Air Quality Sensors + E-Ink Display using ESPHome
*** I’VE UPDATED MY POST WITH MY LATEST CODE ***
I’m no more using DarkSky as it will be removed soon.
Had to show my latest project as asked here: E-paper display
Parts are (total is about 50€): a 4.2" E-Ink display from Waveshare, a Lolin D32, a SDS011 (Air Quality), a BME280 (Temp, Humidity and Pressure), a buzzer and a LED (for notification):
Software used is ESPHome (what a great project!)
Nearly no soldering (only BME280 if I remember correctly)! This ESP32 has all the GPIO + all 3V3 and 5V needed.
My goal was to make a clone of the Xiaomi Mi Clear Grass Air Detector and to replace my Oregon weather station but where I am able to display what I want. I still need to make a case :slight_smile:
Here is my code
substitutions:
  devicename: AQI Display
  gpio_led_status: GPIO5
  gpio_i2c_sda: GPIO21
  gpio_i2c_scl: GPIO22
  gpio_uart_rx_pin: GPIO14
  gpio_uart_tx_pin: GPIO13
  gpio_spi_clk_pin: GPIO25
  gpio_spi_mosi_pin: GPIO26
  gpio_cs_pin: GPIO32
  gpio_busy_pin: GPIO33
  gpio_reset_pin: GPIO27
  gpio_dc_pin: GPIO17
  gpio_buzzer: GPIO04
  gpio_led_red: GPIO19
  gpio_led_green: GPIO23
  gpio_led_blue: GPIO18
esphome:
  comment: "Air Quality Display"
  platform: ESP32
  board: lolin_d32
status_led:
  pin:
   number: $gpio_led_status
   inverted: True
i2c:
  sda: $gpio_i2c_sda
  scl: $gpio_i2c_scl
  scan: False
uart:
  rx_pin: $gpio_uart_rx_pin
  tx_pin: $gpio_uart_tx_pin
  baud_rate: 9600
spi:
  clk_pin: $gpio_spi_clk_pin
  mosi_pin: $gpio_spi_mosi_pin
binary_sensor:
  - platform: status
  - platform: homeassistant
    entity_id: binary_sensor.alerte_meteo
    internal: true
    name: "Out Temp Rising"
    entity_id: binary_sensor.jardin_temp_rising
    internal: true
    name: "Out Temp Failing"
    entity_id: binary_sensor.jardin_temp_falling
    internal: true
  - platform: uptime
    name: "$devicename Uptime Sec"
    internal: true
  - platform: wifi_signal
    name: "$devicename WiFi Signal"
    update_interval: 120s
    device_class: "timestamp"
    accuracy_decimals: 0
    update_interval: never
    lambda: |-
      static float timestamp = (
        id(current_time).utcnow().timestamp - id(uptime_sec).state
      return timestamp;
  - platform: bme280
    i2c_id: bme_280
    temperature:
      name: "$devicename Temperature"
      filters:
        - sliding_window_moving_average:
            window_size: 5
            send_every: 5
    humidity:
      name: "$devicename Humidity"
      filters:
            window_size: 5
            send_every: 5
    pressure:
      name: "$devicename Pressure"
      filters:
            window_size: 5
            send_every: 5
        - lambda: |-
            const float STANDARD_ALTITUDE = 160; // in meters
            return x / powf(1 - ((0.0065 * STANDARD_ALTITUDE) /
                   (id(bme280_temp).state + (0.0065 * STANDARD_ALTITUDE) + 273.15)), 5.257); // in hPa
    address: 0x76
    update_interval: 60s
  - platform: sds011
    pm_2_5:
      name: "$devicename PM <2.5µm Concentration"
    pm_10_0:
      name: "$devicename PM <10.0µm Concentration"
    update_interval: 10min
    name: "1st floor Temp. from HA"
    entity_id: sensor.rdc_temperature
    unit_of_measurement: "°"
    accuracy_decimals: 1
    internal: true
    name: "1st floor Hum. from HA"
    entity_id: sensor.rdc_humidity
    unit_of_measurement: "%"
    internal: true
    name: "2nd floor Temp. from HA"
    entity_id: sensor.1er_temperature
    internal: true
    name: "2nd floor Hum. from HA"
    entity_id: sensor.1er_humidity
    internal: true
    name: "Outdoor Temp. from HA"
    entity_id: sensor.jardin_th_temperature
