e[32m2024-09-24 13:20:24.006 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2024-09-24 13:20:24.006 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2024-09-24 13:20:24.007 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2024-09-24 13:20:24.007 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setupe[0m
e[32m2024-09-24 13:20:24.008 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-09-24 13:20:24.012 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setupe[0m
e[32m2024-09-24 13:20:24.037 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setupe[0m
e[32m2024-09-24 13:20:24.051 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-09-24 13:20:24.071 INFO (MainThread) [__main__] Running Supervisore[0m
e[32m2024-09-24 13:20:24.156 INFO (MainThread) [supervisor.os.manager] Rauc: slot B - activated slot kernel.1, marked slot kernel.1 as goode[0m
e[32m2024-09-24 13:20:24.263 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-onse[0m
e[32m2024-09-24 13:20:24.271 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 1 add-onse[0m
e[32m2024-09-24 13:20:24.387 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_a0d7b954_zwavejs2mqtt applicatione[0m
e[32m2024-09-24 13:20:26.132 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/zwave-js-ui/amd64 with version 3.11.0e[0m
e[32m2024-09-24 13:20:56.391 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 1 add-onse[0m
e[32m2024-09-24 13:20:56.455 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_core_ssh applicatione[0m
e[32m2024-09-24 13:20:58.480 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-ssh with version 9.14.0e[0m
e[32m2024-09-24 13:21:03.498 INFO (MainThread) [supervisor.core] Start Home Assistant Coree[0m
e[32m2024-09-24 13:21:03.563 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistante[0m
e[32m2024-09-24 13:21:04.168 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is readye[0m
e[32m2024-09-24 13:21:29.216 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startupe[0m
e[32m2024-09-24 13:21:29.217 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-09-24 13:21:29.810 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2024-09-24 13:21:29.857 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)e[0m
e[32m2024-09-24 13:22:30.985 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='STARTING', offline_db_migration=False)e[0m
e[32m2024-09-24 13:22:37.234 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)e[0m
e[32m2024-09-24 13:22:37.237 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instancee[0m
e[32m2024-09-24 13:22:37.238 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 2 add-onse[0m
e[32m2024-09-24 13:22:37.699 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_core_configurator applicatione[0m
e[32m2024-09-24 13:22:43.193 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-configurator with version 5.8.0e[0m
e[32m2024-09-24 13:22:43.508 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_0521a35e_reactor applicatione[0m
e[32m2024-09-24 13:22:49.174 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on mrw298/toggledbits-reactor-amd64 with version 0.0.8e[0m
Any other suggestions? I’m reluctant to try again because it keeps doing this.
Every time I try to install the update, HA locks up. When I get it going again, the Supervisor Log wipes data from the previous session so I’m not capturing logs when this is occuring.
Are any other add-ons failing to update? Do you have sufficient free space on your docker partition? Have you tried installing any other, larger, add-ons (like esphome, which is almost 600MB)? Have you tried running the ha supervisor logs
command during the attempted upgrade and maybe see what is going on before it hangs and reboots? Have you tried unchecking “Create backup before updating” to make sure that’s not the part that’s failing? (note some backup errors in the logs).
All other add-ons are updating.
I think there’s sufficient space on the docker partition:
I’m not using esphome but maybe reactor is the issue as far as size of add-ons?
How to run the ha supervisor logs
during the upgrade?
I tried unchecking “Create backup before updating” and it still crashes requiring a full reboot.
You could try switching the USB Controller to USB 3.0 (xHCI).
BINGO!
Now I’m wondering if this is why HA in the VM has been randomly locking up on me. I’ll continue to monitor the situation but I believe we have a solution here…
Hmm… Maybe I posted too soon? Even though the updated was successful, the add-on is not loading:
Supervisor
2024-10-08 15:33:16.399 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-10-08 15:33:16.400 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-10-08 15:33:16.415 INFO (MainThread) [__main__] Running Supervisor
2024-10-08 15:33:16.449 INFO (MainThread) [supervisor.os.manager] Rauc: slot B - activated slot kernel.1, marked slot kernel.1 as good
2024-10-08 15:33:16.510 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2024-10-08 15:33:16.516 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 1 add-ons
2024-10-08 15:33:16.600 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_a0d7b954_zwavejs2mqtt application
2024-10-08 15:33:18.080 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/zwave-js-ui/amd64 with version 3.13.2
2024-10-08 15:34:48.520 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 1 add-ons
2024-10-08 15:34:48.532 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Z-Wave JS UI is unhealthy, restarting...
