Adjustable Wake-up to Android alarm
This blueprint wakes you up:
  • to your custom actions
  • if your custom conditions are met
  • before (or after) your phones next alarm with an custom offset.
  • It uses the next alarm sensor from the HA Android App.
:tipping_hand_man: Usage
  1. Enable next alarm sensor on the HA Android App
    HA App → Settings → Companion App → Manage Sensors → Next Alarm → enable
  2. Import the Blueprint
  3. Create an Automation based on the imported Blueprint Adjustable Wake-up to Android alarm
    Open your Home Assistant instance and show your blueprints.
  4. Set an alarm on your phone
:sparkles: Features
  • Offset (how many seconds before / or after the phone alarm goes off)
  • Select any action to run, e.g. turn on lights, play media, etc…
  • Select any condition, e.g. only run if person is home, only run if sun has not risen yet, etc…
    :bulb: Some Inspiratios: (at your own risk)
  • If the sun has not risen yet, turn on the bedroom lights 10 minutes before the phone alarm goes off
  • If person 1 is at home, switch on the TV and tune it to a news channel 30 minutes before the phone alarm rings
  • If person 2 is not at home, retrieve today’s calendar events and announce them on the bedroom speaker 2 minutes before the alarm is set to go off
  • If the temperature outside is below 0°C, start warming up the car 45 minutes before the alarm is set to go off
  • Wake up to an inspirational quote from a text-to-speech service, right before the alarm goes off
:wrench: Requirements
  • Android phone with mobile app
  • Next alarm sensor activated
  • Home Assistant Version 2024.10.x or higher
:fist_left: Tips, Tricks and Gotchas
  • You can test the action in the automation editor (run). It will not check the conditions you have configured.
  • When you snooze the alarm, let’s say 10 minutes it would rerun the action in again with the offset if the actions have already completed. You could set a delay longer than your snooze duration at the end of your actions to avoid multiple runs when snoozing. The automation is set to run in single mode.
  • Avoid positive offsets, see Automation Trigger - Home Assistant
:hammer_and_wrench: Changelog
  • 2026-03-24: V5, added forum link to the description
  • 2025-01-12: V4, removed the need for a helper and simplified the blueprint
  • 2024-11-22: V3, :new: Action can be tested, bugfixes and better snooze Handling, thanks @martinelv for the help here
  • 2023-10-15: Fix when disabling the phones alarm the automation was still running @Propboot
  • 2023-08-06: Initial release
blueprint:
  name: Adjustable Wake-up to Android alarm
  description: >
    # Adjustable Wake-up to Android alarm V5
    When the specified __conditions__ are satisfied, it runs these specified __actions__ prior the phone's next alarm
    ## 🔧 Requirements:
      - [Android app](https://play.google.com/store/apps/details?id=io.homeassistant.companion.android) installed on your phone
      - Next alarm sensor activated in the app (HA App → Settings → Companion App → Manage Sensors → Next Alarm → enable)
        [![Open your Home Assistant instance and show your helper entities.](https://my.home-assistant.io/badges/helpers.svg)](https://my.home-assistant.io/redirect/helpers/)
      - Home Assistant version 2023.8.0 or higher
    ## 💡Some Inspiratios: **(at your own risk)**
     - If the sun has not risen yet, turn on the bedroom lights 10 minutes before the phone alarm goes off
     - If person 1 is at home, switch on the TV and tune it to a news channel 30 minutes before the phone alarm rings
     - If person 2 is not at home, retrieve today's calendar events and announce them on the bedroom speaker 2 minutes before the alarm is set to go off
     - If the temperature outside is below 0°C, start warming up the car 45 minutes before the alarm is set to go off
    ## 🤝Feedback and Discussion
      - [Home Assistant Forum](https://community.home-assistant.io/t/adjustable-wake-up-to-android-alarm/599838)
  domain: automation
  author: op00
  homeassistant:
    min_version: 2024.10.0
  source_url: https://community.home-assistant.io/t/adjustable-wake-up-to-android-alarm/599838/26
  input:
    offset:
      description: "Enter an offset for the next alarm. Specify when the
        action should run the alarm. Use negative values for hour, minutes and seconds\n\n
        -1:-22:-33 = 1 hour 22 minutes and 33 seconds before alarm"
      selector:
        duration:
          enable_day: false
          enable_millisecond: false
      default:
        hours: -0
        minutes: -10
        seconds: -20
    alarm_source:
      description: "Select the alarm source\n\n _your Android phone's next alarm sensor_"
      selector:
        entity:
          filter:
            - integration: mobile_app
              device_class:
                - timestamp
          multiple: false
    conditions:
      description:
        "Choose the circumstances under which the actions will or will
        not run\n\n _can be multiple or none_"
      default: []
      selector:
        condition: {}
    actions:
      description: "Actions to run before alarm goes off\n\n _can be multiple_"
      default: []
      selector:
        action: {}
  - platform: time
    at:
      entity_id: !input alarm_source
      offset: !input offset
conditions: !input conditions
actions:
  sequence: !input actions
  alias: Alarm Actions
mode: single
trace:
  stored_traces: 21
:construction: ToDo
  • :black_square_button: Spellcheck
  • :white_check_mark: Ability to only listen to a specific alarm from android (there is an option in the HA companion app to whitelist apps)
  • :white_check_mark: Fix manual trigger for testing
  • :white_check_mark: Handle snooze, setting a new alarm when the alarm is still running.
