Zigbee2mqtt: show the networkmap in home assistant
Hi! I am still confused where to copy the files extracted from the zipfile.
Should all folders and files be copied to /config/custom_components/zigbee2mqtt_networkmap included the www folder?
OR
only the 3 files to /config/custom_components/zigbee2mqtt_networkmap and the files and folders in the www folder from zip file to the /config/www ?
Edit: i installed Zigbee2MqttAssistant instead 1 click after add repository url, add username & password then finished :slight_smile:
It is in the first post.
Is it possible to change the line length? Basically spacing - everything is widely spaced and some devices spill beyond the frame. Thanks.
  • I have installed ha_zigbee2mqtt_networkmap with HACS.
  • I have modify configuration.yaml with the webhook from tutorial.
  • I have restart HASSIO.
    No errors in log.
But : in development tools services i haven’t the new service zigbee2mqtt_networkmap.update (service not found)
Have you an idea ??
Resolved :slight_smile:
How did you resolve this?
-I have installed ha_zigbee2mqtt_networkmap with HACS.
-I have modify configuration.yaml with the webhook from tutorial.
-I have restart HASSIO.
But I don’t see zigbee2mqtt_networkmap.update service
and don’t see any changes on my UI
Thats helpful!
Hey guys,
I’m having a 404: Not Found when I click on the iframe
this is the config yaml
webhook:
zigbee2mqtt_networkmap:
panel_iframe:
  networkmap:
    title: 'Zigbee Map'
    url: '/local/zigbee2mqtt_networkmap/map.html'
    icon: 'mdi:graphql'
I run zigbee2mqtt_networkmap.update from services but still nothing
I originally kept the www folder inside the zigbee2mqtt_networkmap custom folder which didn’t work.
Then I moved the files inside the www folder to the default config/www folder and still not working
In hassio situation ‘local’ is ‘www’ folder inside ‘config’ folder, so the config in this thread assumes your map.html should be located in:
/config/www/zigbee2mqtt_networkmap/map.html
so basically just copy everything from www folder in the zip from github to /config/www/zigbee2mqtt_networkmap/
i can’t get it show me the map myself but at least I’m not getting the 404 :slight_smile:
Thank you @highway! It’s now partially working :smiley:
I run the update from services, there are no errors in HA log
but I still get a blank map with just this down the bottom
Edit: I don’t know if this is related here but it’s new to me
ERROR (MainThread) [homeassistant.core] Error doing job: Unclosed connection
I’m using Chrome
Sorry guys, I’ve been really busy the last few months. I just committed some tweaks from codewise-nicolas.Please check if your problems are still present.
I had no problems before but after I installed the update now I get a blank page when opening the map.
HA says this:
…but my config is exactly what the readme file says, even including the comment:
  #topic: your topic (optional, default zigbee2mqtt)
panel_iframe:
  networkmap:
    title: 'Zigbee Map'
    url: '/local/community/zigbee2mqtt_networkmap/map.html'
    icon: 'mdi:graphql'
I installed it through HACS if that makes any difference.
Edit: Ah, turns out the update script failed because I had already moved a file manually after the addon initially didn’t do that by itself:
2020-03-30 18:15:16 ERROR (MainThread) [homeassistant.setup] Error during setup of component zigbee2mqtt_networkmap
File “/usr/local/lib/python3.7/distutils/dir_util.py”, line 70, in mkpath
os.mkdir(head, mode)
FileExistsError: [Errno 17] File exists: ‘/config/www/community/zigbee2mqtt_networkmap/viz.js’
File “/usr/src/homeassistant/homeassistant/setup.py”, line 170, in _async_setup_component
hass, processed_config
File “/config/custom_components/zigbee2mqtt_networkmap/init.py”, line 25, in async_setup
copy_tree(fromDirectory, toDirectory)
File “/usr/local/lib/python3.7/distutils/dir_util.py”, line 159, in copy_tree
verbose=verbose, dry_run=dry_run))
File “/usr/local/lib/python3.7/distutils/dir_util.py”, line 135, in copy_tree
mkpath(dst, verbose=verbose)
File “/usr/local/lib/python3.7/distutils/dir_util.py”, line 74, in mkpath
“could not create ‘%s’: %s” % (head, exc.args[-1]))
distutils.errors.DistutilsFileError: could not create ‘/config/www/community/zigbee2mqtt_networkmap/viz.js’: File exists
After removing that file it works again.
I’m sorry, but these installation directions are just terrible. So many steps and details missing…
I’ve FINALLY gotten the iFrame to work and got rid of my 404 error. Now I’m trying to set up the Automation to call the service every 10 minutes. Guess what? The service “zigbee2mqtt_networkmap.update” doesn’t appear to exist. What non-existent step did I miss?
I take it you are volunteering to document it. Well done.
If I could ever get it to work, sure…
Well post a proper request for help then. See How to help us help you - or How to ask a good question
Out of interest, what steps do you think are missing?
The steps on where to extract the files from the zip archive are unclear. You’ll see that several people had the 404 error because of this.
Second, what prerequisites are necessary? When I installed the integration through HACS, made the change to the configuration.yaml file, extracted the zip, and restarted HA I received a notification on startup that mqtt and Zigbee2mqtt were invalid and as I mentioned there was no Zigbee2mqtt service to create an automation for. Am I supposed to install mqtt somehow first?
I apologize if I came off as rude but I’m new to HA and as I dive in I’m finding that a lot of assumptions are made that people know all these things. I understand this is more complicated and involved than say SmartThings, but it is difficult and a little frustrating. It’s kind of a theme across the Linux community in general.
Finally, the code snippets provided for the configuration.yaml won’t work if you simply copy and paste as the indentions are off. At least it threw an error for me until I fixed the spacing.
Well quite clearly you’ll need zigbee2mqtt before you even begin to show the zigbee2mqtt network map. You cannot see the network map of something you don’t have!
And yes zigbee2mqtt needs mqtt.
Perhaps you misunderstood what this custom component does?
Ok, I wanted to give this a try.
TL;DR: in 5 minutes I had this:
HOWTO
This is my system:
arch	x86_64
dev	false
docker	true
hassio	true
os_name	Linux
os_version	5.3.0-28-generic
python_version	3.7.7
version	0.107.6
virtualenv	false
My prerrequisites:
My steps:
1.- Search zigbee2mqtt in the Integrations tab in HACS:
2.- Click install (the screenshot shows reinstall because I’m writing this howto after installing it):
3.- I added this to my configuration.yaml :
  topic: zigbee2mqtt
panel_iframe:
  networkmap:
    title: 'Zigbee Map'
    icon: 'mdi:graphql'
It’s the same as in the instructions in the add-on but, as @cdef said, the indentations are off.
4.- Restart HA
5.- Go to Developers tools and run the zigbee2mqtt_networkmap.update service:
6.- Enjoy the map clicking in the sidebar:
Thanks to all the people that make this possible.
See, you mention these things that are “obvious” but how is someone new supposed to know what is actually being installed through HACS? I have no idea what zigbee2mqtt or MQTT are until I tried to get this map working to troubleshoot my zigbee mesh.
