🎼 ZHA, deCONZ, Zigbee2MQTT - Ikea E1743 On/Off Switch & Dimmer Universal blueprint - all actions + double click events - control lights, media players and more with Hooks
Thanks @SandaleZ - I figured it out in the end :wink:
Double press not working with deCONZ
Any suggestion?
Hi, have you changed the default mapping?
EDIT: you also have to expose (activate) the double press behavior.
Thanks SandaleZ, your solution for the missing long-press brightness up/down with ZHA worked for me as well :wink:
Hi, first of all, thank you for this awesome blueprint.
So far everything works wonderfull but I have the following problem. If I press the Up button of all my switches always goes a certain lamp with on. Does anyone have an idea what this can be?
All of my automation switches looks different and have not registered this lamp.
for an example
- id: '1674664944157'
  alias: Schalter_Kueche_Belegung
  description: ''
  use_blueprint:
    path: EPMatt/ikea_e1743.yaml
    input:
      integration: Zigbee2MQTT
      controller_entity: sensor.schalter_kueche_action
      action_button_up_short:
      - type: turn_on
        device_id: ed20fab380ad29bbd91bba7dde35137b
        entity_id: light.yeelight_ceiling10_0x10d9a9e8
        domain: light
      action_button_up_long:
      - device_id: ed20fab380ad29bbd91bba7dde35137b
        domain: light
        type: brightness_increase
      action_button_up_double:
      - type: turn_on
        device_id: b93f4465b8c1229888030fc58a3b7753
        entity_id: light.arbeitsplattenbeleuchtung
        domain: light
      button_up_double_press: true
      button_down_double_press: true
      helper_last_controller_event: input_text.helper_last_controller_event_kueche
      action_button_down_short:
      - type: turn_off
        domain: light
      action_button_down_double:
      - type: turn_off
        domain: light
      - type: turn_off
        domain: light
      action_button_down_long:
        domain: light
        type: brightness_decrease
but if i press “up short” the light light.schreibtischlampe turns on.
Doesn’t seem to work for me. Any other advice?
Gibt es eine Möglichkeit das Dimmen zu verlangsamen? Ich kann leider nicht schnell genug reagieren um es zu stoppen xD
Thanks for this blueprint.
Everything works except the longpresses for me.
When I longpress it increases or decreases brightness once and then it hangs until the 500 loops are done. IF i change the loops to 10 the same things happens, it increases the dimmer 1 step then nothing.
This is my settings:
alias: Sovrum Switch Taklampa
description: ""
use_blueprint:
  input:
    controller_device: 007d6fb3b356df1e0b8fcde9bddafc53
    controller_entity: sensor.sovrum_switch_action
    helper_last_controller_event: input_text.sovrum_ikea_switch
      - type: toggle
        device_id: 8d91c0ddf5d2e16e2f9e82520d399088
        entity_id: light.sovrum_taklampa
        domain: light
      - device_id: 8d91c0ddf5d2e16e2f9e82520d399088
        domain: light
      - type: toggle
        domain: light
        domain: light
    button_up_long_loop: true
    button_down_long_loop: true
    action_button_down_release: []
    button_up_long_max_loop_repeats: 10
    button_down_long_max_loop_repeats: 10
Hrm. I’m having an issue with long presses and this Blueprint/Controller as well. I use my E1743 with ZHA, and incorporated the fixes from @SandaleZ last year.
Now when I update from 2023.4.x to 2023.5.x, the long press doesn’t “stop”. If I hold to dim a light up/down, it keeps going after I let go.
I’m gonna look at the ZHA entries in the Helper to see if I can figure out what events are being set. I’m keeping a backup of my config and 2023.4.6 just in case.
Hey,
this is my first post so forgive me if its the wrong part of the forum.
Im trying to set up E1766 for my blinds and E1743 for my lights. I have filled in all the required fields but when I try to save it always return a “Response error: 500”.