🧑🏼‍🤝‍🧑🏻 Contributions
Very welcomed and please do, so far:
  • Thanks @Propboot for providing a fix, when the alarm gets disabled
  • Thanks @martinelv for the help with version V3
@op00 I now see what you realized, that everything people have been requesting of your previous blueprint can all be implemented using conditions. Brilliant in it’s simplicity!
Hi @op00
Thank you for this great blueprint. I noted that deactivating the alarm does not deactivate the scheduled alarm sequence. So I added the following condition:
  - conditions:
    - condition: trigger
    - condition: template
      value_template: '{{ trigger.to_state.state in ["unknown","unavailable"]
    sequence:
    - service: input_datetime.set_datetime
        datetime: "1970-01-01 00:00:00"
        entity_id: !input alarm_helper
I am new to HA, so this will not be the most elegant solution but perhaps it is a helpful inspiration.
Thank you, that’s great and I have updated the blueprint. Wish there was better versioning with blueprints.
I want to make a “wake up light” where a light slowly increases in brightness from the “offset” time until the alarm goes off. I see this older blueprint has functionality for this: Wake up to lights at next alarm (android), but since that one is deprecated I’m guessing it should also be possible with this one. Could anyone point me in a direction on how to implement that?
@kwint That’s what I use it for. If your light supports transition. You can add a service call ligth.turn_on with transition time to the actions.
Add Action → Call Service → Light: turn on → Select your Target → Select Transition (set a time) → select Brightness (target brightness)
or yaml
service: light.turn_on
  transition: 30
  brightness_step_pct: 100
  entity_id: light.somelight
if your light doesn’t support transition, i made this blueprint script here: Increase or decrease light brightness over time - Blueprints Exchange - Home Assistant Community (home-assistant.io)
I have a problem with this blueprint.
When I make a new automation the alarm which is already sets works. But when I change the alarm the steps in the automation change.
If I look at the trace timeline it says: “Triggered by the state of sensor.tel_ruben_next_alarm at December 22, 2023 at 15:42:42” and suddenly only chooses option 1 therefore not executing the sequence.
sorry, not sure if I understand your question/problem. Sorry. But the blueprint/automation has two triggers. One, when the alarm is being set/changed (changes the helper) and the time condition (actual alarm, with the configures actions)
When I change my alarm this happens.
The wrong option is chosen, it should be option 3.
EDIT: nvm, all of a sudden it’s working again
Thank you for this blueprint, it is exactly what I was looking for.
But I still have a question of understanding:
If I create several automations with the blueprint, do I need a separate helper for each automation or can the automations share one helper?
Thank you for this blueprint!
It was working for a while, but since a few days ago I have an issue: the first alarm fails to trigger anything, and only the subsequent snoozes work.