    internal: true
    name: "Outdoor Hum. from HA"
    entity_id: sensor.jardin_th_humidity
    internal: true
    name: "$devicename Air Quality Index"
    lambda: |-
      float value_temp = id(bme280_temp).state;
      float index_temp = 5;
      if (value_temp <= 14 || value_temp >= 25) {
          index_temp = 1;
      } else if (value_temp <= 15 || value_temp >= 24) {
          index_temp = 2;
      } else if (value_temp <= 16 || value_temp >= 23) {
          index_temp = 3;
      } else if (value_temp < 18 || value_temp > 21) {
          index_temp = 4;
      float value_hum = id(bme280_hum).state;
      float index_hum = 5;
      if (value_hum < 10 || value_hum > 90) {
          index_hum = 1;
      } else if (value_hum < 20 || value_hum > 80) {
          index_hum = 2;
      } else if (value_hum < 30 || value_hum > 70) {
          index_hum = 3;
      } else if (value_hum < 40 || value_hum > 60) {
          index_hum = 4;
      float value_pm2_5 = id(pm_2_5).state;
      float index_pm2_5 = 5;
      if (value_pm2_5 > 64) {
          index_pm2_5 = 1;
      } else if (value_pm2_5 > 53) {
          index_pm2_5 = 2;
      } else if (value_pm2_5 > 41) {
          index_pm2_5 = 3;
      } else if (value_pm2_5 > 23) {
          index_pm2_5 = 4;
      float value_pm10 = id(pm_10).state;
      float index_pm10 = 5;
      if (value_pm10 > 64) {
          index_pm10 = 1;
      } else if (value_pm10 > 53) {
          index_pm10 = 2;
      } else if (value_pm10 > 41) {
          index_pm10 = 3;
      } else if (value_pm10 > 23) {
          index_pm10 = 4;
      return ((index_temp + index_hum + index_pm2_5 + index_pm10) * 13) / 4;
    icon: "mdi:air-filter"
    on_value_range:
      - below: 38.0
        then:
          - light.turn_on:
              brightness: 100%
              red: 100%
              green: 0
              blue: 0
      - above: 39
        then:
          - light.turn_off:
switch:
  - platform: restart
  - platform: gpio
    pin: $gpio_buzzer
    icon: "mdi:volume-high"
text_sensor:
  - platform: version
    hide_timestamp: true
  - platform: wifi_info
    ip_address:
      icon: "mdi:server-network"
    ssid:
      name: "$devicename Connected SSID"
      icon: "mdi:wifi"
    name: "Today Weather Forecast"
    entity_id: sensor.weather_forecast_0
    internal: true
    name: "Today Weather Icon"
    entity_id: sensor.weather_condition_0
    internal: true
    name: "Tomorrow Weather Forecast"
    entity_id: sensor.weather_forecast_1
    internal: true
    name: "Tomorrow Weather Icon"
    internal: true
    name: "$devicename Air Quality Level"
    lambda: |-
      if (id(aqi_index).state <= 25) {
          return {"Très Mauvais"};  // INADEQUATE
      } else if (id(aqi_index).state <= 38) {
          return {"Mauvais"};       // POOR
      } else if (id(aqi_index).state <= 51) {
          return {"Moyen"};         // FAIR
      } else if (id(aqi_index).state <= 60) {
          return {"Bon"};           // GOOD
      } else {
          return {"Très Bon"};      // EXCELLENT
time:
    timezone: Europe/Paris
    on_time_sync:
      - component.update: uptime_timestamp
output:
  - platform: ledc
    pin: $gpio_led_red
  - platform: ledc
    pin: $gpio_led_green
  - platform: ledc
    pin: $gpio_led_blue
light:
  - platform: rgb
    red: redgpio
    green: greengpio
    blue: bluegpio
display:
  - platform: waveshare_epaper
    cs_pin: $gpio_cs_pin
    busy_pin: $gpio_busy_pin
    reset_pin: $gpio_reset_pin
    dc_pin: $gpio_dc_pin
    model: 4.20in # 300x400
    rotation: 270°
    lambda: |-
      ESP_LOGI("display", "Updating...");
      // OUTSIDE
