On opening terminal I get this message.
What can be wrong.
Please advise
i have this problem too… Tried connecting with putty too and it is refused…
Fixed it… In the plug in page there is a tab called CONFIGURATION, select it and you will see the default setup
ssh:
username: hassio
password: ‘’
authorized_keys: []
Put a hard password in between single talking marks and then save it. It wont start if the password is too simple or has been cracked before…
Had to use a hard password in SSH terminal configuration
Hi everyone, I’m getting the same error.
I have a strong password and I’m using also an authorized key!!
Is possible the problem is because I’m running Supervised HA in an RPi?
Edit: I tried to install the other SSH plugin and it worked but I prefer this one
Thanks, that solved my problem
worked for me too Thanks!!
I am using HA Supervised installation. I am getting same issue. I used hard password but not working. But able to use other ssh add-on. Write me if any solution. Thanks
I had the same problem on a supervised installation on a Linux host. The solution for me was to change the default port for SSH on the Linux part.
I had to change /etc/ssh/sshd_config file on Linux, I changed the Port key from the default port number (22) to some other free port (in my case 8022) and restarted the sshd service with:
systemctl restart sshd.service
Keep in mind that once the change is made, if you want to connect to the host with ssh you have to specify the port.
Good hint!.
I changed port on addon’s configuration page, not the host’s ssh port.
Artur
I had the same issue. I had entered a strong password but hadn’t noticed the Save button. Now it works as it should.
I ran into the same issue.
Sometimes it take a minute for the SSH to get ready. See the logs tab to ensure that the ssh is up and running. the log tab is to the right of configuration tab.
You can also access logs directly with (e.g. http://homeassistant.local:xxxx/hassio/addon/a0d7b954_ssh/info)
Yet. Hard password worked for me. Thanks!
Also, once you set your password, your existing session giving a bad gateway won’t work
Just reopen the shell once you’ve set a hard password.
Your method worked for me.
Thank you so much !
