O okay, that is strange. Obviously you canât adjust the 15min or just disable this feature in your fan.
Sorry the automation will not do what your asking.
Blacky
Blacky
Perfect. Thanks a lot! Warningâs gone
Hi, @Blacky
thanks for your quick response. We had a discussion here on the forum in June 2024, and you helped me then with setting up a manual switch as a bypass for your automation (your post number 494 in forum here) - I used your code suggestion directly in configuration.yaml. I note, however, that this bit of code in configuration.yaml does not affect the fan behavior after HA restart. Thanks for your concern and help, it was invaluable for me especially at the beginning when I was a complete beginner - now I have a bit more insight (although I probably wonât learn much programming at my age⌠)
My automatisation:
alias: VentilĂĄtor koupelna
description: ""
use_blueprint:
path: Blackshome/bathroom-humidity-exhaust-fan.yaml
input:
trigger: sensor.derivacni_senzor_koupelna_2
fan_switch:
area_id: koupelna
entity_id: light.tz3000_zojh9vz7_ts0001_svetlo
time_out: 20
include_manual_fan_switch: enable_manual_fan_switch_auto_off
manual_fan_switch:
- binary_sensor.manualni_zapnuti_ventilatoru
rising_humidity: 0.7
include_max_humidity: maximum_humidity_enabled
max_humidity: 80
bypass_auto_off_delay: 20
winter_include_fan_speed: fan_speed_disabled
manual_fan_switch_time_delay: 10
include_manual_trigger: enable_manual_trigger_time_delay
time_delay: 5
Your modified bypass of the manual switch from my configuration.yaml:
template:
- trigger:
- platform: state
to: "on"
- platform: state
to: "off"
binary_sensor:
- name: "ManuĂĄlnĂ zapnutĂ ventilĂĄtoru"
icon: mdi:fan
state: >
{% if trigger.id == 't1' and trigger.to_state.context.parent_id is none %}
on
{% else %}
off
{% endif %}
Thanks for your YAML. I have noticed 3 things⌠letâs clean this up first.
You canât use an area. Not sure why this is there. You will have to remove this or expand the area down to entities by clicking on the <> icon next to the X down to entities. From this list, select only the fan entity but it looks like it is already there so you could just remove this area selection.
You have option 2 enabled but your not using this option as there is no manual trigger selected. Please disable this option.
You have enabled max humidity but you havenât added your humidity sensor into the trigger. Please add your humidity sensor into Bathroom Humidity Sensor
I see, yes the binary sensor will not survive a restart so when HA restarts the automation thinks it is OFF so the fan sits and waits for the Safeguard - Maximum Run Time before it turns OFF. It will turn OFF but in your case 20 min.
However when testing found a bug in the bypass if you where using a actual switch. I have fixed this and will release an update.
I do have another way of doing this that will survive a restart. I have another blueprint that works the same but toggles a toggle helper. I havenât released it yet as it is not perfect but if your keen I can provide the link so you can test it out.
Blacky
Maintenance
Bugs Fixed
If you like this blueprint? Consider hitting the button in the top post
If you like my blueprints, and would like to show your support or just say thank you? Click Here
Enjoy
Blacky
Hey, @Blacky,
I corrected what I could according to your check of my update - it was obviously based on my misunderstanding of some of the functions of your blueprint. Yes, you are right that the maximum fan run time after HA restart is 20 minutes - which I experimentally verified when I once forgot to manually turn off the fan after HA restart -).
Iâll wait for your update, I donât feel erudite enough to play with beta versions. However, despite everything, your blueprint works satisfactorily - itâs clearly robust, and has survived my unprofessional settings⌠Thanks for your help!
Thanks for the update, glad to help you. At least you know what will happen when you restart HA now and you lead me to fix another bug in the blueprint, thank you. I have already release the update so if you press the blue import button at the top it will update the blueprint but it will still work the same when you restart HA.
Enjoy
Blacky
Thanks for your amazing template!
Wanted to ask if you are planning on adding a timer lock that disables the fan during certain hours?
It does detect humidity accurately but during certain times I want to be as quiet as possible and having to log in, disable the automation and so on its just a chore.
I wasnât planning to have an easy selection to disable the fan because I never get a false positive and for any reason we take a shower at anytime I would like the fan ON.
That said, I recommend using the bypass option 2. Create a schedule helper for the times you donât want the automation to run, and then add that schedule helper to the Bypass Switch. This way, youâll achieve the exact behavior youâre looking for.
Blacky
Do you know why i get this error:
Blockquote
Message malformed: expected a dictionary for dictionary value @ data[âactionsâ][0][âchooseâ][0][âsequenceâ][0][âchooseâ][0][âsequenceâ][2][âparallelâ][0][0][âsequenceâ][0][âtargetâ]
Blockquote
iâm on HA 2024.10.3
i get this when in auto triggers area i select derivate senzor and i wanna save it, i didnât change any other option in blueprint.
Could you please provide us your YAML of the automation? This YAML code are the settings you have selected in the automation so I can help. To do this go into your automation, top right 3 dots, Edit in YAML, copy all the code, come back to the forum and in your reply at the top tool bar click on â</>â and paste code in there.
Blacky
description: ""
alias: Bathroom Humidity Exhaust Fan
use_blueprint:
input: {}
You need to set up all the inputs and create a Derivative Sensor Helper
Step 1 = Click here
Step 2 = Click here
Blacky
itâs strange because i try to fill all the settings in blueprints when i click save, i didnât get error, but when i come back to see if the setting are save, they are not save.
ok i will try to take the steps you advice.
After saving a blueprint automation, youâll find it listed under the Automationâs tab, not the Blueprints tab. A blueprint acts as a reusable template, allowing you to create multiple automations from it. For example, you could use the same blueprint to set up automations for three different bathrooms.
Once saved, each automation will appear under the Automationâs tab, where you can view and adjust its specific settings.
It might feel a bit confusing at first, but I hope this explanation clarifies things!
Blacky
Oh, now itâs more clear, found it in automation TAB, i will post YAML file
description: ""
use_blueprint:
input:
trigger: sensor.senzor_de_umiditate_derivative
bathroom_humidity_sensor: sensor.sonoff_temp_bucatarie_humidity
manual_trigger:
- switch.ventilator_baie_mare_switch_0
manual_trigger_default_time_delay: 5
manual_trigger_winter_time_delay: 5
fan_switch:
area_id: baie_mare
device_id: 436181267fd1aadc7eb96180cad80e5c
entity_id: switch.ventilator_baie_mare_switch_0
manual_fan_switch:
manual_fan_switch_time_delay: 5
so for this fan i have a push button to control it, so i want to use this push button every time i think itâs necessary.
but with the current setting when i press the PB (shelly 1PM) the shelly start to flicker very fast on/off i donât think itâs suppose to work like that.
i donât know what option to use ?
if i disable both like in screenshoot fan works, but i need to set a working time like 5min when i press PB.
I have adjusted your automation YAML.
description: ""
use_blueprint:
input:
fan_switch:
Blacky
Hi Blacky,
Thank you for helping me.
I just want to point out , manual trigger work with phisical push button, i test it with delay time 5 min and works.
Now i think i need a little bit a fine tuning, i will explain why:
i take 2 showers with 5 min interval (i will post screenshoot)
the automation starts but only works for 5 min i will aspect to work till humidity falls back to normal levels
here automation stop for few seconds then restarts for 5 min
current config:
description: ""
use_blueprint:
input:
manual_trigger:
include_manual_trigger: disable_manual_trigger
fan_switch:
area_id: baie_mare
manual_fan_switch:
