This is the blueprint for the Loratap SS600ZB / Tuya TS0043 3-button wireless switch for Zigbee2MQTT:
Supported actions for each button:
Single press
Double press
Long press
Further information: TuYa TS0043 control via MQTT | zigbee2mqtt.io
blueprint:
name: Zigbee2MQTT - Loratap SS600ZB / Tuya TS0043 Zigbee Wireless Switch
description: Automate your Loratap SS600ZB / Tuya TS0043 Zigbee Wireless Switch via Zigbee2MQTT.
domain: automation
input:
switch:
name: Loratap SS600ZB / Tuya TS0043 Zigbee Wireless Switch
description: Loratap SS600ZB / Tuya TS0043 Zigbee Wireless Switch to use
selector:
entity:
integration: mqtt
domain: sensor
button_one_short_press:
name: Single Press - Button 1
description: Action to run on button 1 - single press
default: []
selector:
action: {}
button_one_double_press:
name: Double Press - Button 1
description: Action to run on button 1 - double press
default: []
selector:
action: {}
button_one_long_press:
name: Long Press - Button 1
description: Action to run on button 1 - long press
default: []
selector:
action: {}
button_two_short_press:
name: Single Press - Button 2
description: Action to run on button 2 - single press
default: []
selector:
action: {}
button_two_double_press:
name: Double Press - Button 2
description: Action to run on button 2 - double press
default: []
selector:
action: {}
button_two_long_press:
name: Long Press - Button 2
description: Action to run on button 2 - long press
default: []
selector:
action: {}
button_three_short_press:
name: Single Press - Button 3
description: Action to run on button 3 - single press
default: []
selector:
action: {}
button_three_double_press:
name: Double Press - Button 3
description: Action to run on button 3 - double press
default: []
selector:
action: {}
button_three_long_press:
name: Long Press - Button 3
description: Action to run on button 3 - long press
default: []
selector:
action: {}
source_url: https://github.com/AramidX/ha-blueprint/blob/8e259f8e40ab1218f06ea1ce1d1444f67b4cd62f/blueprints/tuya/loratap_ss600zb_wireless_switch_z2m.yaml
mode: restart
max_exceeded: silent
- platform: state
entity_id: !input "switch"
attribute: action
- variables:
command: '{{ trigger.to_state.state }}'
- choose:
- conditions:
- '{{ command == ''1_single'' }}'
sequence: !input 'button_one_short_press'
- conditions:
- '{{ command == ''2_single'' }}'
sequence: !input 'button_two_short_press'
- conditions:
- '{{ command == ''3_single'' }}'
sequence: !input 'button_three_short_press'
- conditions:
- '{{ command == ''1_double'' }}'
sequence: !input 'button_one_double_press'
- conditions:
- '{{ command == ''2_double'' }}'
sequence: !input 'button_two_double_press'
- conditions:
- '{{ command == ''3_double'' }}'
sequence: !input 'button_three_double_press'
- conditions:
- '{{ command == ''1_hold'' }}'
sequence: !input 'button_one_long_press'
- conditions:
- '{{ command == ''2_hold'' }}'
sequence: !input 'button_two_long_press'
- conditions:
- '{{ command == ''3_hold'' }}'
sequence: !input 'button_three_long_press'
Subzero
(Dan)
March 25, 2022, 3:12pm
2
This blueprint no longer seems to work, it allows me to select the TS0043 device and assign actions etc, but nothing actually happens when I press a button on the remote.
I tried stepping though the action and got this error:
xecuted: 25 March 2022, 14:57:19
Error: UndefinedError: 'dict object' has no attribute 'to_state'
I too get the same result.
dwr
(David R.)
May 11, 2022, 1:47am
4
I got this working in Node-Red. I was after each of the 3 buttons to select a preset Philips Hue Scene controlling 7 x rgb ceiling lights, each button can cycle through multiple scenes. Uses the Home Assistant and HueMagic nodes. Works good (wife friendly) about 1 second delay needed between presses and am yet to do anything with the double or long press options.
samart45
(Samart)
June 7, 2022, 3:43am
5
I use Tuya TS0043.
I got error message.
I remove attribute: action from trigger.
It’s work for me!!!.
blueprint:
domain: automation
input:
switch:
selector:
entity:
integration: mqtt
domain: sensor
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
mode: restart
- platform: state
- variables:
- choose:
- conditions:
- conditions:
- conditions:
- conditions:
- conditions:
- conditions:
- conditions:
- conditions:
- conditions:
Does this work now?
I had it initially seemed to be able to add the device to automation. Didn’t work tho.
Tried yours and the top version.
WHere do you see that debug log?
It seems to be working on and off. Will continue testing.
Just doesn’t work half the time. Same button pressed, 10s apart
and
Sometimes this error
(script.aircon_power) turned off
Stopped because of unknown reason "null" at November 7, 2022 at 11:19:26 PM (runtime: 1.51 seconds)
No idea, since it’s finished
I have exactly the same problem as
aussie1497
the button returns ’ ’ instead of returning 1_single.
It randomly returns either nothing or 1_single
o.pitsenko
(O Pitsenko)
October 29, 2023, 6:14am
11
Same problem, same symptoms, how to return to normal performance?
SkylightXD
(Skylight Xd)
November 15, 2023, 6:46am
12
I got it
If you are using Zigbee2MQTT, you do not need an attribute as the status is transmitted directly by the sensor.
I have commented out the attribute line and reloaded the yaml files.