So when I check the logs it says:
Error handling request
13:08:42 – (ERROR) components/config/automation.py
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 235, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 146, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/__init__.py", line 145, in post
    self._write_value(hass, current, config_key, data)
  File "/usr/src/homeassistant/homeassistant/components/config/automation.py", line 70, in _write_value
    cur_value[CONF_ID] = uuid.uuid4().hex
**TypeError: 'str' object does not support item assignment**
Any suggestions on what Im doing wrong here?
Hi, welcome to the forum!
The automation seems to be right, things you could try:
  • use an entity instead of a device and/or another device for the action to see if the that works
  • delete & recreate the automation
Just an idea or wait for someone else who makes more out of that error.
Figured out the fix for my long press issue.
It’s in this Pull Request for the blueprint: remove spaces to match new helper format in 2023.5 by LordSushiPhoenix · Pull Request #545 · EPMatt/awesome-ha-blueprints · GitHub
The short story is that in HA 2023.4.6 and older, the helper text messages would be something like this:
{"a": "off", "t": 1684956194.70524}
After updating to 2023.5.x, they look like this:
{"a":"off","t":1684956194.70524}
The key difference is that there is no longer a space after each colon or comma. The blueprint has regex that is hard-coded to look for that, which causes it to “miss” these events.
@tuffno: Though I don’t use Z2M (ZigBee2MQTT), there are some folks in that pull request link and in this issue link that have implemented similar fixes. Though they’re talking about a double-tap issue, it’s caused by the same bug in the end.
Blueprint works great for the 5 button remote but double press stopped working with HA core 5.0 update. Last version it’s working is with 4.6 which I now reverted to. Any ideas how to keep this working with newer versions of HA?
Running HA supervisor on docker.
EDIT: Nevermind I dug into the github discussions and already found that there are several pull requests for other tradfri models which changed 2 regex entries. These changes should be applied to the blueprint to make double taps work on HA 5.x. I made a pull requests for my model yaml can be downloaded here: changed regex to make double tap work again on HA 5.x by comk22 · Pull Request #550 · EPMatt/awesome-ha-blueprints · GitHub
Ah
 that explains whats happened to my switches.
Looking at the blueprint code I think you’re talking about lines 299-305:
    trigger_delta: '{{ (as_timestamp(now()) - ((states(helper_last_controller_event)
      | from_json).t if helper_last_controller_event is not none and (states(helper_last_controller_event)
      | regex_match("^\{((\"a\": \".*\"|\"t\": \d+\.\d+)(, )?){2}\}$")) else as_timestamp("1970-01-01
      00:00:00"))) * 1000 }}'
    last_controller_event: '{{ (states(helper_last_controller_event) | from_json).a
      | regex_match("^\{((\"a\": \".*\"|\"t\": \d+\.\d+)(, )?){2}\}$")) else "" }}'
Pretty sure thats a trivial fix. I’ll have a go at it later when I am home.
Ok, I changed my blueprint file for the E1743 and double presses are working again, by simply changing the block of code between lines 309-315 to this:
      | regex_match("^\{((\"a\":\".*\"|\"t\":\d+\.\d+)(,)?){2}\}$")) else as_timestamp("1970-01-01
      | regex_match("^\{((\"a\":\".*\"|\"t\":\d+\.\d+)(,)?){2}\}$")) else "" }}'
One last thing was still broken. For some reason, long press down no longer works.
When listening to the ZHA events for this, this is what I get:
event_type: zha_event
  device_ieee: 70:ac:08:ff:fe:b0:ef:e3
  unique_id: 70:ac:08:ff:fe:b0:ef:e3:1:0x0008
  device_id: d0c386d7bd249ec226ae57987d9b701a
  endpoint_id: 1
  cluster_id: 8
  command: move
  args:
    - 1
    - 83
    - 0
    - 0
  params:
    move_mode: 1
    rate: 83
    options_mask: 0
    options_override: 0
origin: LOCAL
time_fired: "2023-06-22T20:06:58.294432+00:00"
context:
  parent_id: null
  user_id: null
Which according to the existing blueprint, should be interpreted as this:-
      button_down_long:
      - move_MoveMode.Down_83_bitmap8.0_bitmap8.0
(See lines 236-237).
