Lutron Pico Media Remote for Contextually Handling Music or Xbox on Sonos Speakers
This blueprint creates an automation allowing a Lutron Caseta 5 button Pico remote to contextually
control music or an Xbox. It assumes Sonos speakers are being used, and the same speakers are used for both music and the Xbox. In my configuration I have an Xbox attached to a TV that has Sonos speakers attached via an HDMI Arc/eArc channel.
When the Xbox is on, the remote's on (top) and off (bottom) buttons map to the Xbox A and B
buttons respectively. This is great, particularly in media apps, since A is used to select, play or
pause while B is used to stop or go back.
When the Xbox is not powered, on (top) is mapped to playing / pausing music and off (bottom) is mapped to going to the next music track.
For both Xbox and music playback the raise (up arrow) button increases speaker volume and lower
(down arrow) button decreases speaker volume. While favourite / stop (round middle) button is
configurable.
The blueprint tries to handle oddities and conveniences for an optimal experience, including:
  • If the Xbox is on but the source isn't TV then it ungroups speakers and sets the source to TV
  • Re-groups speakers when re-starting music playback (groups are commonly broken after TV playback)
  • When re-grouping speakers, sets the volume on all speakers to the lead speaker's volume
  • When re-setting the volume during re-grouping the order of operations changes so you don't get odd volume spikes
  • When you press the raise / lower buttons the volume changes for all speakers
Script Inputs
  • [required] Pico remote
  • [required] Xbox console
  • [required] Primary Sonos speaker
  • [optional] List of additional Sonos speakers (to group together for a multi-room setup)
  • [optional] List of music content IDs (typically URLs) where one will randomly be chosen to play
  • [required] Volume (for music playback)
  • [required] Shuffle (for music playback)
  • [required] Repeat (for music playback)
  • [optional] Action to run when you press the favourite button
Note: the volume, shuffle and repeat values are only used when music is set to play the first time.
How to Install
This automation blueprint relies on another blueprint I previously created. Since Home Assistant blueprints don't support dependencies the dependencies have to be installed manually. I recommend the following order:
  1. Install the Play Random Media script blueprint (details here) and create a script with an Entity ID of play_random_media
  2. Install the actual Contextual Pico Media Remote automation blueprint and create the automation
Additional Notes
  • This is another of my favourite automations since I commonly switch between music and Xbox. While you still need an Xbox controller or media remote to browse content, I find the infrared on the Xbox can be finicky, media remotes aren't physically stable for quick button presses so you have to pick them up (unlike a Pico remote on a stand), and powering up Xbox controllers takes time. So this script is very convenient for quickly selecting, playing, pausing and going back.
  • This only requires Sonos speakers because I'm uncertain if other speakers can change their source to TV and I only have Sonos speakers to test with
  • I recommend setting the mode to single since this creates a script bound to fixed speakers, Xbox and remote
# *  Copyright 2022 Joseph Molnar
# *  Licensed under the Apache License, Version 2.0 (the "License");
# *  you may not use this file except in compliance with the License.
# *  You may obtain a copy of the License at
# *      http://www.apache.org/licenses/LICENSE-2.0
# *  Unless required by applicable law or agreed to in writing, software
# *  distributed under the License is distributed on an "AS IS" BASIS,
# *  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# *  See the License for the specific language governing permissions and
# *  limitations under the License.
# Automation blueprint that contextual controls music on speakers or context on an Xbox.
blueprint:
  name: Contextual Pico Media Remote
  description:
    This blueprint creates an automation allowing a **Lutron Caseta** 5 button  Pico remote to contextually
    control music or an **Xbox**. It assumes **Sonos** speakers are being used, and the same speakers are used
    <br>
    <br>
    When the Xbox is on, the remote's `on` (top) and `off` (bottom) buttons map to the Xbox `A` and `B`
    buttons respectively. This is great, particularly in media apps, since `A` is used to select, play or
    pause while `B` is used to stop or go back.
    <br>
    <br>
    When the Xbox is not powered, `on` (top) is mapped to playing / pausing music and `off` (bottom) is mapped
    <br>
    <br>
    For both Xbox and music playback the `raise` (up arrow) button increases speaker volume and `lower`
    (down arrow) button decreases speaker volume. While `favourite` / `stop` (round middle) button is
    configurable.
  domain: automation
  input:
    # general inputs
    remote_id:
      description: The entity id of the pico remote to enable.
      selector:
        device:
          model: PJ2-3BRL-GXX-X01 (Pico3ButtonRaiseLower)
    xbox_id:
      description: The entity id of the Xbox console.
      selector:
        entity:
          domain: media_player
          integration: xbox
    speaker_id:
      description: The entity id of the primary speaker.
      selector:
        entity:
          integration: sonos
    speaker_group_members:
      name: "Speaker Group Members"
      description:
        The entity ids of the additional entities to group together in a multi-room system. This ignores
        all types but entity ids. These speakers are only used when playing music, not when playing on
        the Xbox. Defaults to  blank.
      default: {}
      selector:
          entity:
            integration: sonos
    # music related inputs
    music_content_ids:
      name: "Music Content IDs"
      description:
        The list of music IDs and one will be randomly chosen to play. Examples include Spotify playlists or albums,
        Tune-In radio stations, etc. Defaults to blank.
