@ptdalen, do you have any bulbs on your zigbee network? ZHA has been really, really rough for me lately.
RANT TIME:
After a reboot everything works - but then in a day or so all my lights (and a switched outlet) stop responding reliably, and eventually they stop responding at all. The lights are all Osram/Sylvania Lightify at the moment - five are RGBW and two are two are Warm/Cool White. The switched outlet is an IRIS v2 plug (reads as CentraLite 3210-L, with the odd dual z-wave/zigbee radios). Iām not sure what the issue is, because ZHA had been pretty darn reliable for a good number of months. (I also have a Tradfi bulb that I was able to include months ago, but I have since reset it, nuked my zigbee.db, and attempted to re-add, and it will no longer show up.)
I also have one and three Visonic MCT-340E door/window sensors spread around a very large house. Even after the bulbs (and the IRIS plug) quit responding, the door sensors still work and are very reliable. The built-in temperature sensors work too.
The five RGBW lights and the IRIS plug are all within 10 feet of the HUSBZB-1 stick, most of them line-of-sight. And yet they drop off just as quickly as the ones further away.
Hereās what an error in the log looks like after the lights stop responding:
Mon Jul 09 2018 00:10:40 GMT-0400 (EDT)
Error executing service ServiceCall light.turn_off: entity_id=['light.osram_lightify_a19_rgbw_00a3342d_3']
File "/usr/src/app/homeassistant/core.py", line 1021, in _event_to_service_call
await service_handler.func(service_call)
File "/usr/src/app/homeassistant/components/light/__init__.py", line 362, in async_handle_light_service
await light.async_turn_off(**params)
File "/usr/src/app/homeassistant/components/light/zha.py", line 127, in async_turn_off
await self._endpoint.on_off.off()
File "/usr/local/lib/python3.6/site-packages/zigpy/device.py", line 89, in request
expect_reply=expect_reply,
File "/usr/local/lib/python3.6/site-packages/bellows/zigbee/application.py", line 213, in request
assert sequence not in self._pending
AssertionError
Any input welcome!
My proposed next step is to try to update the firmware on the bulbs:
Exclude/reset all seven bulbs,
Add them into the Lighify network (I have a gateway and account already) and do the updates,
Exclude/Reset them all again,
Add them all back to ZHA and see what happens. If they retain their IEEE addresses after the updates, at least this part should be easy.
Ugh.
Iām also thinking I need to pick up a Tradfri gateway to update that bulb, since I bought it fairly early in their availability.
Thereās got to be a better way. Z-wave stuff just WORKS.