      it.printf(7, 15, id(font_medium_20), TextAlign::BASELINE_LEFT, "Dehors");
      it.line(78, 14, 293, 14);
      it.printf(10, 84, id(icon_font_35), TextAlign::BASELINE_LEFT, "\U000F058E");
      if (id(outdoor_hum).has_state()) {
          it.printf(41, 82, id(font_regular_45), TextAlign::BASELINE_LEFT, "%2.0f", id(outdoor_hum).state);
          it.printf(95, 82, id(font_regular_30), TextAlign::BASELINE_LEFT, "%%");
      it.printf(120, 80, id(icon_font_40), TextAlign::BASELINE_LEFT, "\U000F050F");
      if (id(outdoor_temp).has_state()) {
          it.printf(220, 82, id(font_regular_65), TextAlign::BASELINE_CENTER, "%.1f°", id(outdoor_temp).state);
      if (id(out_temp_rising).has_state() && id(out_temp_failing).has_state()) {
          if (id(out_temp_rising).state == true) {
              it.printf(296, 82, id(icon_font_20), TextAlign::BASELINE_RIGHT, "\U000F005C");
          if (id(out_temp_failing).state == true) {
              it.printf(296, 82, id(icon_font_20), TextAlign::BASELINE_RIGHT, "\U000F0043");
      // INSIDE
      it.printf(7, 110, id(font_medium_20), TextAlign::BASELINE_LEFT, "Dedans");
      it.line(81, 109, 293, 109);
      // Floor 1
      it.printf(18, 162, id(icon_font_30), TextAlign::BASELINE_LEFT, "\U000F0D80");
      it.printf(60, 161, id(icon_font_25), TextAlign::BASELINE_LEFT, "\U000F058E");
      if (id(average_2nd_hum).has_state()) {
          it.printf(125, 160, id(font_regular_35), TextAlign::BASELINE_RIGHT, "%.0f", id(average_2nd_hum).state);
          it.printf(128, 160, id(font_regular_30), TextAlign::BASELINE_LEFT, "%%");
      it.printf(160, 159, id(icon_font_30), TextAlign::BASELINE_LEFT, "\U000F050F");
      if (id(average_2nd_temp).has_state()) {
          it.printf(290, 160, id(font_regular_45), TextAlign::BASELINE_RIGHT, "%.1f°", id(average_2nd_temp).state);
      // Floor 0
      it.printf(18, 212, id(icon_font_30), TextAlign::BASELINE_LEFT, "\U000F0DD2");
      it.printf(60, 211, id(icon_font_25), TextAlign::BASELINE_LEFT, "\U000F058E");
      if (id(average_1st_hum).has_state()) {
          it.printf(125, 210, id(font_regular_35), TextAlign::BASELINE_RIGHT, "%.0f", id(average_1st_hum).state);
          it.printf(128, 210, id(font_regular_30), TextAlign::BASELINE_LEFT, "%%");
      it.printf(160, 209, id(icon_font_30), TextAlign::BASELINE_LEFT, "\U000F050F");
      if (id(average_1st_temp).has_state()) {
          it.printf(290, 210, id(font_regular_45), TextAlign::BASELINE_RIGHT, "%.1f°", id(average_1st_temp).state);
      // AQI
      it.printf(20, 255, id(icon_font_25), TextAlign::BASELINE_LEFT, "\U000F0D43");
      it.printf(68, 255, id(font_regular_30), TextAlign::BASELINE_LEFT, "%s", id(aqi_level).state.c_str());
      // WEATHER
      it.printf(7, 285, id(font_medium_20), TextAlign::BASELINE_LEFT, "Météo");
      it.line(70, 284, 293, 284);
      int time = id(current_time).now().hour * 100 + id(current_time).now().minute;
      if (id(weather_icon).has_state()) {
          std::map<std::string, std::string> weather_state {
            { "clear-night", "\U000F0594" },
            { "cloudy", "\U000F0590" },
            { "exceptional", "\U000F05D6" },
            { "fog", "\U000F0591" },
            { "hail", "\U000F0592" },
            { "lightning", "\U000F0593" },
            { "lightning-rainy", "\U000F067E" },
            { "partlycloudy", "\U000F0595"},
            { "pouring", "\U000F0596" },
            { "rainy", "\U000F0597" },
            { "snowy", "\U000F0598" },
            { "snowy-rainy", "\U000F067F" },
            { "sunny", "\U000F0599" },
            { "windy", "\U000F059D" },
            { "windy-variant", "\U000F059E" }
