Automation for Sonos + Lutron Picos to Magically Manage Sleep Alarms and Music
This blueprint creates an automation that listens for a button press on a Lutron Caseta Pico Remote and depending on the time of day performs different sleep / alarm actions on a Sonos Speaker:
If pressed during the Wake Phase the automation will:
  • see if an alarm is playing and if so, stop it, otherwise temporarily disable an upcoming alarm
  • optionally run an additional action (e.g. open blinds and/or play music)
If pressed during the Sleep Phase, the automation will:
  • optionally run an additional action (e.g. turn off lights and/or turn on security system)
  • announce when the next alarm is set to run
  • optionally play music and set a sleep timer
Script Inputs
General inputs:
  • Sonos speaker id to use for the alarms and music
  • Pico remote id and button
Wake Phase inputs:
  • Time when the phase starts
  • Action to run
  • Time period to look for an alarm to disable
Sleep Phase inputs:
  • Action to run
  • Time period to look for an alarm to announce, and volume level for the announcement
  • Sleep music to play, sleep music volume, and sleep timer
How to Install
This automation blueprint relies on three script blueprints I previously created. Since Home Assistant blueprints don't support dependencies (more on that in a separate post), the dependencies have to be installed manually. I recommend the following order:
  1. Install the Announce Sonos Alarm script blueprint (details here) and create a script with an Entity ID of announce_sonos_alarm and optionally change the text-to-speech provider
  2. Install the Stop Sonos Alarm script blueprint (details here) and create a script with an Entity ID of stop_sonos_alarm
  3. Install the Play Random Media script blueprint (details here) and create a script with an Entity ID of play_random_media
    ... and finally ...
  4. Install the actual Sonos Sleep Handler automation blueprint itself and create the automation
Additional Notes
  • This blueprint is an experiment, both technically (configurable triggers and actions) and experientially (see what it is like having dependencies on other blueprints); I'll post my thoughts on that later, but installing requires more tinkering/knowledge than is ideal. If the instructions below are insufficent, I will update them.
  • This is one of my favourite automations. It simplifies sleep alarm handling down to one contextual button press. In my configuration, my Sleep Phase action includes turning off all downstairs lights and checking to see if the master bathroom is occupied and has lights on, and if so, dims the lights to the lowest setting to minimize light bleed into the master bedroom.
  • This blueprint requires Home Assistant 2022.5.0 because it runs the provided actions in parallel with the script actions
  • I recommend setting the mode to single since general safer to let it run
# *  Copyright 2022 Joseph Molnar
# *  Licensed under the Apache License, Version 2.0 (the "License");
# *  you may not use this file except in compliance with the License.
# *  You may obtain a copy of the License at
# *      http://www.apache.org/licenses/LICENSE-2.0
# *  Unless required by applicable law or agreed to in writing, software
# *  distributed under the License is distributed on an "AS IS" BASIS,
# *  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# *  See the License for the specific language governing permissions and
# *  limitations under the License.
# Automation blueprint that makes sleeping and waking time convenient on Sonos.
blueprint:
  name: Sonos Sleep / Alarm Handler
  description:
    This blueprint creates an automation that listens for a button press on a Lutron Caseta Pico remote
    and depending on the time of day does different things. If pressed during the `Wake Phase` it will
    disable the current or upcoming alarm on a Sonos speaker disable, and execute an optional action.
    If pressed during the `Sleep Phase`, it executes an optional action, annouce when the next alarm
    is set to run, and ends with some optional sleep music.
  domain: automation
  homeassistant:
    min_version: 2022.5.0 # this is needed because we are using 'parallel' below
  input:
    # general inputs
    speaker_id:
      description: The entity id of the Sonos speaker.
      selector:
        entity:
          domain: media_player
          integration: sonos
    remote_id:
      description: The entity id of the pico remote to enable.
      selector:
        device:
          integration: lutron_caseta
    button:
      name: Pico Remote Button
      description: The button on the pico remote. Common values are 'raise', 'lower', 'on', 'off' and 'stop'.
      selector:
        text:
    # wake phase inputs
    wake_start_time:
      name: Wake Phase | Start Time
      description:
        The time when someone may wake and need to disable alarm. It should be set a good amount of
        time prior to when an alarm would go off but after you go to sleep. The `Wake Phase` ends
        at `Sleep Phase Start Time`.
      default: "04:00:00"
      selector:
        time:
    wake_action:
      name: Wake Phase | Action
      description: An action to run while disabling the alarm. Examples could include opening blinds, playing music, etc.
      default: []
      selector:
    disable_alarm_time_window:
      name: Wake Phase | Period of Time to Find Alarm to Disable
      description:
        The number of minutes (up to 6 hours) the script will look forward to find an active alarm to disable
        if music isn't playing. The alarm is re-enabled about 5 minutes after the time it would have gone off.
      default: 60
      selector:
        number:
          min: 0
          max: 360
          unit_of_measurement: minutes
          mode: slider
    # sleep phase inputs
    sleep_start_time:
      name: Sleep Phase | Start Time
      description: A time close to when, though before, you go to sleep. The `Sleep Phase` ends at the `Wake Phase Start Time`.
      default: "18:00:00"
      selector:
        time:
    sleep_action:
      name: Sleep Phase | Action
      description:
        An action to run while announcing the alarm time and playing sleep music. Examples include turning
        off lights, turning down a thermostat, etc.
      default: []
      selector:
    announce_alarm_time_window:
      name: Sleep Phase | Period of Time to Find Alarm to Announce
      description:
        The amount of time, in minutes, to look forward for an alarm to announce. Maximum time is 1439 minutes
        (23 hours and 59 minutes), minimum is 30 minutes and the default is 720 minutes (12 hours).
      default: 720
      selector:
        number:
          min: 30
          max: 1439
          mode: slider
    announce_volume_level:
      name: "Sleep Phase | Alarm Announce Volume"
      description: "Float for volume level. Range 0..1. If value isn't given, volume isn't changed. Recommend the value be more than the music volume."
      default: 0.15
      selector:
        number:
          min: 0
          max: 1
          step: 0.01
          mode: slider
    music_content_ids:
      name: "Sleep Phase | Music Content IDs"
      description: "The list of music IDs and one will be randomly chosen to play. Examples include Spotify playlists or albums, Tune-In radio stations, etc."
      selector:
        object:
    music_volume_level:
      name: "Sleep Phase | Music Volume Level"
      description: "Float for volume level. Range 0..1. If value isn't given, volume isn't changed."
      default: 0.02
      selector:
        number:
          min: 0
          max: 1
          step: 0.01
          mode: slider
    music_sleep_timer:
      name: Sleep Phase | Music Timer
      description: How long music will play before stopping. Default is 15 minutes. Maximum is 600 (10 hours).
