I will try to add more things that will going to help me identify issue on Android Wear. Maybe a debug mode or something similar. I will think on this more. Thanks.
you could create a fake mqtt light for testing.
I understand this is how it works. It also means the issues I’ve raised have been assigned a low(er) priority given that they have not been addressed for several releases. That’s why I’ve decided to allow for more time to pass before I test Ariela again.
I understand that but Conditional Card is official. I realize not all official cards may be supported yet, so another reason for me to allow for more time to pass before I test Ariela again.
Is there any way to use the Ariela device tracker to replace google_maps in the as a tracker? Google location sharing is horrendously slow, some times as much as 15 minutes. I want to use something that updates more frequently and thought the Ariela device tracker would do the trick. I haven’t figured out a way for it to show up on the map within HA. I also don’t want multiple device trackers running that suck my battery dry.
I can, but it will not going to properly simulate actual hardware. ( i had tried before, and for example turn_on / turn_off commands didn’t worked as intended).
Conditional card it should be ready somewhere next week.
Just enable device tracker in Ariela and your device should show up in maps / as entity. More informations you will find here: Device Tracker – Ariela
it will but then you need to set the optimistic mode.
Version 1.2.8.6 is out.
What’s new
- fixed crash when enabling firebase notification
- fixed shopping list display when using dark UI
- fixed clear button display on shopping list
- fixed UI display issue when showing HA notifications
- support for lovelace view background
- fixed inconsistent text size for climate / badges views
- show sensor value instead of icon in badges
- lovelace show conditional cards(it will always show the card from conditional)
Switched from WebUI to the native client and so much stuff is working
Any chance of getting the lovelace history_graph and thermostat component supported?
I also have a camera view that shows up, but only for a split second before it crashes the whole app. It is displaying a looping gif file. The android crash generates this:
time: 1550145882205
msg: java.lang.NullPointerException: Attempt to invoke virtual method 'android.graphics.drawable.Drawable android.graphics.drawable.Drawable$ConstantState.newDrawable()' on a null object reference
stacktrace: java.lang.NullPointerException: Attempt to invoke virtual method 'android.graphics.drawable.Drawable android.graphics.drawable.Drawable$ConstantState.newDrawable()' on a null object reference
at com.surodev.ariela.view.lovelace.GlanceViewHolder.lambda$null$2(GlanceViewHolder.java:109)
at com.surodev.ariela.view.lovelace.-$$Lambda$GlanceViewHolder$w-AhbbbhmXa7ebVYm0r8VaTtkDY.run(Unknown Source:4)
at android.os.Handler.handleCallback(Handler.java:873)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loop(Looper.java:193)
at android.app.ActivityThread.main(ActivityThread.java:6739)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:495)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:859)
I’ve emailed over the logs.
device_tracker is enabled and device tracking is on in Ariela. I’ve added the sensor to my main screen. It show as being away for the last 24 hrs and it’s not showing up on the map. Is there something I’m missing?
Enable debug mode in Ariela please and send me the logs. I will take a look and let you know what is wrong.
Thank you.
Just installed the app and I’m liking it so far. I have a few locks setup with Lovelace Entity Cards. In the web UI, they have a proper lock icon, but when using Ariela (referencing the Lovelace UI config) these cards have, what appear to be, some default icon that is a circle with 3 dots inside. Is this expected or should I be seeing the same icons as I do in the web UI?
Great work @Ionut, just bought Ariela PRO to show some support
As I already switched to lovelace, I’m having trouble reconstructing my lovelace view to Ariela.
I’m using custom-button card, it isn’t supported by Ariela, but I’m willing to switch to core button card, that is supported (I think).
Now the trouble is that I cannot get the same result as I get with web view.
I use vertical-horizontal stack to define the row for the buttons, but when I was testing the new lovelace layout, web view looked like it suppose to, but in ariela all button cards was arranged one by one.
I treyed with column number, but that didn’t gave great results.
Anyone else using button card, would love some examples that work with Ariela, and still look good in web view?
Here is a sample of my web view (don’t mind custom button card and modder, I can live without that), is something like that possible to achieve in Ariela?
Also is simple-thermostat supported in Ariela?
Button card is supported in Ariela. Regarding the vertical-horizontal stack, because some users didn’t realized they have to swipe left / right to show the cards in horizontal card, i decided to make rendering in Ariela show as vertical cards. In i will see what i can do in the future about this situation.
Also, thank you very much for the support, i really appreciate.
Swiping left right isn’t realy what I’m after, but simply to order my view like in the image above.
Swiping is in my opinion better to be left for switching tabs, or eaven better - swiping trough some cards like custom-swiper-card.
Also if you use light component with slider, or any slider it’s dificult to be recognized what are you trying to swipe.
A lot of swipes in single post
Are picture-elements going to be supported in the near future?
I have an horizontal stack with 2 picutre-elements, that does not render at all in Ariela
It’s already added to my TODO list. The plan is to support at least all official lovelace cards.
Too much swipes
I will see what i can do about this
One more suggestion…
Why not making a list of lovelace cards that are supported, so we know what to work with atm
Will do.
Also, version 1.2.8.7 is out.
What’s new:
- NEW: NFC MQTT reader (read and send NFC tags to Home Assistant)
- fixed crash when icon / picture / camera images are GIF
Please let me know if you find any issues.
Hello all,
If anyone want to check what lovelace cards are currently supported by Ariela, the list can be found here: http://ariela.surodev.com/2019/02/15/lovelace-cards/
