This is my current code. I have removed all the settings, so it will not work without some reconfiguration.
The API calls need lat & long etc - go to
https://doc.forecast.solar/doku.php?id=api:estimate
for the details. The azimuth in the API is different to that used in the HA configuration!
Note that there is a limit to the number of free calls per hour, so I set this to run only once per hour.
I convert all times to local, and I use Dat/Time formatter node (just easy to use) - you will need to change the location settings in these.
I use persistent storage for my Forecast array object, but I have removed this you may not have it.
For the actual energy (Wh), I use a Riemann Sum on my inverter power to give energy, then I use a utility sensor with hourly reset and 30 minute offset to measure Wh by the hour. Since the forecast is power on the hour, I want to display energy as well at the hour, so rather than average between the hours and plot at the half hour, I average between the half hours and plot at the hour.
[{"id":"e08d258f206f740d","type":"http request","z":"8dc76c7c28d91dc0","name":"West (75)","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.forecast.solar/estimate/LAT/LONG/TILT/75/2.2","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":480,"y":220,"wires":[["4e231fe707a1707e"]]},{"id":"4f23fd40dd993022","type":"debug","z":"8dc76c7c28d91dc0","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":790,"y":180,"wires":[]},{"id":"a514e382982b2e2d","type":"http request","z":"8dc76c7c28d91dc0","name":"East (-105)","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.forecast.solar/estimate/LAT/LONG/TILT-105/2.2","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":470,"y":180,"wires":[["9d4953144b87679b"]]},{"id":"05c6e6c99987756a","type":"function","z":"8dc76c7c28d91dc0","name":"Init/Shift array","func":"var solarFC=flow.get(\"SolarForecast\") || {};\nvar i;\n\n// read date of the first set of records (ie forecast for today)\nvar upDate=Object.keys(msg.payload.result.watt_hours_day)[0];\nvar dateToday=msg.payload.nowTS.substring(0,10);\n\n// initialise object & table if it does not exist\nif (Object.keys(solarFC).length==0) {\n solarFC.solarTable=[];\n setTable(0);\n solarFC.energyToday=0;\n solarFC.energyTomorrow=0;\n solarFC.start=null;\n solarFC.stop=null;\n solarFC.dates={yesterday: msg.payload.dateYesterday, today: dateToday, tomorrow: msg.payload.dateTomorrow};\n solarFC.lastRead={P1: {time: null, watts: null, todayTotal: null, tomorrowTotal: null}, P2: {time: null, watts: null, todayTotal: null, tomorrowTotal: null}};\n flow.set(\"SolarForecast\", solarFC);\n}\n\n// if update is beyond 'tomorrow', clear array and start again\nif (upDate>solarFC.dates.tomorrow) {\n solarFC.solarTable=[];\n setTable(0);\n solarFC.dates={yesterday: msg.payload.dateYesterday, today: dateToday, tomorrow: msg.payload.dateTomorrow};\n flow.set(\"SolarForecast\", solarFC);\n}\n\n// if update = 'tomorrow' we need to move array left & add new 'tomorrow'\nif (upDate==solarFC.dates.tomorrow) {\n for (i=1; i<=24; i++) {solarFC.solarTable.shift()}\n setTable(48);\n solarFC.dates.yesterday=solarFC.dates.today;\n solarFC.dates.today=solarFC.dates.tomorrow;\n solarFC.dates.tomorrow=msg.payload.dateTomorrow;\n flow.set(\"SolarForecast\", solarFC);\n}\n\n// keep 'today' for use later\nmsg.payload.dateToday=dateToday;\nreturn msg;\n\nfunction setTable(from) {\n var j, hr, ts;\n for (j=from; j<72; j++) {\n ts=msg.payload.dateTomorrow;\n