2024-10-08 15:34:48.550 INFO (SyncWorker_3) [supervisor.docker.manager] Stopping addon_a0d7b954_zwavejs2mqtt application
2024-10-08 15:34:48.624 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_core_ssh application
2024-10-08 15:34:49.905 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-ssh with version 9.15.0
2024-10-08 15:34:54.924 INFO (MainThread) [supervisor.core] Start Home Assistant Core
2024-10-08 15:34:55.063 INFO (SyncWorker_5) [supervisor.docker.manager] Starting homeassistant
2024-10-08 15:34:55.949 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-10-08 15:35:12.716 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startup
2024-10-08 15:35:12.717 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-10-08 15:35:16.175 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-10-08 15:35:16.233 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2024-10-08 15:35:20.054 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_a0d7b954_zwavejs2mqtt application
2024-10-08 15:35:21.980 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/zwave-js-ui/amd64 with version 3.13.2
2024-10-08 15:35:54.300 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2024-10-08 15:35:54.301 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2024-10-08 15:35:54.302 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 2 add-ons
2024-10-08 15:35:54.387 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_0521a35e_reactor application
2024-10-08 15:35:56.117 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on mrw298/toggledbits-reactor-amd64 with version 0.0.8
2024-10-08 15:35:56.233 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_cebe7a76_hassio_google_drive_backup application
2024-10-08 15:35:59.590 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/sabeechen/hassio-google-drive-backup-amd64 with version 0.112.1
2024-10-08 15:36:05.402 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:05.454 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:05.490 INFO (MainThread) [supervisor.api.middleware.security] /mounts access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.245 INFO (MainThread) [supervisor.api.middleware.security] /addons access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.291 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.320 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.335 INFO (MainThread) [supervisor.api.middleware.security] /backups/77843f8b/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.344 INFO (MainThread) [supervisor.api.middleware.security] /backups/d9b8eecf/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.356 INFO (MainThread) [supervisor.api.middleware.security] /backups/335963dc/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.385 INFO (MainThread) [supervisor.api.middleware.security] /backups/dc112a67/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.395 INFO (MainThread) [supervisor.api.middleware.security] /backups/5eba2a0b/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.408 INFO (MainThread) [supervisor.api.middleware.security] /backups/02bb9dca/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.433 INFO (MainThread) [supervisor.api.middleware.security] /backups/7839a583/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.451 INFO (MainThread) [supervisor.api.middleware.security] /backups/e49e1b41/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.463 INFO (MainThread) [supervisor.api.middleware.security] /backups/47890719/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.477 INFO (MainThread) [supervisor.api.middleware.security] /backups/09011b37/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.530 INFO (MainThread) [supervisor.api.middleware.security] /backups/a2f69be7/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.548 INFO (MainThread) [supervisor.api.middleware.security] /backups/e02ba9ba/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.589 INFO (MainThread) [supervisor.api.middleware.security] /backups/8201755d/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.606 INFO (MainThread) [supervisor.api.middleware.security] /backups/54726eb7/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.626 INFO (MainThread) [supervisor.api.middleware.security] /backups/ad960973/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.651 INFO (MainThread) [supervisor.api.middleware.security] /backups/50251688/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.675 INFO (MainThread) [supervisor.api.middleware.security] /backups/340b8fd0/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.702 INFO (MainThread) [supervisor.api.middleware.security] /backups/3f644184/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.728 INFO (MainThread) [supervisor.api.middleware.security] /backups/07e4157f/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.736 INFO (MainThread) [supervisor.api.middleware.security] /backups/f64c0d84/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.757 INFO (MainThread) [supervisor.api.middleware.security] /backups/58a67092/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.769 INFO (MainThread) [supervisor.api.middleware.security] /backups/3b472017/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.782 INFO (MainThread) [supervisor.api.middleware.security] /backups/8b3a7c1f/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.797 INFO (MainThread) [supervisor.api.middleware.security] /backups/e95aacd9/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.816 INFO (MainThread) [supervisor.api.middleware.security] /backups/19a61f37/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:06.824 INFO (MainThread) [supervisor.api.middleware.security] /backups/3aa73978/info access from cebe7a76_hassio_google_drive_backup
2024-10-08 15:36:52.816 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Z-Wave JS UI is unhealthy, restarting...
