I suggest looking at Switch Manager. It works with the IKEA devices including this rotary one.
Thanks so much for the tip.
Woah that integration is amazing!! Setup the sound remote and it works perfectly.
Just wish I had known about this one before manually creating automations for each of my 30 or so Friends of Hue Lightswitches, Hue Dimmer Switches and Ikea Buttons over the past couple of daysâŠ
Just went into HACS and clicked install. No issues. I am using the Home Assistant OS install. Are you sure you got the correct integration selected?
Or do you have some âexoticâ installation of HA?
Yes Iâm using standard HA, nothing exitic. and latest versionâŠ
When I click the âadd integrationâ Iâm taken to this URL: Link to Integrations: add integration â My Home Assistant
Can you confirm that this is the correct integration?
Hello @n00bish , @drsound & HA fans,
I experiment with HA since about a year (considering myself newbie).
I get a Docker install of HA.
I created a ikea_e1744.yaml file located at /home/[USER]/hass-config/blueprints/automation/homeassistant/ using
~$ sudo nano /home/[USER]/hass-config/blueprints/automation/homeassistant/ikea_e1744.yaml
and pasted there the content from @drsound since I understand it was never merged.
I reloaded config using
Developper Tools > YAML > All Yaml Configuration
(Tried Developper Tools > YAML > Automations as well)
However the blueprint does not appear magically in the blueprint listâŠ
Any idea why?
Hey @LeoG . Do you not have the âimport blueprintâ button on the docker instance of HA?
If you do, then click it, and paste it the url: https://raw.githubusercontent.com/EPMatt/awesome-ha-blueprints/157f8964a777ac5ae4acd108c7cc7766256fe44f/blueprints/controllers/ikea_e1744/ikea_e1744.yaml
This is the link @drsound posted ealier. It worked perfectly for me
I have this remote working fine in both HA and Node red.
Not sure what the issue is.
Although I recommend getting the new that is not spinning. That is a far much better remote. The only downside of that remote is that itâs all white and itâs really hard to see what button is what.
Anyways, the old remote. Here is my automation for that remote
alias: David IKEA remote
description: ""
- platform: event
event_type: zha_event
event_data:
device_id: 3d00470f1ec47548299d3ba0d5bb5ea1
command: move
args:
- 0
- 195
- 0
- 0
- platform: event
event_data:
command: move
args:
- 1
- 195
- 0
- 0
- platform: event
event_data:
command: toggle
- platform: event
event_data:
command: step
args:
- 0
- 1
- 0
- 0
- 0
- platform: event
event_data:
command: step
args:
- 1
- 1
- 0
- 0
- 0
enabled: false
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: button.press
data: {}
entity_id: button.david_lg_tv_volume_up
- choose:
- conditions:
sequence:
data: {}
entity_id: button.david_lg_tv_volume_down
- choose:
- conditions:
sequence:
- service: media_player.media_play_pause
data: {}
entity_id: media_player.chromecast5039
- choose:
- conditions:
- condition: state
entity_id: binary_sensor.david_tv_on_off
state: "on"
sequence:
- service: media_player.turn_off
data: {}
entity_id: media_player.playstation_4
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
data: {}
entity_id: button.david_lg_tv_on_off
enabled: false
mode: single
This blueprint does not work properly anymore since HA v2024.10!
I use the Ikea volume knobs for changing the volume of my denon receiver. Canât use the option âloop until stopâ anymore because it brakes the automation somehow. Without this option enabled I have to spin the knob very very slowly.
In HA v2024.9 with âloop until stopâ enabled it worked so perfectly! Is there a workaround to make it work again in the newer HA releases?
Thereâs an issue on the Redux repo here: Bug - E1744 rotates continuously with light brightness or media volume · Issue #25 · lsismeiro/awesome-ha-blueprints · GitHub
(I havenât made a redux forum post yet, if we get a fix for it, I can?)
Anyone got a solution to get the rotation to work?
My issue seems to be that this doesnât get defined:
{{ (states(helper_last_controller_event) | from_json).a if
helper_last_controller_event is not none and
(states(helper_last_controller_event) | regex_match("^\{((\"a\":
\".*\"|\"t\": \d+\.\d+)(, )?){2}\}$")) else "" }}
Hi - It may be worth raising a issue here if you are using the new repo: GitHub - lsismeiro/awesome-ha-blueprints: A curated collection of automation blueprints for Home Assistant.
The only other issue we have raised right now is that the spin will not stop - rather than it not working before.
I also see your trigger_action is rotate_left. This does not match the mapped action value in the blueprint which is brightness_move_down. I manually changed the action value for rotation in the blueprint to the values reported by the device. Started working with these changes.
actions_mapping:
zigbee2mqtt:
rotate_left:
- rotate_left
rotate_stop:
- rotate_stop
rotate_right:
- rotate_right
After the latest Z2M update to version 2.0.0 the blueprint was broken.
As i see, the âZigbee2MQTT) Controller Entityâ is deleted therefore the whole automation wonât run at all.
Any ideas?
Did you read the release notes before updating?
There is a fairly active thread now with a lot of details how to fix it for those who didnât read before clicking.
Yes i did read the release notes and since im not an advanced user, i didnât understand what exactly i had to change in the automation to run again.
Right now, i just restored the previous version and works as it should be and i will check it again.
I created a sensor from the new event value to use it in my blueprint that wants only a sensor entity. Works for me!
What i have done: Added Sensor in configuration.yaml
How do add Sensor from Event:
Create a Sensor from Event Values in Home Assistant
This guide shows how to extract values from an event entity and display them as a sensor in Home Assistant.
Example Configuration:
# Add to configuration.yaml
# Template sensor to display event_type from an event entity
template:
- sensor:
- name: "Event Sensor"
state: >
{{ states.event["your_event_entity_id"].attributes.event_type if "event_type" in states.event["your_event_entity_id"].attributes else "unknown" }}
attributes:
friendly_name: "Event Sensor"
icon: mdi:gesture-double-tap
Steps:
Replace your_event_entity_id with your actual event entity ID (e.g., event.ikea_symfonisk_schwarz_action).
Add the configuration to your configuration.yaml or template.yaml file.
Restart Home Assistant.
Now you have a sensor that dynamically updates with the event_type of the specified event entity.
I tried to do this, it appeared but didnât seem to work lol.
Will the blueprint be able to be updated to follow the new rules or it will it likely be removed?
