Do not tell wrong things: Groups via yaml are still alive!
Groups can be defined in YAML, do not belive who is telling different things.
The issue is caused by new version of File editor
Thank you for the information. Iāll join git.
Great update again guys!
I tried setting up one of my esp32ās as a bluetooth proxy by adding the lines below to the esphome config:
esp32_ble_tracker:
bluetooth_proxy:
I get this error when validating the code. Thoughts anyone?
INFO Reading configuration /config/esphome/esp32u_contact.yamlā¦
Failed configbluetooth_proxy: [source /config/esphome/esp32u_contact.yaml:22]
Component not found: bluetooth_proxy.
The feature isnāt out to stable yet, youāll need to use the dev version to use the feature until that is released
Does this update allows Bluetooth devices to be tracked via device.tracker.ABCD? Iām still on 2022.6.0 because I need this functionality.
Strangeā¦they have it documented in the 2022.9 release notes. There is no mention that a Beta version of anything is needed.
yeah saw that, but do you not config them now using the Group Platform (under lights, switches, etc) rather than all under one Groups: area of your configā¦am I totally misreading this?
(Slightly off topic hereā¦apologies )
Super nice! Congrats to those involved
Not sure if this is the right place, but wouldnāt it make sense to add a consolidated dashboard to monitor the hardware instead of 3 separate entries?
You can still do both. There are still legacy groups (which I still use for some things).
āGroup - Home Assistantā
Cheersā¦I did away with my legacy groups, thought they were deadā¦thanks for explaining
Many thanks for that awesome release! Really love it.
One question (maybe Iām just too dumb): How can I use ānext_eventā of a schedule in a template? Donāt know if the datetime format is so special but Iām just getting error messages when trying to use it.
Found the issue in the Release live chat. Somehow my version of ESPhome fell way behind and never prompted me to update. I was on 1.17.x and the latest version was 2022.8.3.
Had to uninstall my addon and reinstall the latest production version. All works now (no dev version necessary).
Thanks team, it has been a nice and useful beta, and now a very smooth release update. really nice.
trying to figure out the BT proxy (because the regular bt tracker no longer works, and le tracker finds 230 devices in an hour or 2, all carkits passing by apparentlyā¦)
New BT integration does nothing either, other than find the MiniPCās own bt hardware.
could we use the ESP device we ran the Matter workshop on some time ago? Espressif ESP32-C3-DevKitM-1
Its laying around useless now, but if that could be done, it would actually be a great tool, to finally be able to track the handhelds and tablets again?
also:
seems the release pushed the processor usage even up a bit more than the beta. went from 16 (2022.8) to 18.5 (in beta) and now see 20 + steady (in release)
Awesome update, thanks for doing great work!
I second that.
Happy B-day, great release, again.
Thanks guys!
Zha backup
Hi
So if I updated my tubes coordinator firmware and it lost all network settings.
What would be the process to restore it to itās previous state?
Would I just click on migrate in zha and follow the steps?
Thanks in advance.
