2022.10 WT$
Didnāt you post this already?
Iād say though that often things are slow on an upgrade to a new version and sometimes a restart is required to get everything running. What is your hardware?
oops yeah you are correct, I did post it, I am on a NUC running Proxmox, I have rebooted several times, rolled back to 2022.9.7 and then upgraded again, this time it worked for a few days then all of a sudden this came up again.
Some strange things are happening to me on this version, donāt generally get issues TBH but Core and ESPHome (bluetooth proxy), going to try 2022.10.2 now and see how we go then roll back for a bit
Hi guys,
Just updated to 2022.10 and wanted to play with Subview feature, but itās not appearing in the menus of existing views or if creating a new one. Is there something else I need to do to enable it or maybe itās not available for some reason?
upd: weird but it appeared a few hours after the update, maybe was cached or something.
Is it just me or do the updates since 2022.10.x take ages compared to before that? Just running 2022.10.2 update on my RPi4 and it again takes more than 5 minutes compared to ~30s before?
I have a Tuya integration for a Floodlight Camera. Since the update, the integration does not have any device. I tried to remove and re-add the Tuya integration but it did not work. Any help please?
Great news on SkyConnect. Tempted to pre-order one directly though living in the Netherlands and seeing current pre-order Partners (Hungary, Norway, Sweden). So the question is whether a local pre-order point is on the horizon?
I wonder what that means?
It says it has removed AND I shall remove a configuration at the same time. - The configuration.yaml
files attribute indicates, that it has not been modified since a week.
And which configuration? All I have with uptime is the docker containers monitored condition.
Die Betriebszeit YAML-Konfiguration wurde entfernt
By the way: It does not make sense to translate every word. Would be easier to understand and to locate, if the Betriebszeit would stay as it is in the configuration file.
It says to remove Uptime from configuration.yaml
and use native integration see documentation.
I understand. I already use the integration:
And I donāt have an uptime in my configuration.yaml
except the one for docker containers and removing that does not solve the problem.
cat *.yaml | grep uptime
# - uptime
itās probably in your sensor.yaml file, make sure you check .yml files too if you decided to use that extension.
Arghā¦ It was in a sensors.yaml
and I now Iāve learned that pasting the error messages text to VS code search does not always work - Uptime
in the error and uptime
in the codeā¦ and the button Match case
was selected.
Thanks.
My Solar dashboard is messed up, negative readings randomly on grid export and one where it thinks I was producing power at midnight
What did you do to resolve it ? Im having the exact same issue
Deleted the custom timer, just utilizing the stock integration now with no issues.
as in removed the timer: from configuration.yaml ?
Ive tried this as well as deleting the timer folder from in the custom_components folder
I dont see any other customer time component I have, thought mine was all the stock integration.
ā¦but your reply was the closest and almost exact same error, so thought id reach out to you.
Use timer in helpers
Ive tried, but its greyed out because of the component failure. I created a separate topic on it here
Ahh ok, I have not upgraded to 2022.10.2 yet, still on 9.7