          if (time < 1900) {
              it.printf(20, 320, id(icon_font_25), TextAlign::BASELINE_LEFT, weather_state[id(weather_icon).state.c_str()].c_str());
          } else {
              it.printf(20, 320, id(icon_font_25), TextAlign::BASELINE_LEFT, weather_state[id(weather_icon_1).state.c_str()].c_str());
      if (id(weather_alert).has_state() && id(weather_alert).state) {
          // mdi:alert-outline
          it.printf(50, 320, id(icon_font_25), TextAlign::BASELINE_LEFT, "\U000F002A");
      if (id(forcast).has_state() && time < 1900) {
          it.printf(290, 321, id(font_regular_30), TextAlign::BASELINE_RIGHT, "%s", id(forcast).state.c_str());
      else if (id(forcast_1).has_state() && time >= 1900) {
          it.printf(290, 321, id(font_regular_30), TextAlign::BASELINE_RIGHT, "%s", id(forcast_1).state.c_str());
      // TIME
      it.line(7, 337, 293, 337);
      it.strftime(7, 363, id(font_medium_20), TextAlign::BASELINE_LEFT, "%A", id(current_time).now());
      it.strftime(7, 393, id(font_medium_20), TextAlign::BASELINE_LEFT, "%d %b. %y", id(current_time).now());
      it.strftime(290, 393, id(font_regular_65), TextAlign::BASELINE_RIGHT, "%H:%M", id(current_time).now());
font:
  - file: 'fonts/Kanit-Medium.ttf'
    glyphs:
      ['&', '@', '!', ',', '.', '"', '%', '+', '-', '_', ':', '°', '0',
       '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E',
       'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S',
       'T', 'U', 'V', 'W', 'X', 'Y', 'Z', ' ', 'a', 'b', 'c', 'd', 'e', 'f',
       'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't',
       'u', 'v', 'w', 'x', 'y', 'z', '/', 'é']
  - file: 'fonts/Kanit-Regular.ttf'
    glyphs:
       'u', 'v', 'w', 'x', 'y', 'z', '/', 'è']
    glyphs:
      ['!', ',', '.', '"', '%', '-', '_', ':', '°', '/',
       '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', ' ']
    glyphs:
    glyphs:
  - file: 'fonts/materialdesignicons-webfont.ttf'
    glyphs: [
      "\U000F0043", # mdi-arrow-bottom-right
      "\U000F005C"  # mdi-arrow-top-right
    glyphs: [
      "\U000F058E", # mdi-water-percent
      "\U000F0D43", # mdi-air-filter
      "\U000F002A", # mdi-alert-outline
      "\U000F0594", # mdi-weather-night - clear-night
      "\U000F0590", # mdi-weather-cloudy
      "\U000F05D6", # mdi-alert-circle-outline - exeptionnal
      "\U000F0591", # mdi-weather-fog
      "\U000F0592", # mdi-weather-hail
      "\U000F0593", # mdi-weather-lightning
      "\U000F067E", # mdi-weather-lightning-rainy
      "\U000F0595", # mdi-weather-partly-cloudy
      "\U000F0596", # mdi-weather-pouring
      "\U000F0597", # mdi-weather-rainy
      "\U000F0598", # mdi-weather-snowy
      "\U000F067F", # mdi-weather-snowy-rainy
      "\U000F0599", # mdi-weather-sunny
      "\U000F059D", # mdi-weather-windy
      "\U000F059E"  # mdi-weather-windy-variant
    glyphs: [
      "\U000F050F", # mdi-thermometer
      "\U000F0D80", # mdi-home-floor-1
      "\U000F0DD2"  # mdi-home-floor-0
    glyphs: ["\U000F058E"]  # mdi-water-percent
    glyphs: ["\U000F050F"] # mdi-thermometer
wifi:
  networks:
  - ssid: !secret ssid
    password: !secret password
  - ssid: !secret ssid_live
    password: !secret password_live
  ap:
    ssid: "$devicename Fallback Hotspot"
    password: !secret api_ota_pwd
captive_portal:
web_server:
  port: 80
  auth:
    username: admin
logger:
api:
ota:
Weather infos are from MétéoFrance integration but it should work with all weather integrations (except DarkSky as it has not been updated). Before 7PM, it display weather forecast for the day, after 7PM it display forecast for tomorrow.
