Setup failed for custom integration ecowitt: Unable to import component: cannot import name ‘async_get_registry’ from ‘homeassistant.helpers.entity_registry’ (/usr/src/homeassistant/homeassistant/helpers/entity_registry.py)
Its still using the old registry methods that were deprecated in Feb 2021. The code needs to be updated to use async_get instead of async_get_registry. Please open an issue with the custom component.
Yup. Did the upgrade and every phone and tablet in the house went mental as all the entities were dropped. Then mental again when I added them again. And now every person is mental as all their routines are broken since dropping the entities also stripped them out of the routines. So they all need to be set up again. Bit of a pain to say the least…it’s year of the voice alright…but all the voices here have an annoying high pitched whine…
Updated and my ELKM1 and Notion integrations failed. No amount of restart/reboots seems to fix them and nothing in breaking changes about those. Reverted to 2023.4.5 and all working again. Will update and grab diagnostics on my next try.
I had a strange issue on my Intel NUC running HAOS. I have my data on an attached NVMe, copied there using the HA function in the settings menu.
Right after the update and running the new version, I got this scary message. Not sure what to do:
REPAIR ISSUE
{reference} is a filesystem with the name ‘hassos-data’ and is not the active data disk. This can cause Home Assistant to choose the wrong data disk at system reboot.
Use the fix option to rename the filesystem to prevent this. Alternatively you can move the data disk to the drive (overwriting its contents) or remove the drive from the system.
Actually @pvizeli is the codeowner of the HA Ecowitt integration. The author of the custom one, @garbled1, has not updated the integration since 2021, and it is really unlikely that he will update it now. So many PRs and issues already waiting for approvals and fixes… So the only way forward really is to migrate to the official one.
Edit: As a fair warning, migrate to the official one before updating to 2023.5, because the integration cannot be removed on 2023.5 for the same reason why it fails.
Ok, I am now very confident that 2023.5 broke my Apple TV integration.
Once I saw the new voice features last week, I tried to get my hands on it before the official release but the minute I had it running, my Apple TV integration stoped working and couldn’t get it to work no matter what I tired. restored from a day old back up and waited till today for the official release. But… as soon as I installed the new update, Surprise Surprise! my Apple TV integration died again!
Does anyone can provide some information about non NabuCasa Cloud Google Assistant ?
I expose my devices to Google Assistant through Yaml, will this continue to work ? Does the new UI works with it ? Will overwrite it ?
I will wait before upgrading to be sure that will not break something …
I also had this problem. But the solution was easy… Just delete the HACS appletv part (reboot) and rely on the main branch appletv built-in to HA… Note I did have to repair my 4 apple TVs through…
Amazing to see the progress with Voice Assistants! One question - can USB devices like Jabras be hooked into Assist yet, in the way they can for the Rhasspy addons?
I understand wake word detection is still in the works, so currently Assist needs some sort of manual trigger (push to talk via esphome, mic button tapped in Assist dialog, phone receiver being lifted for VoIP).
But until we have wake word detection, it would be awesome if there was also a service to trigger Assist which would then listen and reply via a selectable USB mic/speaker.