But even weirder: it works fine when I use an alarm in the middle of the day; only the morning one fails :face_with_raised_eyebrow:
I can’t see anything in the traces (https://file.io/q5WxK6JVYxHO) nor the logs :
2024-01-18 07:44:40.836 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 08:06:26.461 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 08:25:10.571 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 08:26:31.666 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 08:55:00.348 WARNING (MainThread) [homeassistant.components.automation.android_reveil_wake_up_alarm] Android : réveil wake up alarm: Already running
2024-01-18 08:55:06.611 WARNING (MainThread) [homeassistant.components.automation.android_reveil_wake_up_alarm] Android : réveil wake up alarm: Already running
2024-01-18 09:04:51.136 WARNING (MainThread) [homeassistant.components.automation.android_reveil_wake_up_alarm] Android : réveil wake up alarm: Already running
2024-01-18 09:04:55.291 WARNING (MainThread) [homeassistant.components.automation.android_reveil_wake_up_alarm] Android : réveil wake up alarm: Already running
2024-01-18 09:15:00.395 WARNING (MainThread) [homeassistant.components.automation.android_reveil_wake_up_alarm] Android : réveil wake up alarm: Already running
2024-01-18 09:15:05.504 WARNING (MainThread) [homeassistant.components.automation.android_reveil_wake_up_alarm] Android : réveil wake up alarm: Already running
2024-01-18 09:15:11.484 WARNING (MainThread) [homeassistant.components.automation.android_reveil_wake_up_alarm] Android : réveil wake up alarm: Already running
2024-01-18 09:15:24.940 WARNING (MainThread) [homeassistant.components.system_log.external] Dots 2 - Single press action
2024-01-18 09:24:28.164 ERROR (MainThread) [homeassistant.components.hassio.handler] /ingress/validate_session return code 401
2024-01-18 09:24:28.164 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /ingress/validate_session -
2024-01-18 10:53:30.243 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 350, in data_received
    messages, upgraded, tail = self._request_parser.feed_data(data)
  File "aiohttp/_http_parser.pyx", line 557, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadHttpMessage: 400, message:
  Data after `Connection: close`:
    b'HELP'
2024-01-18 10:59:54.820 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 11:16:46.190 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 11:41:35.310 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 11:49:57.056 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 12:51:19.289 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 13:20:33.725 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 13:37:02.080 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 14:24:13.331 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 15:01:29.214 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 15:48:00.810 WARNING (MainThread) [homeassistant.components.automation.android_reveil_wake_up_alarm] Android : réveil wake up alarm: Already running
2024-01-18 15:48:04.396 WARNING (MainThread) [homeassistant.components.automation.android_reveil_wake_up_alarm] Android : réveil wake up alarm: Already running
2024-01-18 15:55:24.855 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
2024-01-18 16:01:08.733 WARNING (MainThread) [homeassistant.components.system_log.external] Dots 2 - Single press action
2024-01-18 16:11:44.649 WARNING (Thread-5) [pychromecast.socket_client] [Salon CCwGTV 4k(192.168.1.25):8009] Heartbeat timeout, resetting connection
There should be something happening at 8:42(alarm at 8:45 with 180s offset) but there is nothing.
It is simply not triggering :face_with_raised_eyebrow:
NOTE: the logs contain a test around 15:48 to confirm it indeed works sometimes/in the middle of the day.
Also I originally thought there could be an issue with the fact that I use a “long running” script as action (Sunrise Simulator Manual) but that does not seem to be an issue (and it worked for a while anyway).
Separate helpers. Per automation a helper. The automation sets the helper to the alarm set on the phone minus offset.
Your logs are full of warning that the automation cannot run because it is already running.
The automation has two modes. 1. Setting the Helper to the alarm - offset 2. triggering the actions when the time equals to the helper.
Try to create a new alarm on your phone and check if the entity (next_alarm) and the helper is set in the dev tools :
Open your Home Assistant instance and show your state developer tools.
Snoozing does set a new next_alarm value => Mode 1, and that’s also why you’d see “already running”
Hello @op00
I have in fact the same problem. In my oppion there is a design failure at the blueprint.
My alarm is set automatically to the next event on the next day at the same time.
Actions are starting with an offset of -60 and if I turn off the alarm the automation is already running. Trigger for a new alarm is starting but cannot run while the automation is already running.
I’v set the automation in mode parallel. In this way it is working but it isn’t the best solution.
Would be awesome to have also an offset (+) for the new next_alarm trigger. Or something else.
regards
Sorry, I don’t really understand the problem.
If you could maybe list a timeline (Setting the alarm, Snoozing, state of the helper, state of the automation). It may be that your alarm app is different and therefore behaves different than mine.
Do I understand correctly if I want this for several phones I just have to create several automations?
Yes, and separate helper. Although I have not tested that yet. Let me know if it worked or not.
I usually have 3 alarm clocks set. 5 seconds before the alarm clock triggers actions - turning on the light or raising the blinds (depending on the sun level) and starting the alarm clock on the nest speaker with a one minute delay.
This one-minute delay means that when the phone alarm clock starts after 5 seconds and the automation wants to set the time of the next alarm clock it does not happen because the automation is already running.
I know that getting rid of the delay will solve the problem but I’m looking for a way to trigger some of the action also after the alarm clock, not just before. To be honest, raising the blinds/ turning on the light would also suit me better after the alarm clock than 5 seconds before.
Is there an easy way to just run this automation when it’s an workday. So it should not run if there is a holiday, weekend (and maybe vacation days
  • this needs manual entries I guess?)