AQI calculation is done directly on the ESP and is based on code from @Limych: Indoor Air Quality Sensor Component (Thanks!)
Looks awesome. What kind of case do you have planned?
My goal is to make a case like the Xiaomi Mi Clear Glass Air Detector:
Original-Xiaomi-Mi-Clear-Grass-Intelligent-Air-Detector-From-Xiaomi-Youpin-Multi-Mode-Compensation-Indoor-Outdoor.jpg_q50
At the beginning I planned to buy a 3D printer and print a case but I’m running out of time to learn how to use FreeCAD… I may end with a laser cut wood case.
Can you please share the aliexpress link for the display? Cheers.
Found this one as the one I bought is not available anymore on Ali
It’s a 4.2" Waveshare 400x300. Full support from ESPHome
Hello I think there is a problem with the copy/paste but what is the symbol 
Thnaks
If you want to see what icon it is, check for it’s « mdi » name on https://materialdesignicons.com/
Then find it in the font and copy/past it to your code.
I try to connect the same paper with esphome without success.
The screen have no react.
My first try :
substitutions:
  gpio_cs_pin: GPIO32
  gpio_dc_pin: GPIO17
  gpio_buzzer: GPIO04
spi:
  clk_pin: GPIO12
  mosi_pin: GPIO13
display:
    rotation: 270°
    lambda: |-
      it.print(0, 0, id(font_medium_20), "Hello World!");
font:
    glyphs:
I found a mistake in my substitutions. It’s works for me thx.
@makai
how have implement mdi font.
I download the ttf file. place in Esphom/fonts, but when a try to use it like you I don’t have icon on screen.
You may check this post: Display materialdesign icons on ESPHome attached to screen
If it does not solve your issue, please post your yaml.
I use your code to understand how to do mine.
    entity_id: sensor.dark_sky_humidity
    internal: true
display:
    rotation: 270°
    lambda: |-
      // OUTSIDE
      it.printf(10, 84, id(icon_font_20), TextAlign::BASELINE_LEFT, "");
font:
    glyphs:
    glyphs: [
     "", # mdi-water-percent
Did you copy/paste the “glyphs” from my code above?
If yes, you should try to open the font on your computer and copy/paste from it.
ok i try it
@makai Bien vu !
Font have change. Thx a lot.
@makai One more question.
How work weather print ?
I use our code without success.
