Blueprint to support the Ikea Symfonsik sound controller and allow it to control a media player, and other devices.
The Symfonisk sound controller supports:
- Single press
- Double press
- Triple press
- Rotate left
- Rotate right
Screen
Blueprint
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the forum topic URL:
blueprint:
name: ZHA - IKEA Symfonisk sound controller for media
description: 'Control media with an IKEA Symfonisk sound controller (the spinny ones).
Single press will toggle Play/Pause on your selected media player.
You can set functions for double press and triple press.
Rotating left/right will change the volume smoothly of the selected media player, if that function is possible.'
domain: automation
input:
remote:
description: IKEA Symfonisk controller to use
selector:
device:
integration: zha
manufacturer: IKEA of Sweden
model: SYMFONISK Sound Controller
media_player:
description: The media player to control
selector:
entity:
domain: media_player
double_press:
description: Action to run on double press
default: []
selector:
action: {}
triple_press:
description: Action to run on triple press
default: []
selector:
action: {}
source_url: https://gist.github.com/seamus65/35bd8cf0323961aa42847a11c17e0de0
mode: single
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input 'remote'
- variables:
command: '{{ trigger.event.data.command }}'
cluster_id: '{{ trigger.event.data.cluster_id }}'
endpoint_id: '{{ trigger.event.data.endpoint_id }}'
args: '{{ trigger.event.data.args }}'
- choose:
- conditions:
- '{{ command == ''toggle'' }}'
- '{{ cluster_id == 6 }}'
- '{{ endpoint_id == 1 }}'
sequence:
- service: media_player.media_play_pause
target: !input 'media_player'
- conditions:
- '{{ command == ''step'' }}'
- '{{ cluster_id == 8 }}'
- '{{ args == [0, 1, 0] }}'
sequence: !input 'double_press'
- conditions:
- '{{ args == [1, 1, 0] }}'
sequence: !input 'triple_press'
- conditions:
- '{{ command == ''move'' }}'
- '{{ args == [0, 195] }}'
sequence:
- service: media_player.volume_up
- delay: 1
- conditions:
- '{{ args == [1, 195] }}'
sequence:
- service: media_player.volume_down
- delay: 1