      default: 15
      selector:
        number:
          min: 0
          max: 600
          mode: slider
variables:
  # oddly you can't get blueprint inputs directly into jina so putting the
  # input into a variable so I can verify after
  music_content_ids: !input music_content_ids
  music_sleep_timer_hack: !input music_sleep_timer
  # we multiple by 60 since the Sonos sleep timer is in seconds but we asked for
  # minutes and yes I could multiplied directly for the constants but thought
  # better to show the why
  music_sleep_timer: >
    {{ ( 25 * 60 ) if ( music_sleep_timer_hack is undefined or music_sleep_timer_hack < 0 ) else ( 600 * 60 ) if music_sleep_timer_hack > 600 else ( music_sleep_timer_hack * 60 ) }}
  # I would love to make this trigger more generic but not really sure
  # how to do that yet, certainly can't make it an input as of yet
  - platform: device
    device_id: !input remote_id
    domain: lutron_caseta
    type: press
    subtype: !input button
  - choose:
      # 'Wake Up' phase of the automation
      - conditions:
          - condition: time
            after: !input wake_start_time
            before: !input sleep_start_time
        sequence:
          # we run these in parallel since the stop alarm may have a long
          # delay no it to re-enable the alarm
          - parallel:
              # first thing here is to turn off the alrm, which uses and
              # existing script I built, which needs to be manually added
              - service: script.stop_sonos_alarm
                  entity_id: !input speaker_id
                  time_window: !input disable_alarm_time_window
              # we now run the wake action
              # doing this weird choose thing to make so it will create the automation
              # since I can't put call !input directly after the hyphen
              - choose:
                  - conditions: >
                      {{ false }}
                    sequence: []
                default: !input wake_action
    default:
      # we run the actions given to us, and the others in parallel
      # since we don't know what it will do or take
      - parallel:
          # we start by running the sleep action
          - choose:
              - conditions: >
                  {{ false }}
                sequence: []
            default: !input sleep_action
          # but these actions, since they involve the sonos speaker
          # we want to run in sequence
          - sequence:
              # we want to announce the alarm
              - service: script.announce_sonos_alarm
                  time_window: !input announce_alarm_time_window
                  volume_level: !input announce_volume_level
              # next we start to play the music that was requested, assuming
              # it was given, this also uses an existing script I built which
              # needs to be manually added
              - choose:
                  - conditions: >
                      {{ music_content_ids != None and music_content_ids != "" }}
                    sequence:
                      - service: script.play_random_media
                          media_content_type: music # forcing music
                          repeat: "all" # forcing repeat
                          volume_level: !input music_volume_level
                          shuffle: true # forcing shuffle
                          media_content_ids: >
                            {{ music_content_ids }}
                      # we clear out any existing sleep timer, just in case
                      - service: sonos.clear_sleep_timer
                      # and now set the sleep timer
                      - service: sonos.set_sleep_timer
                          sleep_time: >
                            {{ music_sleep_timer }}
                default: []
mode: single
Revisions
  • 2022-05-30: Initial release
Available Blueprints
As mentioned above, this script is an experiment to see what it is like to have blueprints depend on blueprints and there are definitely some improvements I’d love to see Home Assistant make. I’ll post my thoughts on the topic separately. Definitely means users of blueprints need to know more and there is an increased chance of error.
This was also an experiment to play with blueprint triggers and again, I wish there were some improvements because I didn’t want this blueprint to be Pico specific. Ideally, like actions, I wish trigger could be an input someone could pass in.
Anyhow, this was pretty educational all-in-all. If I can provide any clarity on the blueprint or how to install, please let me know.
Your scripts are awesome, lots of effort and knowledge put there! Thank you so much for sharing!
A quick question for this specific one: trigger (switch) can be user- specified or (as you say) is something that will be included in a future release of yours?
I’m a noob in Home Assistant and still learning so I’d like to be able to define that option as I don’t own a lutron pico.
Once again, keep up the good work!
Hey @Stratos, thank you for the kind words! The scripts are definitely fun to create. Hoping to have a new one out this weekend that is more akin to this script (involving a Pico remote, Xbox and Sonos for a contextual media remote).
In terms of the trigger, I’m still not sure how to make it completely generic yet (not sure if it is possible even). Actually, hmm, I could create a script blueprint from this and then you could manually create your own automation with your own trigger. Hmm, something for me to think about. Would that be interesting?
What are you looking to trigger on?
That’s awesome news! You are very handy with this!
What I am looking for is triggering on a generic zigbee button, nothing special, eg a Samsung SmartThings Smart Button or similar.
I believe that you creating a blueprint with an open choice of triggers (zigbee buttons) will open up countless possibilities for using your automation, which, by the way, I find fantastic, even though I cannot use it for now.
No pressure, just saying… :slightly_smiling_face:
In any case, thank you so much for sharing your knowledge!
