hi, I’ve already created feature requests for these kind of changes:
Does anybody alse have a weird issue with the energy dashboard with the new 2023.11.0? My shows only on half of the screen:
Wait what? I didnt’t even think about monitoring my MC server via HA Great catch!
It’s a bug in card-mod
Yes, I also missed the beta, but look how after the release update, the restarts show 0. thats really impossible and must be a bug?
Also, I wonder why those 100% spikes are there now, never seen before. What would have changed in 2023.11 to suddenly go 100%? Seems a bug too if you ask me
might need to set the purge to a bit longer period (now using 5 days). isnt the LTS supposed to show after that?
I don’t think it’s a bug because I don’t have 100% spikes. I have ~80% spikes, meaning it’s grabbing the information. You just have less processing power. Outside that, the processor use is less erratic. The 0 is most likely coming from the restart.
and fixed already in the latest update
In understand all of that, but what I am saying is that something changed in HA 2023.11, to make the limits show 0 and 100.
Nothing else changed on this side, except updating to release.
I did look for a system monitor PR, but couldnt find it. So this is really unaccounted for as far as I can see now, and a breaking change more over.
In what world is this a breaking change? How do you know that it reporting correctly before? There were optimizations that were made. Nothing in system monitor changed. This is most likely more accurate due to the increase in startup speeds.
I have restarted 4 times last 24hrs, assume thats the 100% spikes, there are lots more then 4 zero readings
I didnt spot this post before: 2023.11 To-do: Add release title - #90 by starob
sorry for that, otherwise I would have replied to that, to keep things tidy.
Yes, and I have 0 readings well before this update.
That whole section has 0 readings for ~5 days. This is nothing new. It may just be int rounding when your processor reads between 0 and 1, which is entirely possible.
Here’s september
Node Red defined sensors don’t show up in 2023.11
my lowest lower limit has been 7% since the last 6 months, so this 0% has never happened in my system.
Also, I have an automation auto restarting when the upper limit crosses 80 % (which happened before because of the loop), so I can also be I am certain 100% has never happened either.
anyways, I filed an issue, and hope this can be investigated
I did the same, but i still get the icon in the sidebar. Only way to remove it is going to the user profile and edit the sidebar.
These trends are 100% normal, especially when things are optimized. And your automation to restart above 80% is just foolish. If you’re trying to catch memory leaks, you should watch memory not your processor. There’s endless reasons why a computer will choose to use as much processor as it can and many of these reasons are not detrimental to the system.
Thanks for the response, In this case I am the author and already tried Default of ''
however it returns this when trying to save the automation
Can you create a separate thread and post the blueprint?
A separate error thread? the blueprint itself already has a topic I can link
You probably don’t want to pollute your BP thread w/ issues. But that’s up to you. Creating a new topic takes 5 seconds.