I’ve had to change this to:
      button_down_long:
      - move_MoveMode.Down_83_0_0
And long button down presses are now working again.
Can you update blueprint please? My double button wont work
I’m using ZHA and is not working any button
alias: Controller - IKEA E1743 TRÅDFRI On/Off Switch & Dimmer
description: ‘’
use_blueprint:
input:
integration: ZHA
controller_device: 0636ea5d6cce1e93af9a14e56cab5b5e
- type: turn_on
device_id: 0f73127aaba38182b2069c668b81f374
entity_id: 3cbfdbeedbd90a2a7f70eff657915668
domain: light
- type: turn_on
domain: light
action_button_up_release:
- type: turn_on
device_id: e0e897dbe4fa39dcc56335b14c144f09
entity_id: 211d965dd7a08ed77265ff7bb8da5a95
domain: light
- type: turn_on
domain: light
please some support here
Nick
Hi, format your code properly please
“trace”: {
“last_step”: “action/1”,
“run_id”: “a04993142eb9da4c8ba9b9268ef4a24f”,
“state”: “stopped”,
“script_execution”: “error”,
“timestamp”: {
“start”: “2023-08-02T15:46:39.864527+00:00”,
“finish”: “2023-08-02T15:46:39.915265+00:00”
“domain”: “automation”,
“item_id”: “1690991159540”,
“error”: “UndefinedError: ‘dict object’ has no attribute ‘event’”,
“trigger”: null,
“trace”: {
“trigger”: [
“path”: “trigger”,
“timestamp”: “2023-08-02T15:46:39.868233+00:00”,
“changed_variables”: {
“this”: {
“entity_id”: “automation.new_automation_7”,
“state”: “on”,
“attributes”: {
“id”: “1690991159540”,
“last_triggered”: “2023-08-02T15:46:28.112870+00:00”,
“mode”: “restart”,
“current”: 0,
“friendly_name”: “New Automation”
“last_changed”: “2023-08-02T15:46:00.839473+00:00”,
“last_updated”: “2023-08-02T15:46:28.117414+00:00”,
“context”: {
“id”: “01H6VEVP4ENZ67D35YAKQQX1WH”,
“parent_id”: “01H6VEVP4CZ8WH3AECGXF46HHM”,
“user_id”: null
“trigger”: {
“platform”: null
“integration”: “ZHA”,
“button_up_long_loop”: false,
“button_up_long_max_loop_repeats”: 500,
“button_up_double_press”: false,
“button_down_long_loop”: false,
“button_down_long_max_loop_repeats”: 500,
“button_down_double_press”: false,
“helper_last_controller_event”: “”,
“helper_double_press_delay”: 500,
“helper_debounce_delay”: 0,
“integration_id”: “zha”,
“adjusted_double_press_delay”: 500,
“actions_mapping”: {
“deconz”: {
“button_up_short”: [
“1002”
“button_up_long”: [
“1001”
“button_up_release”: [
“1003”
“button_down_short”: [
“2002”
“button_down_long”: [
“2001”
“button_down_release”: [
“2003”
“zha”: {
“on”
“button_up_long”: [
“move_with_on_off_0_83”
“stop”
“off”
“move_1_83”
“stop”
“zigbee2mqtt”: {
“on”
“button_up_long”: [
“brightness_move_up”
“brightness_stop”
“off”
“brightness_move_down”
“brightness_stop”
“on”
“button_up_long”: [
“stop”
“off”
“move_1_83”
“stop”
“integrations_with_prev_event_storage”: [
“zha”,
“zigbee2mqtt”
“controller_entity”: “”,
“controller_device”: “0636ea5d6cce1e93af9a14e56cab5b5e”,
“controller_id”: “0636ea5d6cce1e93af9a14e56cab5b5e”
“action/0”: [
“path”: “action/0”,
“timestamp”: “2023-08-02T15:46:39.888386+00:00”,
“context”: {
“id”: “01H6VEW1KRYPEBEXCGH1WT1K4A”,
