It minimizes when you click on the main window somewhere. Annoying but at least you can survive until the front end devs find out why the code that should prevent expansion of the left menu does not work.
The click on main window trick works both on Safari and Chrome on iPad
hmmm. When testing config.
[05:52:02] INFO: Installing Home Assistant: latest...
[05:52:02] INFO: Please be patient, this might take a few minutes...
[05:52:33] INFO: Installed Home Assistant 0.96.0
[05:52:33] INFO: Don't worry, this temporary installation is not overwriting your current one.
[05:52:33] INFO: Making a copy of your configuration for checking...
[05:52:33] INFO: Checking your configuration against this version...
[05:53:06] ERROR: The configuration check did not pass!
[05:53:06] ERROR: See the output below for more details.
INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /tmp/config
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20190717.1
INFO:homeassistant.util.package:Attempting install of netdisco==2.6.0
INFO:homeassistant.util.package:Attempting install of mutagen==1.42.0
INFO:homeassistant.util.package:Attempting install of distro==1.4.0
INFO:homeassistant.util.package:Attempting install of sqlalchemy==1.3.5
INFO:homeassistant.util.package:Attempting install of pyupdate==1.4.0
INFO:homeassistant.util.package:Attempting install of pyvera==0.3.2
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.7.0
Failed config
General Errors:
- Platform not found: device_tracker.unifi
- Platform not found: climate.smartir
Successful config (partial)
Oof, ok. That’s a shame - I use that far more than any other feature on Hive. Generally haven’t got the need to boost the heating in the middle of summer. ![]()
For people having issues with SSL like this:
ImportError: /usr/lib/arm-linux-gnueabihf/libssl.so.1.1: version `OPENSSL_1_1_1’ not found
(Like @ZioTitanok, @Ernst, @skaker1, @mig2008pt)
I’ve posted an extensive answer on the GitHub Issue:
did you get a reply?
Delighted to get battery sensors for ZHA, but I’ve lost the temperature sensors that were part of my Xioami magnet and motion sensors.
I still see them listed under each device in Configuration > Integrations > ZHA, but there’s no icon next to them, nothing happens when I click them, and I can’t select them as an entity in States.
maybe of help
Aha! The last one seems to be the key - removed intentionally because they were inaccurate. I could swear they were still there yesterday, before I updated to 0.96. Pretty sure I was on 0.95…! Oh well!
Thanks!
They botched it again.
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 121, in handle_call_service
connection.context(msg))
File "/usr/src/homeassistant/homeassistant/core.py", line 1150, in async_call
self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1172, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 194, in handle_service
required_features
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 316, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 337, in _handle_service_platform_call
await getattr(entity, func)(**data)
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 399, in async_set_preset_mode
self.set_preset_mode, preset_mode)
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 394, in set_preset_mode
raise NotImplementedError()
NotImplementedError
Hi !
I upgraded my home assistant instance (Hassbian) from the version 0.94.4 to 0.96, and the “cloud” integration with nabu casa is broken.
I got the following stack trace in home-assistant.log…
Copy to clipboard
ERROR (MainThread) [homeassistant.setup] Error during setup of component cloud
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 153, in _async_setup_component
hass, processed_config)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/cloud/__init__.py", line 142, in async_setup
from hass_nabucasa import Cloud
File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 16, in <module>
from .remote import RemoteUI
File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/remote.py", line 16, in <module>
from .acme import AcmeClientError, AcmeHandler
File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/acme.py", line 9, in <module>
import OpenSSL
File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/crypto.py", line 16, in <module>
from OpenSSL._util import (
File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/_util.py", line 6, in <module>
from cryptography.hazmat.bindings.openssl.binding import Binding
File "/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 15, in <module>
from cryptography.hazmat.bindings._openssl import ffi, lib
ImportError: /usr/lib/arm-linux-gnueabihf/libssl.so.1.1: version `OPENSSL_1_1_1' not found (required by /srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so)
With this error, the connection with Nabu Casa is not done…
Anyone can help me with this one ?!
Thanks !
The fix was posted here:
Yes, read the thread, it is covered.
And only 6 posts above your own.
Seems the MP1 broadlink switches are still broken with this release. Was first broken in 0.94
I confirm the fix above for the SSL issue works for an hassbian install.
Cheers
I have the same ImportError about OPENSSL_1_1_1.
Did you try the posted solution?
use this custom integration, works perfectly
What other logs would you sugest?
@aneisch, I’ve restarted a few times now, and I’m still seeing the same warning about device_tracker.nmap_tracker in the Hassio config checker (v2.2).
If you’ve already upgraded to 0.96, is the nmap tracker still working?
Thanks.
Not sure if this is a 0.96.1 issue or something else strange going on but since updating I can’t change one of my Yeelights colour / temp / brightness with HA. I get the following errors (it goes offline after trying to change the settings too many times:
2019-07-19 16:36:31 ERROR (SyncWorker_2) [homeassistant.components.yeelight.light] Error when calling <function YeelightGenericLight.set_brightness at 0x7f3f262d6440>: {‘code’: -1, ‘message’: ‘client quota exceeded’}
2019-07-19 16:36:31 ERROR (SyncWorker_2) [homeassistant.components.yeelight] Unable to update device 192.168.0.42, Bedroom Lamp: {‘code’: -1, ‘message’: ‘client quota exceeded’}
I updated to bulb firmware hoping that would resolve it but it’s no different. What points me to HA is that the bulb works fine when controlled by the Yeelight app on my phone