The weather alert binary sensor is a templated binary sensor based on the Météo France integration (you need to add it using GUI):
Under binary_sensor:
  sensors:
    alerte_meteo:
      entity_id: sensor.81_weather_alert
      friendly_name: Alerte Météo
      device_class: safety
      value_template: >-
        {{ is_state('sensor.81_weather_alert', 'Jaune')
           or is_state('sensor.81_weather_alert', 'Orange')
           or is_state('sensor.81_weather_alert', 'Rouge') }}
For the forecast I use the Darksky integration and a templated sensor (under sensor: in my conf):
    sensors:
      forecast_0:
        entity_id:
          - sensor.dark_sky_daytime_high_temperature_0d
          - sensor.dark_sky_overnight_low_temperature_0d
          - sensor.dark_sky_precip_probability_0d
          - sensor.dark_sky_icon_0d
          - sensor.dark_sky_uv_index_0d
        friendly_name: "Météo de la journée"
        value_template:
          "{{ states('sensor.dark_sky_overnight_low_temperature_0d')|round(0) }}°/\
           {{ states('sensor.dark_sky_daytime_high_temperature_0d')|round(0) }}°/\
           {{ states('sensor.dark_sky_precip_probability_0d')|round(0) }}%/\
           {{ states('sensor.dark_sky_uv_index_0d') }}UV"
        icon_template: >-
          {% if is_state("sensor.dark_sky_icon_0d", "clear-day") %}
            mdi:weather-sunny
          {% elif is_state("sensor.dark_sky_icon_0d", "clear-night") %}
            mdi:weather-night
          {% elif is_state("sensor.dark_sky_icon_0d", "cloudy") %}
            mdi:weather-cloudy
          {% elif is_state("sensor.dark_sky_icon_0d", "rain") %}
            mdi:weather-pouring
          {% elif is_state("sensor.dark_sky_icon_0d", "sleet") %}
            mdi:weather-snowy-rainy
          {% elif is_state("sensor.dark_sky_icon_0d", "snow") %}
            mdi:weather-snowy
          {% elif is_state("sensor.dark_sky_icon_0d", "wind") %}
            mdi:weather-windy
          {% elif is_state("sensor.dark_sky_icon_0d", "fog") %}
            mdi:weather-fog
          {% elif is_state("sensor.dark_sky_icon_0d", "partly-cloudy-day") %}
            mdi:weather-partly-cloudy
          {% elif is_state("sensor.dark_sky_icon_0d", "partly-cloudy-night") %}
            mdi:weather-night-partly-cloudy
          {% else %}
            error
          {% endif %}
      forecast_1:
        entity_id:
          - sensor.dark_sky_daytime_high_temperature_1d
          - sensor.dark_sky_overnight_low_temperature_1d
          - sensor.dark_sky_precip_probability_1d
          - sensor.dark_sky_icon_1d
          - sensor.dark_sky_uv_index_1d
        friendly_name_template: '{{ (as_timestamp(now()) + (86400))|timestamp_custom("%A", True) }}'
        value_template:
          "{{ states('sensor.dark_sky_overnight_low_temperature_1d')|round(0) }}°/\
           {{ states('sensor.dark_sky_daytime_high_temperature_1d')|round(0) }}°/\
           {{ states('sensor.dark_sky_precip_probability_1d')|round(0) }}%/\
           {{ states('sensor.dark_sky_uv_index_1d') }}UV"
        icon_template: >-
          {% if is_state("sensor.dark_sky_icon_1d", "clear-day") %}
            mdi:weather-sunny
          {% elif is_state("sensor.dark_sky_icon_1d", "clear-night") %}
            mdi:weather-night
          {% elif is_state("sensor.dark_sky_icon_1d", "cloudy") %}
            mdi:weather-cloudy
          {% elif is_state("sensor.dark_sky_icon_1d", "rain") %}
            mdi:weather-pouring
          {% elif is_state("sensor.dark_sky_icon_1d", "sleet") %}
          {% elif is_state("sensor.dark_sky_icon_1d", "snow") %}
            mdi:weather-snowy
          {% elif is_state("sensor.dark_sky_icon_1d", "wind") %}
            mdi:weather-windy
          {% elif is_state("sensor.dark_sky_icon_1d", "fog") %}
            mdi:weather-fog
          {% elif is_state("sensor.dark_sky_icon_1d", "partly-cloudy-day") %}
          {% elif is_state("sensor.dark_sky_icon_1d", "partly-cloudy-night") %}
          {% else %}
            error
          {% endif %}
It’s work ! Are you on the French discord ?
Hi @makai,
Thanks for sharing the project.
Can I use waveshare 7,5” e-ink display that uses red color along with black and white?
https://www.waveshare.com/7.5inch-hd-e-paper-b.htm
I would like to use red color to accent high values.
I have other question regarding 3D printed case, the finish on the 3D printed materials always feels cheap and not smooth at all, do you have some method where it would turn out like a molded plastic?
ESPHome does not currently support color for displays. So only the “black and white” 7.5" display is supported and the red one won’t work at all.
Regarding the case, I have no idea :man_shrugging:
