ZHA - Philips Hue Dimmer Switch (RWL020, RWL021)
I think this is wonderful, thanks!
I hope version could be released some time that mimicks the advanced scene toggle function (choosing scenes based on amount of clicks on the on-button)
Iā€™ll look in to it :slight_smile:
Great Job!
BUT, is there a way to change the integration type? I use zigbee2mqtt. Is this a simple platform change in your blueprint, or a whole new thing?
Hi, thanks for sharing this. Big help for a newb like me.
The original scene select function is great, but I think it would be even better to have the ā€œonā€ button step cycle through color_temp values (when light is on). Maybe with a selector for number of steps.
I have a very primitive automation doing this, but my lack of yaml skills prevent me from incorporating it with your blueprint and if your (very cool) brightness feature is on itā€™ll kick in whenever I press the ā€œonā€ button. An additional feature could be a smooth transition through color_temp when ā€œonā€ is held.
Just some thoughts. Thanks again.
Have a look at ControllerX, can do all sorts with that and really easy to set up.
On / Off doesnt work for me :smiley: Only the dimming works
RWL021
Iā€™m looking at your code for minutes now, itā€™s awesome how easy blueprints would make automations for newcomers!
Weā€™re using this dimmer switches in horizontal in the following way:
using the ā€œIā€ button for light 1 & the ā€œOā€ button for light 2
For both: on (short press) and off (long press)
I could thing of a way to use your blueprint to archive this.
But currently iā€™m using a variable to store the last changed light of this two and using the dim up/ down button to change the brightness of the last changed light. But Iā€™ve got no idea how I could solve that using only one automation (currently having one for turning light 1 on/off, one for light 2 on/off, and one for each light to change the brightness) or make that available for others as a blueprint.
Maybe you find that helpful, too and are able to edit your blueprint and post that separately :slight_smile:
Greets
I think its best to make one general template for each speciality. One base that do the dame as philips default and one that can switch between lights. I do the deconz version and have the color temp mode fixed tomorrow (code can be exchanged) but its also possible to use same principle (long press) to change bulb or so.
But not one size fits all, that i do not suggest. Keep this one simple
With the greatest respect to yours and others work, check out the ControllerX add on as mentioned above, it will make your life so much simpler, out of the box it makes the Hue Dimmer work as nature intended and thatā€™s literally just the most basic functionā€¦
I am using ControllerX now, and it is working pretty good. But if I could ditch AppDaemon, without losing functionality that would be great.
Can I ask why you want to ditch AppDaemon? Doing it this way would normally be considered a backward step :slight_smile:
Fair question!
I have a wish to keep my setup as simple as possible, for instance:
Using ZHA instead of Deconz.
Using HA Automations instead of Node-Red.
Of course, it has to be without considerable loss of functionality (which is why I am using ControllerX now). But it is my experience, that a simpler setup brings less headaches down the road, and I am definitely going to test if this can replace ControllerX.
Thanks, man after my own heart, both examples are the same for me, other than came to ZHA from zigbee2mqtt, although Iā€™ve also found they work better but must admit I just donā€™t get on with Node-Red, actually seems far more complicated than good old yaml for everything I want to do :slight_smile:
Also admit I avoided AppDaemon like the plague for ages and only installed it for ControllerX but hadnā€™t realised the add-on now makes it so simple and itā€™s like itā€™s not even there.
Good luck, whichever way you go.
@Bobby_Nobble Thanks for the suggestion, but I think the new blueprint is the way to go. No additional software needed, fully integrated into the web interface, no editor needed, growing community.
Itā€™s good to hear that ControllerX can do much more than this blueprint right now, however Iā€™m sure this will evolve very quickly.
I have ControllerX set up and working and it does everything I want - except step-cycling through color_temp.
I am the creator of ControllerX, and I agree on the fact that the setup process for ControllerX is tedious and relies on AppDaemon, which is not an official tool. I see that Blueprints are the official way towards something that ControllerX already does, but Blueprints are no more than parematrized automations that can be shared thrhough the community. They can be used for other use cases since they have a generic purpose, which is great.
ControllerX on the other hand, it is an specific tool that allows you to create controller-based automations. It can not be used for anything not related to controllers, this means that they donā€™t have a generic purpose, but focus well in the simple task of integrating controllers with your HA entities and services. ControllerX has the following functionality over Blueprints amongst others:
  • Integration with Z2M (state and mqtt), deCONZ and ZHA.
  • Easy to define a custom mappings through YAML code with predefined actions.
  • Smooth transition for brightness, color temp, volume.
  • Color loop for lights that support color.
  • Multiple click functionality for controllers with no hardware support for it.
  • Be able to define a very specific use case. For Blueprints if you want something specific, you need to change the blueprint yaml, which loses the purpose of using a Blueprint in my opinion.
Blueprints seem to be a beginning towards an easy way to create controller-based automations, but far to be fairly compared with ControllerX when it comes to functionality.
Hi @k_manggaard,
Could you develop your idea? Do you mean infinitely cycling through the color temp? So from warm go to cold color directly and then cycle back again without releasing the button?
Regards,
Xavi M.
Thank you @Bobby_Nobble for the support. As I said, I understand the point of ControllerX not being part of Native HA. I did create ControllerX because HA was missing this functionality, and in my opinion it still does. Blueprints is a better way to solve that problem I had a year ago, but it does not solve the same problem as ControllerX does.
I guess if someone just needs an standard way of integrating a controller, Blueprints are okay, but if someone needs to go further with an specific use case, then I still recommend ControllerX for it since as you said, it is much flexible and solves all the problems that everyone is trying to solve in this thread.
Is it possible to add ā€œmulti functionalityā€ to the on button, just like original work? First click on, second next collor/scene third next color/scene ā€¦ and when you have cycled it goes back to the first color.
Iā€™ll try to explain:
Out of the box, when paired with a warm/cold bulb, the dimmer switch cycles through a number of predefined scenes when clicking the ā€œonā€ button. What I would like is to cycle through predefined color_temp values instead. So if the bulbā€™s color_temp was at 50% when turned on, subsequent clicks would take it to 60%, 70%, 80% and so on, eventually going from 100% back to 0%. Preferably with the option to define the size and duration of ā€œjumpsā€. This is actually the default behavior of the TrĆ„dfri remote, although that one only cycles through 3 values (I think).
Great work! And thanks for the interest.
