Sorry, I’m new in iOS, where I can find information about it? Or maybe the name of this feature?
It will be released once it is ready for prime time.
Apple KB probably or iOS manual.
This link might help explain it.
I recall reading that with iOS 12 it will be possible to have “emergency” notifications that can penetrate mute/DND, and that it was planned to implement this in the HA app. Did that happen in this version? Or is that still a future thing?
I have a problem I’m trying to solve because of the inability to pierce Apple’s mute/DND, and having this in the HA iOS app would make things much, much, easier… I’m working on some circuitous workarounds that could just be eliminated.
Thanks.
The feature you’re referring to is Critical Alerts in iOS 12. I think this feature for the iOS Home-Assistant app will be released after v1.5.0.
More details here
Just a quick question - I have read the thread and can’t find the answer, so apologies if I have missed it.
My HA (not hass.io) 0.84.6 is not exposed to the internet in anyway. I connect to it externally via a VPN to my router on my iPhone. The webpage works great through the VPN, but the iOS app won’t connect at all. Is this by design?
Not sure if it’s been reported or not, but the “iOS Components” show as X (not loaded) on the beta client.
I have tick marks next to all three. You may have a configuration problem.
Try hard exiting the app and then running it again… it will then show ticks.
Thanks, that worked. Specifically the power off screen-home button holding method. Simply swiping up did not work, which I had already tried.
What are you using for the connection URL? Is it the internal IP address of your HA server?
If you’re using a hostname, that might not resolve over the VPN. Try using the IP address while connected to the VPN.
Tried a couple of things - IP address in external, internal and both and even put a DNS forwarder on LAN of MarkHA.co.uk that works internally and externally on the webpage in safari, but not in the app.
Don’t do the “use internal URL” setting. Just use the 192.168.x.x. address of your internal server.
Same
I think there must be something in the app that ignores the VPN and uses the cellular connection?
It can’t ignore the VPN That would defeat the whole purpose of the VPN.
So that exact same URL works when you are on your home net? And that exact same URL works over VPN via your browser via the VPN?
Edit: You don’t need to obscure the 192.168.x.x addresses - they are private, no routable addresses usable from your LAN behind your router only.
Yep works fine in safari via the VPN and locally via app. Just won’t connect over VPN on the app. All other local resources are fine too over the VPN.
As I say, it is app specific as the VPN is fine and all resources available.
I am also aware that 192.168.x.x is a local non routable address - just paranoid I suppose and don’t like giving out my subnet
Interesting…
As a test, I just connected to my LAN from work via OpenVPN. In the iOS app I entered http://192.168.1.8:8123 (my server) and just like you, it did NOT work. I then copied and pasted that URL into my phone’s browser and it did connect.
So it does appear to be bug! I don’t normally use it that way - I have my HA instance exposed (behind a reverse proxy with certs), so I never saw it before…
Thanks for testing it too. At least I am not going mad.
I have toyed with the reverse proxy idea, but I prefer to have all non VPN access locked out from my network. Call me paranoid
I think there is a bug, as I put a local DNS entry in my Draytek router and again it is accessible by name in Safari and VPN, but not in the app. The VPN is definitely using my pihole DNS server as I have a few dummy addresses in it to test.
I’ve just tested this out of curiosity while out and about and it’s working fine here?
I use OpenVPN to my router and have changed the URL connection to my LAN address. Default white theme was presented.