“parent_id”: “01H6VEW1KPG9E7DYVDHNW11TJS”,
“user_id”: null
“result”: {
“delay”: 0,
“done”: true
“action/1”: [
“path”: “action/1”,
“timestamp”: “2023-08-02T15:46:39.890085+00:00”,
“config”: {
“variables”: {
“integration_id”: “{{ integration | lower }}”,
“adjusted_double_press_delay”: “{{ [helper_double_press_delay - helper_debounce_delay, 100] | max }}”,
“deconz”: {
“1002”
“button_up_long”: [
“1001”
“1003”
“2002”
“2001”
“2003”
“zha”: {
“on”
“button_up_long”: [
“stop”
“off”
“move_1_83”
“stop”
“zigbee2mqtt”: {
“on”
“button_up_long”: [
“brightness_stop”
“off”
“brightness_stop”
“button_up_short”: “{{ actions_mapping[integration_id][“button_up_short”] }}”,
“button_up_long”: “{{ actions_mapping[integration_id][“button_up_long”] }}”,
“button_up_release”: “{{ actions_mapping[integration_id][“button_up_release”] }}”,
“button_down_short”: “{{ actions_mapping[integration_id][“button_down_short”] }}”,
“button_down_long”: “{{ actions_mapping[integration_id][“button_down_long”] }}”,
“button_down_release”: “{{ actions_mapping[integration_id][“button_down_release”] }}”,
“zha”,
“zigbee2mqtt”
“controller_id”: “{% if integration_id==“zigbee2mqtt” %}{{controller_entity}}{% else %}{{controller_device}}{% endif %}”
“mode”: “restart”,
“max_exceeded”: “silent”,
“trigger”: [
“platform”: “event”,
“event_type”: “state_changed”,
“event_data”: {
“entity_id”: “”
“event_type”: [
“deconz_event”,
“zha_event”
“event_data”: {
“device_id”: “0636ea5d6cce1e93af9a14e56cab5b5e”
“condition”: [
“condition”: “and”,
“conditions”: [
“{%- set trigger_action -%} {%- if integration_id == “zigbee2mqtt” -%} {{ trigger.event.data.new_state.state }} {%- elif integration_id == “deconz” -%} {{ trigger.event.data.event }} {%- elif integration_id == “zha” -%} {{ trigger.event.data.command }}{{”" if trigger.event.data.args|length > 0}}{{ trigger.event.data.args|join("") }} {%- endif -%} {%- endset -%} {{ trigger_action not in ["",“None”] }}",
“{{ integration_id != “zigbee2mqtt” or trigger.event.data.new_state.state != trigger.event.data.old_state.state }}”
“action”: [
“delay”: {
“milliseconds”: 0
“variables”: {
“trigger_action”: “{%- if integration_id == “zigbee2mqtt” -%} {{ trigger.event.data.new_state.state }} {%- elif integration_id == “deconz” -%} {{ trigger.event.data.event }} {%- elif integration_id == “zha” -%} {{ trigger.event.data.command }}{{”" if trigger.event.data.args|length > 0}}{{ trigger.event.data.args|join("") }} {%- endif -%}",
“trigger_delta”: “{{ (as_timestamp(now()) - ((states(helper_last_controller_event) | from_json).t if helper_last_controller_event is not none and (states(helper_last_controller_event) | regex_match(”^\{((\“a\”: \".\"|\“t\”: \d+\.\d+)(, )?){2}\}$")) else as_timestamp(“1970-01-01 00:00:00”))) * 1000 }}",
“last_controller_event”: “{{ (states(helper_last_controller_event) | from_json).a if helper_last_controller_event is not none and (states(helper_last_controller_event) | regex_match(”^\{((\“a\”: \".
