Hi, it seems the image is missing in the Hardware information page:
I think it would nice to have it back. Thank you. Regards, Luis Sismeiro
Speedtest wasnât showing it me either after the upgrade to 202.7.4âŠa second reboot returned it so didnât have to remove and reinstall.
(just in case it helps anyone else)
I just use watchtower now to redeploy the new version each time - advises me by telegram or gotify - redeploys gracefully - debugs and rollsback if any errors occur. polls every 12 hours.
For all of my containers now on proxmox.
I did the upgrade to 2022.7.4 and all went well. I have a T7900 and a T2000.
Install Watchman and it will find them for you. Itâs in HACS.
After 2022.7.4 upgrade I could no longer control any Z-Wave switches (HUSBZB-1). Tried restarting HASS, rebooting the host. No luck. Reverted to 2022.7.3 and everything started working again. I saw no messages in the logs, but I donât have Z-Wave debugging turned on. Wonder if it was just me? Should I try again, or is there a known issue?
P.S. Itâs worth noting that when I tried to do a partial restore (core only) from a full backup with 2022.7.3 in it the system came up and everything looked okay but my /config folder was MIA. I ended up doing a full restore and everything looked fine.
2022.7.4
Cannot create a simple template sensor:
template:
- sensor:
- name: testing_123
state: "123"
What is going on?
Restart HA does not help.
No any corresponding messages in a Log.
Also I cannot create a simple âinput_booleanâ:
input_boolean:
testing_boolean:
Update: found a reason.
I specified a sensor & input_boolean in a âtest.yamlâ file.
The file was located in some subfolder like ânetwork/tracker/compositeâ.
But - I also had a âtest.yamlâ file in a different location.
So the 2nd âtest.yamlâ file was just ignored w/o any error messages.
Thanks mate. I have used that before. Totally forgot about it.
Hi HA family,
I have had no issues with updates for years. However now trying to move from 2022.6.7 to that 2022.7 and get these errors.
The error from logs is:
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 411, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 301, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy
My setup is :
Version | core-2022.6.7 |
Installation Type | Home Assistant Supervised |
Development | false |
Supervisor | true |
Docker | true |
User | root |
Virtual Environment | false |
Python Version | 3.9.12 |
Operating System Family | Linux |
Operating System Version | 5.4.0-113-generic |
CPU Architecture | x86_64 |
Timezone | Australia/Sydney |
Host Operating System | |
Update Channel | stable |
Supervisor Version | supervisor-2022.07.0 |
Agent Version | |
Docker Version | 20.10.17 |
Disk Total | 101.7 GB |
Disk Used | 69.0 GB |
Healthy | Unhealthy |
Any assistance would be appreciated so I can update.
Thank you.
You need to set HA to ignore the unhealthy condition (or fix it) What does more info show? Why is it unhealthy?
This command:
ha jobs options --ignore-conditions healthy
Will make it ignore unhealthy but if possible fix it. In my case Iâm already unsupported as I run other docker containers on the host so I thought screw it Iâll start using watchtower again to keep them up-to-date so I was unhealthy as well. But everything working perfecthealthy not causing any problems.
Hi @DavidFW1960 ,
Firstly, I need to thank you for your posts and config on BOM weather. Was a massive help getting me up and running. Champion.
What the detailed logs give me (forgive me, some of what is says is way over my understanding):
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:301
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: July 8, 2022 at 4:18:34 PM (17 occurrences)
Last logged: 10:34:49 AM
[140174564369840] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy
[140174563626528] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy
[140174648281600] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy
[140174564733424] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy
[140174763924832] Error updating Home Assistant Core 'HomeAssistantCore.update' blocked from execution, system is not healthy
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 299, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 47, in _wrapper
raise HassioAPIError(data["message"])
homeassistant.components.hassio.handler.HassioAPIError: 'HomeAssistantCore.update' blocked from execution, system is not healthy
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 193, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1704, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1741, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 680, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 964, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 717, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 152, in async_install
await entity.async_install_with_progress(version, backup)
Does that give any clear clues as to the culprit?
Otherwise, I might try that ignore setting.
Thank you again.
At the top of system health you will see this:
Click Learn More and you might get a hint.
Mine says
The supervisor log shows
22-07-15 10:56:28 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-07-15 10:56:28 ERROR (MainThread) [supervisor.resolution.evaluations.container] Found image in unhealthy image list 'v2tec/watchtower' on the host
22-07-15 10:56:28 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-07-15 10:56:28 CRITICAL (MainThread) [supervisor.jobs] The following job conditions are ignored and will make the system unstable when they occur: {<JobCondition.HEALTHY: 'healthy'>}
I have the following:
22-07-15 09:43:07 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-07-15 09:47:50 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
22-07-15 09:52:52 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
22-07-15 09:57:54 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
22-07-15 10:02:56 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
22-07-15 10:07:58 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
22-07-15 10:11:15 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-07-15 10:13:00 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
22-07-15 10:18:02 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
22-07-15 10:19:21 WARNING (MainThread) [supervisor.jobs] 'HomeAssistantCore.update' blocked from execution, system is not healthy
22-07-15 10:23:04 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
22-07-15 10:28:06 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
22-07-15 10:30:17 WARNING (MainThread) [supervisor.jobs] 'HomeAssistantCore.update' blocked from execution, system is not healthy
22-07-15 10:33:08 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
22-07-15 10:34:49 WARNING (MainThread) [supervisor.jobs] 'HomeAssistantCore.update' blocked from execution, system is not healthy
22-07-15 10:38:10 WARNING (MainThread) [supervisor.addons.options] Option 'vnc_password' does not exist in the schema for deCONZ (core_deconz)
Iâm today old (thanks to you) for learning there is a supervisor log section.
From this, iâm lead to believe there is something in the deconz vnc password. ill have to look into that a bit more what has happened.
You concur on that path?
Thanks mate
What do you see if you click on privileged?
Brings me to here:
âThe Supervisor needs to have privileged access to the docker runtime on your host to be able to do everything it needs to do.â
Im running on:
System: Host: automationhub Kernel: 5.4.0-113-generic x86_64 bits: 64 compiler: gcc v: 7.5.0
Desktop: MATE 1.22.2 wm: marco dm: LightDM Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Machine: Type: Desktop System: Intel Client Systems product: NUC7i3DNKE v: J57829-510
serial: Chassis: Intel Corporation type: 3 v: 2 serial:
Mobo: Intel model: NUC7i3DNB v: J57625-510 serial: UEFI [Legacy]: Intel
v: DNKBLi30.86A.0056.2018.1003.1513 date: 10/03/2018
Iâve done -apt update and upgrade many times over. There is nothing left to update on the host.
Hmm. So you need to run the container in privileged mode?
Not sure how you would do this given itâs a supervised installation. That should be automatic when you installed. Do you have the HA agent installed? Have you tried running the installation script/package again?
Also see this thread
Seems they also say re-run installation
Inevitably this will bring problems as supervised is only supported on debian 11.
True but supported is a moving target these days becoming increasingly narrow all the time. I stopped chasing it a long time ago.
Hi guys,
Reading through the thread @DavidFW1960 shared.
I did âsudo docker restart hassio_supervisorâ on host terminal, went back to HA and attempted update which it did successfully.
I have NOT restarted host or HA and now have a Healthy supervisor and updated to the latest.
From the convo, I take it not to always expect this outcome, but for a reason (of which I do not know), simply restarting hassio_supervisor and then updating via HA GUI did the trick.
Thank you for your responses, support, and feedback. I learned some new things today.
Much appreciated.
2022.7.5 is out, but the the release note is missing.
