And worse, ābreaking changesā is entirely missing. So thisā¦
ā¦ seems like a pretty easy mistake to make for people who are assuming they can just consume this info through the forum posts.
It might be best to change the Discourse plugin to only post excerpts and clearly link to the original until whatever is causing that can be figured out.
From what I can see, the change here is to remove some broken (in the API, not anything that can be done from the HA side) functionality. Is there more to it than that?
in case you missed my question: How can I switch between applications using SamsungTV?
Changelog says this feature has been added but documentation lacks any details about it.
same way every media player does, through play media with media_content_id and media_content_type.
EDIT: Before you ask, youāre going to have to manually switch to these and look at the attributes to figure out what you need to set them as. Every media player is different in that regards.
Thanks for answer.
I was asking because every other SamsungTV integration I know requires manual configuration of list of possible applications. Devs were saying itās not possible to collect app list from TV). Nice if itās the opposite
Every media player works the same way. The only way you can change things are through the play media or the change source service calls. If those service calls donāt accept your inputs, then itās not possible. Iām sure every TV is different, especially seeing that these can have different osās and apps.
But itās not about changing itself. The point is to change app in SamsungTV you have to know itās ID (itās fixed identifier given to each app).
While changelog says changing app is now available for SamsungTV, it doesnāt say where to get those IDs from. And what is more important, where to store them to make them available to select (considering using GUI).
As I said other integrations require to list those app in the integration configuration.
But docs of the official integration donāt mention how to work with that at all
Docs doesnāt even mention changing apps.
I do. But I have no knowledge about core SamsungTV component implementation.
This is why this is me who is asking for details. Once those details will be provided, I can update docs.