if (j<48) {ts=dateToday}\n if (j<24) {ts=msg.payload.dateYesterday}\n hr=j%24;\n ts=ts+\" \"+(100+hr).toString().substring(1,3)+\":00:00\";\n solarFC.solarTable[j] = {hour: hr, timestamp: ts, actualWh: null, efcWh: null, fcW: 0, oldfcW: null };\n }\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":860,"y":280,"wires":[["51d4b5d7426bcdeb"]]},{"id":"75789820f57a598f","type":"moment","z":"8dc76c7c28d91dc0","name":"NowTS","topic":"","input":"","inputType":"date","inTz":"ETC/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYY-MM-DD HH:mm","locale":"en-GB","output":"payload.nowTS","outputType":"msg","outTz":"Europe/London","x":920,"y":220,"wires":[["5e3849fade603d4c"]]},{"id":"5e3849fade603d4c","type":"moment","z":"8dc76c7c28d91dc0","name":"Y'day","topic":"","input":"","inputType":"date","inTz":"ETC/UTC","adjAmount":"1","adjType":"days","adjDir":"subtract","format":"YYYY-MM-DD","locale":"en-GB","output":"payload.dateYesterday","outputType":"msg","outTz":"Europe/London","x":1050,"y":220,"wires":[["aae43beb5a958f00"]]},{"id":"9d4953144b87679b","type":"change","z":"8dc76c7c28d91dc0","name":"P1","rules":[{"t":"set","p":"payload.plane","pt":"msg","to":"P1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":180,"wires":[["4f23fd40dd993022","95407afda7f38cef"]]},{"id":"4e231fe707a1707e","type":"change","z":"8dc76c7c28d91dc0","name":"P2","rules":[{"t":"set","p":"payload.plane","pt":"msg","to":"P2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":220,"wires":[["4f23fd40dd993022","95407afda7f38cef"]]},{"id":"aae43beb5a958f00","type":"moment","z":"8dc76c7c28d91dc0","name":"T'row","topic":"","input":"","inputType":"date","inTz":"ETC/UTC","adjAmount":"1","adjType":"days","adjDir":"add","format":"YYYY-MM-DD","locale":"en-GB","output":"payload.dateTomorrow","outputType":"msg","outTz":"Europe/London","x":1170,"y":220,"wires":[["05c6e6c99987756a"]]},{"id":"51d4b5d7426bcdeb","type":"function","z":"8dc76c7c28d91dc0","name":"Save record","func":"var solarFC=flow.get(\"SolarForecast\");\nvar plane=msg.payload.plane;\n\n// save part of API record, according to plane\nsolarFC.lastRead[plane].time=msg.payload.nowTS;\nsolarFC.lastRead[plane].watts=msg.payload.result.watts;\nsolarFC.lastRead[plane].todayTotal=msg.payload.result.watt_hours_day[msg.payload.dateToday];\nsolarFC.lastRead[plane].tomorrowTotal=msg.payload.result.watt_hours_day[msg.payload.dateTomorrow];\nflow.set(\"SolarForecast\", solarFC);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1030,"y":280,"wires":[[]]},{"id":"95407afda7f38cef","type":"switch","z":"8dc76c7c28d91dc0","name":"Success?","property":"payload.message.code","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":780,"y":220,"wires":[["75789820f57a598f"],[]]},{"id":"edc105c15dfe0888","type":"api-current-state","z":"8dc76c7c28d91dc0","name":"Solar Actual Wh hr30","server":"","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.solar_energy_hr30","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":460,"y":340,"wires":[["240261a5dcdb5d83"]]},{"id":"240261a5dcdb5d83","type":"change","z":"8dc76c7c28d91dc0","name":"values","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.attributes","tot":"msg"},{"t":"set","p":"payload.value","pt":"msg","to":"$number(msg.payload.last_period)*1000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":340,"wires":[["38d3d2589928f9df"]]},{"id":"3a49dbac5ac2a5ef","type":"delay","z":"8dc76c7c28d91dc0","name":"10s","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":310,"y":220,"wires":[["e08d258f206f740d","b9e003618f7c07f6"]]},{"id":"b9e003618f7c07f6","type":"delay","z":"8dc76c7c28d91dc0","name":"10s","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":290,"y":340,"wires":[["edc105c15dfe0888"]]},{"id":"7820caeea2c216d4","type":"function","z":"8dc76c7c28d91dc0","name":"Chart Array","func":"var graph = [\n {\n \"series\": [\"Forecast\", \"History\", \"Energy\", \"Actual\"],\n \"data\": [ [], [], [], []],\n \"labels\": []\n }\n];\n\nvar i;\nvar dp;\n\nfor (i = 0; i < msg.payload.length; i++) {\n dp=msg.payload[i];\n graph[0].data[0].push(dp.fcW);\n graph[0].data[1].push(dp.oldfcW);\n graph[0].data[2].push(dp.efcWh);\n graph[0].data[3].push(dp.actualWh);\n \n graph[0].labels.push(dp.hour.toString().concat(\":00\"));\n}\n\nreturn {payload: new Array(graph[0])};\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":890,"y":400,"wires":[["6f563040164af065"]]},{"id":"b4bc85f8910e51d7","type":"change","z":"8dc76c7c28d91dc0","name":"Read FC","rules":[{"t":"set","p":"payload","pt":"msg","to":"SolarForecast","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":240,"y":400,"wires":[["13ca57d7603b44e2","61a51f448dea4164","53154cd628b93a06","6ad0127144bb6b65","770e87fd5dc16fe4","ce8d74722e05f5c8","8e411ef252b4a030"]]},{"id":"6f563040164af065","type":"ui_chart","z":"8dc76c7c28d91dc0","name":"Forecast","group":"76e876790e22c53e","order":2,"width":0,"height":0,"label":"SolarForecast (Yesterday-Today-Tomorrow)","chartType":"line","legend":"true","xformat":"HH:mm","interpolate":"cubic","nodata":"","dot":true,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#d62728","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":1040,"y":400,"wires":[[]]},{"id":"6f365ba0a9744877","type":"inject","z":"8dc76c7c28d91dc0","d":true,"name":"Startup - refresh displays","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payloadType":"date","x":230,"y":440,"wires":[["b4bc85f8910e51d7"]]},{"id":"38d3d2589928f9df","type":"moment","z":"8dc76c7c28d91dc0","name":"TheHour","topic":"","input":"payload.last_reset","inputType":"msg","inTz":"ETC/UTC","adjAmount":0,"adjType":"days","adjDir":"add","format":"HH","locale":"en-GB","output":"payload.hour","outputType":"msg","outTz":"Europe/London","x":760,"y":340,"wires":[["03a5848d489c44e0"]]},{"id":"03a5848d489c44e0","type":"change","z":"8dc76c7c28d91dc0","name":"Index","rules":[{"t":"set","p":"payload.index","pt":"msg","to":"$parseInteger(msg.payload.hour, \"99\")+24\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":340,"wires":[["236a759e877f8fa7"]]},{"id":"730cf7a0b350b753","type":"change","z":"8dc76c7c28d91dc0","name":"Clear","rules":[{"t":"set","p":"payload","pt":"msg","to":"\"\"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":170,"y":180,"wires":[["3a49dbac5ac2a5ef","a514e382982b2e2d"]]},{"id":"6cb12d8d34719e70","type":"ui_text","z":"8dc76c7c28d91dc0","group":"76e876790e22c53e","order":3,"width":5,"height":1,"name":"","label":"Energy Today","format":"{{msg.payload}} kWh","layout":"row-spread","className":"","x":500,"y":560,"wires":[]},{"id":"53154cd628b93a06","type":"ui_text","z":"8dc76c7c28d91dc0","group":"76e876790e22c53e","order":5,"width":4,"height":1,"name":"","label":"Date","format":"{{msg.payload.dates.today}}","layout":"row-spread","className":"","x":470,"y":520,"wires":[]},{"id":"ac6df3972954c2f1","type":"ha-entity","z":"8dc76c7c28d91dc0","d":true,"name":"FC Energy Estimate","server":"","version":2,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"FC energy estimate"},{"property":"device_class","value":"measurement"},{"property":"icon","value":"mdi:counter"},{"property":"unit_of_measurement","value":"kWh"},{"property":"state_class","value":"energy"},{"property":"last_reset","value":""}],"state":"payload.energy","stateType":"msg","attributes":[{"property":"power","value":"payload.power","valueType":"msg"},{"property":"start","value":"payload.start","valueType":"msg"},{"property":"stop","value":"payload.stop","valueType":"msg"},{"property":"maximum","value":"payload.max","valueType":"msg"},{"property":"minimum","value":"payload.min","valueType":"msg"},{"property":"maxPower","value":"payload.maxPower","valueType":"msg"},{"property":"date","value":"payload.today","valueType":"msg"}],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"block","outputOnStateChange":false,"outputPayload":"","outputPayloadType":"str","x":1080,"y":500,"wires":[[]]},{"id":"1f15dba3805db244","type":"ui_text","z":"8dc76c7c28d91dc0","group":"76e876790e22c53e","order":7,"width":5,"height":1,"name":"","label":"Energy Tomorrow","format":"{{msg.payload}} kWh","layout":"row-spread","className":"","x":510,"y":600,"wires":[]},{"id":"c4a8903f4a0a4a42","type":"template","z":"8dc76c7c28d91dc0","name":"Period","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{payload.start}} to {{payload.stop}}","output":"str","x":430,"y":720,"wires":[["354a2540446d3ced"]]},{"id":"354a2540446d3ced","type":"ui_text","z":"8dc76c7c28d91dc0","group":"76e876790e22c53e","order":9,"width":4,"height":1,"name":"","label":"Period","format":"{{msg.payload}}","layout":"row-spread","className":"","x":550,"y":720,"wires":[]},{"id":"13ca57d7603b44e2","type":"change","z":"8dc76c7c28d91dc0","name":"Table","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.solarTable","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":400,"wires":[["7820caeea2c216d4","e204e3f2caada2a3"]]},{"id":"61a51f448dea4164","type":"function","z":"8dc76c7c28d91dc0","name":"Analyse Forecast","func":"var trend=\"night\";\nvar i, j, hour, FCnow, FCstart, FCstop, maxi=0, mini=0;\nvar FCmax=[], FCmin=[];\nvar FCpower=[{power: 0, period: [{start: 0, stop: 0, minutes: 0}]}];\nvar FCmaxPower=0, FCenergyToday=0;\nvar FCold, FClast=0, FCthisOne, FClastOne=0;\nvar startMins, stopMins;\nvar today=msg.payload.dates.today;\n\n// set up power array: up to 4000 watts in 250 watt increments\nfor (i=0; i<17; i++) {\n FCpower[i]={power: i*250, period: []};\n}\n// write true start/stop to [0] record (ie zero power)\nFCpower[0].period[0]={start: toMinutes(msg.payload.start.substring(11,16)), stop: toMinutes(msg.payload.stop.substring(11,16)), minutes: 0};\nstartMins=parseInt(msg.payload.start.substring(14,16));\nstopMins=parseInt(msg.payload.stop.substring(14,16));\n\n// go through forecast array - for today only\n// use 'history' record of forecast in preference to current forecast where it exists\n// so as to get a more accurate figure as the day progresses\n// *now is forecast, *old is history of forecast (current hour)\n// *thisOne is current hour value by preference, *lastOne is last hour value\n\nfor (hour=0; hour<24; hour++){\n FCnow=msg.payload.solarTable[hour+24].fcW;\n FCold=msg.payload.solarTable[hour+24].oldfcW;\n if (FCold>0) {FCthisOne=FCold} else {FCthisOne=FCnow} // use history in preference\n FCenergyToday+=FCthisOne;\n if (trend==\"night\") { // night\n if (FCthisOne>0) { // night->day : rise, start hour\n trend=\"rise\";\n FCstart=hour*60;\n power(startMins);\n }\n } else { // day (rise|fall)\n if (FCthisOne==0) { // day->night : night, stop hour\n power(60-stopMins);\n trend=\"night\";\n FCstop=(hour-1)*60;\n } else { // day=day\n if (FCthisOne>FClastOne) { // is rising\n if (trend==\"fall\") { //fall->rise, minimum point\n trend=\"rise\";\n FCmin[mini]=toHM((hour-1)*60);\n mini++;\n }\n } else { // is falling|same\n if (trend==\"rise\") { //rise->fall, maximum point\n trend=\"fall\";\n FCmax[maxi]=toHM((hour-1)*60);\n maxi++;\n }\n } // end falling|same\n power(0);\n } // end=day\n } // end day (rise|fall)\n FClastOne=FCthisOne;\n} // end for\n\n// calculate event duration and set minutes to string time\nfor (i=0; i<FCpower.length; i++) {\n if (FCpower[i].period.length>0) {\n FCmaxPower=FCpower[i].power;\n }\n for (j=0; j<FCpower[i].period.length; j++) {\n FCpower[i].period[j].minutes=FCpower[i].period[j].stop-FCpower[i].period[j].start;\n FCpower[i].period[j].start=toHM(FCpower[i].period[j].start);\n FCpower[i].period[j].stop=toHM(FCpower[i].period[j].stop);\n }\n}\n\n// output values for Node Red display & push to HA\nmsg.payload={};\nmsg.payload.start=toHM(FCstart); // start hour HH:00\nmsg.payload.stop=toHM(FCstop); // stop hour HH:00\nmsg.payload.maxPower=FCmaxPower; // maximum power level (*250 W) during day\nmsg.payload.max=FCmax; // array of maximum points (hours HH:00)\nmsg.payload.min=FCmin; // array of minimum points (hours HH:00) if found\nmsg.payload.power=FCpower; // array [i*250 W] of objects {power, period [{start, stop, minutes duration}]\nmsg.payload.today=today;\n// estimate of today energy kWh\nmsg.payload.energy=Math.round(FCenergyToday/100)/10;\n\nreturn msg;\n\n\n// extract total minutes (hour*60 + mins) from a string time\nfunction toMinutes(timeS) {\n return parseInt(timeS.substring(0,2))*60+parseInt(timeS.substring(3,5)); \n}\n\n// turn total minutes to a string (with leading zeros)\nfunction toHM(mins) {\n var temp=mins%60;\n return (100+(mins-temp)/60).toString().substring(1,3)+\":\"+(100+temp).toString().substring(1,3);\n}\n\n// for power levels of 250 watt increments, pro-rata the start/end\n// times based on a straight line: work in total minutes\n\n// loop through power levels between last and this power value\n// for each, pro-rata the minutes and add to last hour\n// save start (create new object) end (add to object) as next item in array of events\n// allow for more than one period in the forecast, adjust first/last for start/stop times\n\nfunction power(offset) { // offset = minutes into first hour at start\n var pwrStart, pwrIndex, mins, event; // 60-minutes from end at stop\n \n if (trend==\"rise\") { \n pwrStart=Math.floor((FClastOne*4)/1000)+1;\n for (pwrIndex=pwrStart; pwrIndex<=FCthisOne/250; pwrIndex++) {\n mins=Math.floor(((pwrIndex*250-FClastOne)/(FCthisOne-FClastOne))*(60-offset));\n event=FCpower[pwrIndex].period.length;\n FCpower[pwrIndex].period[event]={start: (hour-1)*60+mins+offset, stop: 0, minutes: 0}\n }\n } else {\n pwrStart=Math.floor((FClastOne*4)/1000);\n for (pwrIndex=pwrStart; pwrIndex>FCthisOne/250; pwrIndex--) {\n mins=Math.floor(((FClastOne-pwrIndex*250)/(FClastOne-FCthisOne))*(60-offset));\n event=FCpower[pwrIndex].period.length;\n FCpower[pwrIndex].period[event-1].stop=(hour-1)*60+mins;\n }\n }\n return;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":500,"wires":[["ac6df3972954c2f1","1819fa8cbaad4353"]]},{"id":"6599aef1b6a6b158","type":"ha-entity","z":"8dc76c7c28d91dc0","d":true,"name":"FC Solar Table","server":"","version":2,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"FC table"},{"property":"device_class","value":"datetime"},{"property":"icon","value":"mdi:update"},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":"timestamp"},{"property":"last_reset","value":""}],"state":"payload.update","stateType":"msg","attributes":[{"property":"FChours","value":"payload.time","valueType":"msg"},{"property":"FCwatts","value":"payload.forecast","valueType":"msg"},{"property":"FCactual","value":"payload.actual","valueType":"msg"},{"property":"FCold","value":"payload.old","valueType":"msg"},{"property":"FCwh","value":"payload.energyfc","valueType":"msg"}],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"block","outputOnStateChange":false,"outputPayload":"","outputPayloadType":"str","x":1060,"y":440,"wires":[[]]},{"id":"e204e3f2caada2a3","type":"function","z":"8dc76c7c28d91dc0","name":"HA graph array","func":"var i;\nvar ts=[], fc=[], efc=[], act=[], old=[];\nvar temp;\n\nfor (i=0; i<msg.payload.length; i++){\n temp=msg.payload[i];\n ts.push(temp.timestamp);\n fc.push(temp.fcW);\n efc.push(temp.efcWh);\n act.push(temp.actualWh);\n old.push(temp.oldfcW);\n}\n\ntemp=new Date().getHours()+24;\ntemp=msg.payload[temp].timestamp;\nmsg.payload={time: ts, forecast: fc, energyfc: efc, actual: act, old: old, update: temp};\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":880,"y":440,"wires":[["6599aef1b6a6b158"]]},{"id":"8e411ef252b4a030","type":"change","z":"8dc76c7c28d91dc0","name":"Period","rules":[{"t":"set","p":"payload.start","pt":"msg","to":"$substring(msg.payload.start,11,5)\t","tot":"jsonata"},{"t":"set","p":"payload.stop","pt":"msg","to":"$substring(msg.payload.stop, 11,5)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":720,"wires":[["c4a8903f4a0a4a42"]]},{"id":"c12e8f53b88a1fca","type":"ui_text","z":"8dc76c7c28d91dc0","group":"76e876790e22c53e","order":6,"width":5,"height":1,"name":"","label":"P1 update","format":"{{msg.payload.P1.time}}","layout":"row-spread","className":"","x":490,"y":640,"wires":[]},{"id":"31ba7f6e5d2590fa","type":"ui_text","z":"8dc76c7c28d91dc0","group":"76e876790e22c53e","order":10,"width":5,"height":1,"name":"","label":"P2 update","format":"{{msg.payload.P2.time}}","layout":"row-spread","className":"","x":490,"y":680,"wires":[]},{"id":"ce8d74722e05f5c8","type":"change","z":"8dc76c7c28d91dc0","name":"lastRead","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.lastRead","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":640,"wires":[["31ba7f6e5d2590fa","c12e8f53b88a1fca"]]},{"id":"6ad0127144bb6b65","type":"function","z":"8dc76c7c28d91dc0","name":"to kWh","func":"msg.payload=(msg.payload.energyToday/1000).toFixed(1);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":560,"wires":[["6cb12d8d34719e70"]]},{"id":"770e87fd5dc16fe4","type":"function","z":"8dc76c7c28d91dc0","name":"to kWh","func":"msg.payload=(msg.payload.energyTomorrow/1000).toFixed(1);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":600,"wires":[["1f15dba3805db244"]]},{"id":"1819fa8cbaad4353","type":"change","z":"8dc76c7c28d91dc0","name":"Save Power Table","rules":[{"t":"set","p":"SolarPowerTable","pt":"flow","to":"payload.power","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":560,"wires":[[]]},{"id":"236a759e877f8fa7","type":"function","z":"8dc76c7c28d91dc0","name":"Update Table","func":"var FC = flow.get(\"SolarForecast\")\n\n// save actual from msg.payload index/value. index = last hour\n// this sould