2024-10-08 15:36:52.850 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping addon_a0d7b954_zwavejs2mqtt application
2024-10-08 15:37:06.267 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:8099 ssl:default [Connect call failed ('172.30.33.0', 8099)]
2024-10-08 15:37:12.550 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:8099 ssl:default [Connect call failed ('172.30.33.0', 8099)]
2024-10-08 15:37:15.298 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:8099 ssl:default [Connect call failed ('172.30.33.0', 8099)]
2024-10-08 15:37:17.656 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:8099 ssl:default [Connect call failed ('172.30.33.0', 8099)]
2024-10-08 15:37:23.855 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_a0d7b954_zwavejs2mqtt application
2024-10-08 15:37:25.241 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/zwave-js-ui/amd64 with version 3.13.2
2024-10-08 15:37:56.128 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Reactor to start, took more than 120 seconds
2024-10-08 15:37:56.160 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-10-08 15:37:56.163 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-10-08 15:37:56.164 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-10-08 15:37:56.166 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2024-10-08 15:37:56.170 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-10-08 15:37:56.170 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-10-08 15:37:56.376 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-10-08 15:37:56.388 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-10-08 15:37:56.466 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-10-08 15:37:56.481 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-10-08 15:37:56.488 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-10-08 15:37:56.496 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-10-08 15:37:56.503 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-10-08 15:37:56.591 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-10-08 15:37:56.594 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-10-08 15:37:56.595 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-10-08 15:37:56.595 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-10-08 15:37:56.595 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-10-08 15:37:59.408 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-10-08 15:37:59.412 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-10-08 15:37:59.413 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-10-08 15:38:02.983 INFO (MainThread) [supervisor.host.services] Updating service information
2024-10-08 15:38:03.011 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-10-08 15:38:03.388 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-10-08 15:38:03.433 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-10-08 15:38:56.043 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Z-Wave JS UI is unhealthy, restarting...
2024-10-08 15:38:56.076 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping addon_a0d7b954_zwavejs2mqtt application
2024-10-08 15:38:57.329 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:8099 ssl:default [Connect call failed ('172.30.33.0', 8099)]
2024-10-08 15:39:26.668 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_a0d7b954_zwavejs2mqtt application
2024-10-08 15:39:28.313 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/zwave-js-ui/amd64 with version 3.13.2
2024-10-08 15:39:36.176 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:8099 ssl:default [Connect call failed ('172.30.33.0', 8099)]
Seems you are in the same situation as System freezes when attempting to update Z-Wave JS server - #6 by Tomadoggy
What about the ZUI add-on logs, anything there?
2024-10-08 15:17:59.624 WARN APP: Shutdown detected: closing clients...
2024-10-08 15:17:59.625 INFO GATEWAY: Closing Gateway...
2024-10-08 15:17:59.637 INFO GATEWAY: Driver is CLOSED
2024-10-08 15:17:59.683 INFO Z-WAVE-SERVER: Client disconnected
2024-10-08 15:17:59.713 INFO Z-WAVE-SERVER: Server closed
2024-10-08 15:17:59.750 INFO Z-WAVE: Client closed
[15:18:00] INFO: Service Z-Wave JS UI exited with code 0 (by signal 0)
s6-rc: info: service zwave-js-ui successfully stopped
s6-rc: info: service init-zwave-js-ui: stopping
s6-rc: info: service init-zwave-js-ui successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc-compile: fatal: invalid /etc/s6-overlay/s6-rc.d/discovery/type: must be oneshot, longrun, or bundle
s6-rc: fatal: unable to take locks: No such file or directory
s6-linux-init-shutdownd: warning: /run/s6/basedir/scripts/rc.shutdown exited 111
Going to restore off of last night’s backup…
