Iāve just found out about this blueprint as Iām looking to send notifications when people leave/arrive any declared zone without having to list them all in an automation.
My issue is, I donāt want to send notifications to devices but rather call the Telegram service to send notifications there. I read in this page that there is supposed to be a ācustom actionā section but I cannot find it after importing the blueprint. The only actions there seem to be are āDevice to notifyā and āNotification Groupā or did I miss something ?
Than you for all the work you have done in this excellent Blueprint.
I would like to know how to verify the version I have installed in my HA, and Iām case to be necessary, how to update?
Greetings
How would I use the blueprint to add two buttons to the notificationsā¦ One to open /todo?entity_id=todo.shopping_list and the other to just close the notification.
Basically I want to set up the local shopping centers as zones, then when my GF or I enter that zone, there will be a āShopping List Reminderā notification with a button to open the list and one to ignore the notification.
Iāve re-imported the blueprint and now I see them. Iām not quite sure how I got the wrong version in the first place (I did import multiple times). Maybe Iām just blind ^^ Thanks for the quick reply!
The automation works great thank you !
Question: is there a way to have some kind of selector for all zones instead of having to enter them one by one ? I would like to send enter/leave notifications for all registered zones in such a way that if I create a new zone it is automatically taken into account by the automation. Is this possible ?
Thanks a lot,
Feature Request:
Your Blueprint works quite well for my use case with 1 small exception. (Church)
I use it to vibrate my phone when in a quite zone and return the ringer to normal on exit.
I have a couple of additional tasks Iād like to automate re. Church and a trigger_id equating to the zone entered or left would be quite helpful. Iām aware I could capture the zone count for the entering portion & employ a helper to save the entered zone for the departing bit. The trigger_id just seems much cleaner & may well prove quite useful to others.
Iām too much of a noob to be clear about the level of effort this might require, so no problem if it is out of scope.
Thanks for creating & maintaining this.
Is there a way I can toggle this to send a critical alert again? (only for a certain automation not the entire blueprint?)
I have two automations one is just entering/exiting all my zones which is for normal notifications and my goal is to have a separate automation that send a critical alert to my wife when I arrive to pick her up at one singular zone
I tried manually configuring the automation but was not able to figure it out has anybody successfully done this?
Did you check your person entity in logbook if the state changed correctly corresponding to the defined zones? That means is your tracking working properly?
Also try a minimal version first without any conditions. So just define persons and zones and if it works for you add your conditions and actions successively.
Did I understand correctly that the āDurationā parameter also affects leaving the zone? If Iām right, it might be convenient to make separate settings for āArrivingā and āLeavingā.
You donāt need a custom action for the notification. Could you check if the automation got teiggered? If yes can you share the trace log? You can simulate a leaving by setting the state of a person in dev tools from home to something else.
