This is a blueprint for the Philips Hue Dimmer Switch specifically for use with ZHA.
Control lights with a Philips Hue Dimmer Switch.
The top "on" button will turn the lights on to the last set brightness
(unless the force brightness is toggled on in the blueprint).
Dim up/down buttons will change the brightness smoothly and can be pressed
and hold until the brightness is satisfactory.
The bottom "off" button will turn the lights off.
Get started
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the forum topic URL:
blueprint:
name: ZHA - Philips Hue Dimmer Switch
description: 'Control lights with a Philips Hue Dimmer Switch.
domain: automation
input:
remote:
name: Philips Hue Dimmer Switch
description: Pick either RWL020 (US) or RWL021 (EU)
selector:
device:
integration: zha
manufacturer: Philips
entity:
domain: sensor
device_class: battery
light:
description: The light(s) to control
selector:
entity:
domain: light
force_brightness:
name: Force turn on brightness
description:
'Force the brightness to the set level below, when the "on" button
on the remote is pushed and lights turn on.
default: false
selector:
boolean: {}
brightness:
description: Brightness of the light(s) when turning on
default: 100
selector:
number:
min: 0.0
max: 100.0
mode: slider
step: 1.0
unit_of_measurement: "%"
source_url: https://community.home-assistant.io/t/zha-philips-hue-dimmer-switch/255048
mode: restart
max_exceeded: silent
variables:
force_brightness: !input "force_brightness"
- platform: event
event_type: zha_event
event_data:
device_id: !input "remote"
- variables:
command: "{{ trigger.event.data.command }}"
cluster_id: "{{ trigger.event.data.cluster_id }}"
endpoint_id: "{{ trigger.event.data.endpoint_id }}"
args: "{{ trigger.event.data.args }}"
- choose:
- conditions:
- "{{ command == 'on' }}"
- "{{ cluster_id == 6 }}"
- "{{ endpoint_id == 1 }}"
sequence:
- choose:
- conditions: "{{ force_brightness }}"
sequence:
- service: light.turn_on
target: !input "light"
transition: 1
brightness_pct: !input "brightness"
default:
transition: 1
- conditions:
- "{{ command == 'off_with_effect' }}"
- "{{ args == [0, 0] }}"
sequence:
- service: light.turn_off
transition: 1
- conditions:
- "{{ command == 'step' }}"
- "{{ cluster_id == 8 }}"
- "{{ args == [0, 30, 9] }}"
sequence:
brightness_step_pct: 10
transition: 1
- conditions:
- "{{ args == [0, 56, 9] }}"
sequence:
brightness_step_pct: 25
transition: 1
- conditions:
- "{{ args == [1, 30, 9] }}"
sequence:
brightness_step_pct: -10
transition: 1
- conditions:
- "{{ args == [1, 56, 9] }}"
sequence:
brightness_step_pct: -25
transition: 1