Now it works!
okkies
November 26, 2023, 5:07pm
13
i dont know what you mean with anything you said, but i do know i need to do thos…
So what did you do ?
Is there any way to reduce the amount of time the hold action takes to register? It’s like 3 full seconds when just natively used by Zigbee2MQTT without a blueprint. Pretty cumbersome.
jolypas
(JoPas)
April 1, 2024, 8:21am
15
Hello
I have the model 3 with covers buttons ( up, down, stop)
I never successed to make this blueprint working even with modifications suggested into this thread
I used this one instead and it work fine (I don’t use the button 4)
This Blueprint allows you define the actions to be taken when perform a single click, double click or hold on the Tuya 4-Button Remote Switch (TS0044_1). This blueprint works with Zigbee2MQTT only.
The remote can purchased here .
[Tuya_TS044]
blueprint:
name: Tuya Zigbee 4 button remote
description: "Blueprint for use with Tuya Zigbee 4 button remote (TS0044_1) on Zigbee2MQTT"
domain: automation
input:
switch:
description: Tuya Zigbe…
Jubii This worked a day. Now I have the same problem with Error: UndefinedError: ‘dict object’ has no attribute ‘to_state’.
I have to admit I am not a programmer so I am stealing from you clever people. So I can’t troubleshoot anything around the code myself.
I were surprised it worked in the first place because I read about how to implement unsupported devices specially from Tuya into mqtt2Zigbee and that was very technical.
Cheers
scad-ds
(scad-ds)
April 27, 2024, 6:47pm
17
Hey folks! I’ve faced with strange behaviour of this blueprint.
The first action triggers okay, but all the next fail or cancel.
I’ve made a little debug session and figured out what it was.
The problem is related to mode: restart property.
Since the action of this switch goes in part with an empty one, this empty action restarts the first execution.
To fix this issue I just changed it to the queued value and the issues are gone.
Maybe it will help someone and save some time
This blueprint stopped working after some breaking changes in Zigbee2MQTT 2.0.0 Zigbee2MQTT 2.0.0 breaking changes · Koenkk/zigbee2mqtt · Discussion #24198 · GitHub
Would be nice if there is a workaround or update.
Update:
You have to add legacy_action_sensor: true to your configuration.yaml file from zigbee2MQTT.
the path is /homeassistant/zigbee2mqtt/configuration.yaml
homeassistant:
and don’t forget to restart the Zigbee2MQTT addon.
Hey, would you be able to explain this in detail please. I’ve been trying via importing the blueprints, but to no avail… TIA.
Hey, I decided to rewrite the blueprint for the latest HA version, considering that I use the ZHA integration:
blueprint:
name: ZHA - LoraTap SS600ZB / Tuya TS0043 3-Button Remote
description: >
Automate the LoraTap SS600ZB / Tuya TS0043 3-button Zigbee remote
through ZHA. Supports single, double, and long press for buttons 1-3.
domain: automation
author: stupid_copilot
source_url: https://community.home-assistant.io/t/zigbee2mqtt-loratap-ss600zb-tuya-ts0043-3-button-wireless-switch/301273
input:
remote:
description: Select the LoraTap / Tuya TS0043 remote paired with ZHA
selector:
device:
integration: zha
button_1_single:
name: Button 1 - Single press
default: []
selector:
action: {}
button_1_double:
name: Button 1 - Double press
default: []
selector:
action: {}
button_1_long:
name: Button 1 - Long press
default: []
selector:
action: {}
button_2_single:
name: Button 2 - Single press
default: []
selector:
action: {}
button_2_double:
name: Button 2 - Double press
default: []
selector:
action: {}
button_2_long:
name: Button 2 - Long press
default: []
selector:
action: {}
button_3_single:
name: Button 3 - Single press
default: []
selector:
action: {}
button_3_double:
name: Button 3 - Double press
default: []
selector:
action: {}
button_3_long:
name: Button 3 - Long press
default: []
selector:
action: {}
mode: queued
max: 10
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
variables:
command: "{{ trigger.event.data.command | default('') }}"
endpoint_id: "{{ trigger.event.data.endpoint_id | int(0) }}"
cluster_id: "{{ trigger.event.data.cluster_id | int(0) }}"
condition: []
- choose:
- conditions:
- condition: template
value_template: "{{ command == 'remote_button_short_press' and endpoint_id == 1 }}"
sequence: !input button_1_single
- conditions:
value_template: "{{ command == 'remote_button_double_press' and endpoint_id == 1 }}"
sequence: !input button_1_double
- conditions:
value_template: "{{ command == 'remote_button_long_press' and endpoint_id == 1 }}"
sequence: !input button_1_long
- conditions:
value_template: "{{ command == 'remote_button_short_press' and endpoint_id == 2 }}"
sequence: !input button_2_single
- conditions:
value_template: "{{ command == 'remote_button_double_press' and endpoint_id == 2 }}"
sequence: !input button_2_double
- conditions:
value_template: "{{ command == 'remote_button_long_press' and endpoint_id == 2 }}"
sequence: !input button_2_long
- conditions:
value_template: "{{ command == 'remote_button_short_press' and endpoint_id == 3 }}"
sequence: !input button_3_single
- conditions:
value_template: "{{ command == 'remote_button_double_press' and endpoint_id == 3 }}"
sequence: !input button_3_double
- conditions:
value_template: "{{ command == 'remote_button_long_press' and endpoint_id == 3 }}"
sequence: !input button_3_long
default: []
Hope this helps if anyone was still struggling.
