Database is currently not locked - then no logging until i reboot. This is in the system logs, reboot fixes the issue.
I am seeing this in the logs at 5am which is when the google backup runs, i have tried manually doing a HA backup and also a google backup which doesnt seem to cause the problem.
I have disabled the backup and see if it occours overnight.
I have already updated to .1 as well.
2024-07-06 05:01:16.292 WARNING (MainThread) [homeassistant.components.recorder.core] Database currently not locked
2024-07-06 05:10:50.330 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.back_door] Error from stream worker: Timestamp discontinuity detected: last dts = 2508266610, dts = 3590302486
2024-07-06 05:13:03.869 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.back_door] Error from stream worker: Timestamp discontinuity detected: last dts = 10197540, dts = -6030
2024-07-06 05:49:52.247 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.back_door] Error from stream worker: Timestamp discontinuity detected: last dts = 196322760, dts = 4292992516
2024-07-06 06:03:25.623 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.back_door] Error from stream worker: Timestamp discontinuity detected: last dts = 6349912, dts = -71720
2024-07-06 06:15:24.970 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.back_door] Error from stream worker: Timestamp discontinuity detected: last dts = 63082080, dts = 4293580756
2024-07-06 06:42:20.249 WARNING (Thread-4409) [custom_components.dreame_vacuum.dreame.protocol] Error while executing request: https://de.api.io.mi.com/app/v2/home/rpc/466929656 HTTPSConnectionPool(host='de.api.io.mi.com', port=443): Read timed out. (read timeout=5)
2024-07-06 07:05:16.954 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.back_door] Error from stream worker: Timestamp discontinuity detected: last dts = 267399630, dts = -240030
2024-07-06 08:08:26.252 WARNING (MainThread) [homeassistant.core] Timed out waiting for final writes to complete, the shutdown will continue
2024-07-06 08:08:26.252 WARNING (MainThread) [homeassistant.core] Shutdown stage 'final write': still running: <Task pending name='Task-430763' coro=<Recorder._async_shutdown() running at /usr/src/homeassistant/homeassistant/components/recorder/core.py:480> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, <1 more>, Task.task_wakeup()]> cb=[set.remove()]>
2024-07-06 08:08:56.422 WARNING (MainThread) [homeassistant.core] Timed out waiting for close event to be processed, the shutdown will continue
2024-07-06 08:08:56.423 WARNING (MainThread) [homeassistant.core] Shutdown stage 'close': still running: <Task pending name='Task-430763' coro=<Recorder._async_shutdown() running at /usr/src/homeassistant/homeassistant/components/recorder/core.py:480> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, <1 more>, Task.task_wakeup()]> cb=[set.remove()]>
2024-07-06 08:08:56.423 WARNING (MainThread) [homeassistant.core] Shutdown stage 'close': still running: <Task pending name='Task-430797' coro=<Recorder._async_close() running at /usr/src/homeassistant/homeassistant/components/recorder/core.py:472> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, <1 more>, Task.task_wakeup()]> cb=[set.remove()]>
2024-07-06 08:08:56.604 WARNING (Thread-5087 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_33] is still running at shutdown: File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self._bootstrap_inner()
File "/usr/local/lib/python3.12/threading.py", line 1073, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.12/threading.py", line 1010, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 89, in _worker
work_item = work_queue.get(block=True)
2024-07-06 08:08:56.623 WARNING (Thread-5087 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_54] is still running at shutdown: File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self.run()
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 92, in _worker
work_item.run()
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.12/threading.py", line 1147, in join
self._wait_for_tstate_lock()
File "/usr/local/lib/python3.12/threading.py", line 1167, in _wait_for_tstate_lock
if lock.acquire(block, timeout):
2024-07-06 08:08:56.639 WARNING (Thread-5087 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_40] is still running at shutdown: File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self.run()
work_item.run()
2024-07-06 08:08:56.966 WARNING (Thread-5087 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_54] is still running at shutdown: File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self.run()
work_item.run()
2024-07-06 08:08:57.293 WARNING (Thread-5087 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_40] is still running at shutdown: File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self.run()
work_item.run()
2024-07-06 08:09:06.443 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_54] is still running at shutdown: File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self.run()
work_item.run()
2024-07-06 08:09:06.460 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_40] is still running at shutdown: File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self.run()
work_item.run()
2024-07-06 08:09:06.959 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_54] is still running at shutdown: File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self.run()
work_item.run()
2024-07-06 08:09:07.458 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_40] is still running at shutdown: File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self.run()
work_item.run()
So backup starts at 5:00am and at 5:01am it does the āDatabase currently not lockedā message. Then no other messages until I restart HA at 8:08am where it looks like it is waiting for the DB to finishing performing writes to shut it down cleanly.
So I am guessing Google Backup kicks off a normal HA backup which pauses / quiesce the DB but is not releasing it.