be energy Wh between hh-:30 and hh+:30\nvar index=msg.payload.index;\nFC.solarTable[index].actualWh=msg.payload.value;\n\n// save pre-update forecast for last hour to forecast history\nFC.solarTable[index].oldfcW=FC.solarTable[index].fcW;\n\nvar today=FC.dates.today;\nvar plane2=(FC.lastRead.P2.time.substring(0,10)==today); // true if P2 last update date is today\n\nFC.energyToday=FC.lastRead.P1.todayTotal;\nFC.energyTomorrow=FC.lastRead.P1.tomorrowTotal;\nif (plane2) {\n FC.energyToday+=FC.lastRead.P2.todayTotal;\n FC.energyTomorrow+=FC.lastRead.P2.tomorrowTotal;\n}\n\nvar i, j;\nvar key, value, date, hour;\nvar wattArray=FC.lastRead.P1.watts;\nvar keyArray=Object.keys(wattArray);\n\n// clear all hour forecasts to zero\nfor (i=24; i<72; i++) {FC.solarTable[i].fcW=0}\n\n// save P1 last-read values to table\nfor (i=0; i<keyArray.length; i++) {\n key=keyArray[i];\n value=wattArray[key];\n date=key.substring(0,10);\n hour=parseInt(key.substring(11,13),10);\n j=hour+24;\n if (date==today){\n if (value==0){ // capture start/end hour\n if (hour<12) {FC.start=key}\n else {FC.stop=key}\n }\n } else {j+=24}\n if(value>0) {FC.solarTable[j].fcW=value}\n}\n\n// add in P2 values if required\nif (plane2) {\n wattArray=FC.lastRead.P2.watts;\n keyArray=Object.keys(wattArray);\n for (i=0; i<keyArray.length; i++) {\n key=keyArray[i];\n value=wattArray[key];\n date=key.substring(0,10);\n hour=parseInt(key.substring(11,13),10);\n j=hour+24;\n if (date>today) {j+=24}\n if (value>0) {FC.solarTable[j].fcW+=value}\n }\n}\n\n// recalculate watt-hours for each hr:-30 to hr:+30 and\n// post to hh:00 using a+b+b+c/4\n// run from index (last hour) to end of today\nfor (i=index; i<48; i++) {\n value=FC.solarTable[i-1].fcW;\n if (i==index) {value=FC.solarTable[i-1].oldfcW}\n value+=2*FC.solarTable[i].fcW;\n value+=FC.solarTable[i+1].fcW;\n FC.solarTable[i].efcWh=Math.floor(value/4);\n}\n\nflow.set(\"SolarForecast\", FC);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1030,"y":340,"wires":[["b4bc85f8910e51d7"]]},{"id":"3992708ff30a51e8","type":"inject","z":"8dc76c7c28d91dc0","d":true,"name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"3600","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":150,"y":100,"wires":[["730cf7a0b350b753"]]},{"id":"76e876790e22c53e","type":"ui_group","name":"Solar Forecast","tab":"a7de90402f2427f9","order":7,"disp":true,"width":15,"collapse":false,"className":""},{"id":"a7de90402f2427f9","type":"ui_tab","name":"Solar Forecast","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
You will have to decide how much of the Node-RED dashboard you want, and how much of the uplift to HA you want.
The forecast analysis builds a table of power periods based on 250 watts, and for each provides an array of possible events, each event being start, stop, and duration minutes. There being more than one period at a given power when the forecast goes up and down, I am still working on how best to use this information in HA. So far I have managed a template sensor that, for a given power, identifies the longest event out of a list of events at that power level.
I should add that I have two planes, so this is set up for two API calls and combination. You will have to remove the second call if not required - I did try to write the code so that it will sort out if only one plane, but naturally this is presented âas isâ and some work may be required.
EDIT April 2024 - Code has been updated and is now on Github for anyone interested