\"|\“t\”: \d+\.\d+)(, )?){2}\}$")) else “” }}"
“service”: “input_text.set_value”,
“data”: {
“entity_id”: “”,
“value”: “{{ {“a”:trigger_action,“t”:as_timestamp(now())} | to_json }}”
“choose”: [
“conditions”: “{{ trigger_action | string in button_up_short }}”,
“sequence”: [
“choose”: [
“conditions”: “{{ button_up_double_press }}”,
“sequence”: [
“choose”: [
“conditions”: “{{ trigger_action | string in states(helper_last_controller_event) and trigger_delta | int <= helper_double_press_delay | int }}”,
“sequence”: [
“data”: {
“entity_id”: “”,
“value”: “{{ {“a”:“double_press”,“t”:as_timestamp(now())} | to_json }}”
“event”: “ahb_controller_event”,
“event_data”: {
“controller”: “{{ controller_id }}”,
“action”: “button_up_double”
“choose”: [
“conditions”: [],
“sequence”: []
“default”: [
“delay”: {
“milliseconds”: “{{ adjusted_double_press_delay }}”
“event_data”: {
“action”: “button_up_short”
“choose”: [
“conditions”: [],
“sequence”: [
“type”: “toggle”,
“device_id”: “0f73127aaba38182b2069c668b81f374”,
“entity_id”: “3cbfdbeedbd90a2a7f70eff657915668”,
“domain”: “light”
“default”: [
“event_data”: {
“choose”: [
“conditions”: [],
“sequence”: [
“type”: “toggle”,
“domain”: “light”
“conditions”: “{{ trigger_action | string in button_up_long }}”,
“sequence”: [
“event_data”: {
“action”: “button_up_long”
“choose”: [
“conditions”: “{{ button_up_long_loop }}”,
“sequence”: [
“repeat”: {
“while”: “{{ repeat.index < button_up_long_max_loop_repeats | int }}”,
“sequence”: []
“default”: []
“conditions”: [
“{{ trigger_action | string in button_up_release }}”,
“{{ not integration_id in integrations_with_prev_event_storage or last_controller_event | string in button_up_long }}”
“sequence”: [
“event_data”: {
“action”: “button_up_release”
“choose”: [
“conditions”: [],
“sequence”: []
“conditions”: “{{ trigger_action | string in button_down_short }}”,
“sequence”: [
“choose”: [
“conditions”: “{{ button_down_double_press }}”,
“sequence”: [
“choose”: [
“sequence”: [
“data”: {
“entity_id”: “”,
“event_data”: {
“action”: “button_down_double”
“choose”: [
“conditions”: [],
“sequence”: []
“default”: [
“delay”: {
“event_data”: {
“action”: “button_down_short”
“choose”: [
“conditions”: [],
“sequence”: []
“default”: [
“event_data”: {
“choose”: [
“conditions”: [],
“sequence”: []
“conditions”: “{{ trigger_action | string in button_down_long }}”,
“sequence”: [
“event_data”: {
“action”: “button_down_long”
“choose”: [
“conditions”: “{{ button_down_long_loop }}”,
“sequence”: [
“repeat”: {
“while”: “{{ repeat.index < button_down_long_max_loop_repeats | int }}”,
“sequence”: []
“default”: []
“conditions”: [
“{{ trigger_action | string in button_down_release }}”,
“{{ not integration_id in integrations_with_prev_event_storage or last_controller_event | string in button_down_long }}”
“sequence”: [
“event_data”: {
“action”: “button_down_release”
“choose”: [
“conditions”: [],
“sequence”: []
“alias”: “New Automation”,
“description”: “”
“blueprint_inputs”: {
“description”: “”,
“use_blueprint”: {
“path”: “EPMatt/ikea_e1743.yaml”,
“input”: {
“action_button_up_short”: [
“type”: “toggle”,
“domain”: “light”
“context”: {
“user_id”: null
“logbookEntries”: [
“name”: “New Automation”,
“message”: “triggered”,
“source”: null,
“context_id”: “01H6VEW1KRYPEBEXCGH1WT1K4A”,
“when”: 1690991199.868478,
Do you realize that you have just posted some gibberish without any way for us to know what the purpose is?