      default: {}
      selector:
        object:
    music_volume_level:
      name: "Music Volume Level"
      description: Float for volume level. Range 0..1. Defaults to 0.2.
      default: 0.2
      selector:
        number:
          min: 0
          max: 1
          step: 0.01
          mode: slider
    music_shuffle:
      description: True/false for enabling/disabling shuffle. Defaults to `true`.
      default: true
      selector:
        boolean: null
    music_repeat:
      name: "Music Repeat Mode"
      description: Repeat mode set to off, all, one. Defaults to `all`.
      default: "all"
      selector:
        select:
          options:
            - "off"
            - "all"
            - "one"
    # favourite as an input
    favourite_action:
      description: An action to run when the Pico remote's favourite button is pressed.
      default: []
      selector:
variables:
  # oddly you can't get blueprint inputs directly into jina so putting the
  # input into a variable so I can verify after
  speaker_entity_id: !input speaker_id
  speaker_group_members_hack: !input speaker_group_members
  speaker_group_members: >-
    {# can't modify a list or reset a variable, so using a replaceable array in a mutable container as work around#}
    {# we only uses entity_id, and there will only be one given it is a dictionary #}
    {# but in the future we can look at converting areas and devices into entities #}
    {%- set workaround = namespace(members = []) -%}
    {%- for key in speaker_group_members_hack if key == 'entity_id'-%}
      {%- set workaround.members = speaker_group_members_hack[key] -%}
    {%- endfor -%}
    {{ workaround.members }}
  current_group_members: >-
    {{ state_attr( speaker_entity_id, 'group_members') }}
  xbox_entity_id: !input xbox_id
  xbox_device_id: >-
    {{ device_id( xbox_entity_id ) }}
  music_content_ids: !input music_content_ids
  music_shuffle: !input music_shuffle
  music_repeat: !input music_repeat
  music_volume_level: !input music_volume_level
  speaker_volume_level: >-
    {%- set volume = state_attr(speaker_entity_id, 'volume_level') -%}
    {%- if volume == None or volume <= 0 -%}
      {{ music_volume_level }}
    {%- else -%}
      {{ volume }}
    {%- endif -%}
  # to make it easier and have less jinja code, and repeated state
  # checks we create some variables
  is_speaker_source_tv: >-
    {{ is_state_attr( speaker_entity_id, 'source', 'TV') }}
  is_speaker_media_set: >-
    {%- set duration = state_attr(speaker_entity_id, 'media_duration') -%}
    {%- if duration == None or duration <= -1 -%}
      {{ false }}
    {%- else -%}
      {{ true }}
    {%- endif -%}
  is_speaker_playing: >-
    {{ is_state(speaker_entity_id, 'playing') }}
  is_speaker_lonely: >-
    {{ current_group_members == None or current_group_members|length == 0 or ( current_group_members|length == 1 and speaker_entity_id in current_group_members ) }}
  is_xbox_on: >-
    {{ is_state(xbox_entity_id, 'on') }}
  - platform: device
    device_id: !input remote_id
    domain: lutron_caseta
    type: press
    subtype: "on"
  - platform: device
    type: press
    subtype: "off"
  - platform: device
    type: press
    subtype: raise
  - platform: device
    type: press
    subtype: lower
  - platform: device
    type: press
    subtype: stop
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - choose:
              - conditions: >
                  {{ not is_xbox_on }}
                sequence:
                  - choose:
                      - conditions: >
                          {{ is_speaker_media_set }}
                        sequence:
                          # if xbox is not on and the speaker is set to play music
                          # we see if we should group and if so, we set the volume
                          # for all speakers to be the same as the leader and then
                          # play/pause, otherwise we just play/pause
                          - choose:
                              - conditions: >
                                  {{ is_speaker_lonely and speaker_group_members|length > 0 }}
                                sequence:
                                  - choose:
                                      - conditions: >
                                          {{ is_speaker_playing }}
                                        sequence:
                                          # we set volume second so you don't hear a
                                          # change in volume before it pauses
                                          - service: media_player.media_pause
                                              entity_id: >-
                                                {{ speaker_entity_id }}
                                            data: {}
                                          - service: media_player.volume_set
                                              entity_id:
                                                - "{{ speaker_entity_id }}"
                                              volume_level: "{{ speaker_volume_level }}"
                                              entity_id: >-
                                                {{ speaker_group_members }}
                                    default:
                                      # we set volume first so you don't hear a
                                      # change in volume after it starts to play
                                          entity_id:
                                          entity_id: >-
                                      # we aren't playing so we play after volume
                                      # changes so it doesn't sound odd
                                      - service: media_player.media_play
                                          entity_id: >-
                                        data: {}
                                  # we do the join after the above play/pause
                                  # and volume changes, since there can be a
                                  # delay when calling join, but we want people
                                  # to know the button was pressed
                                  - service: media_player.join
                                      group_members: >-
                                      entity_id: >-
                            default:
                              - service: media_player.media_play_pause
                                  entity_id: >-
                                data: {}
                    default:
                      # if xbox is not on and the speaker is not set to play
                      # music then we start playing what was passed in
                      - service: script.play_random_media
                          media_content_type: music
                          entity_id: >-
                          group_members:
                            entity_id: >-
                          repeat: >-
                            {{ music_repeat }}
                          volume_level: >-
                          shuffle: >-
                            {{ music_shuffle }}
                          media_content_ids: >
                            {{ music_content_ids }}
            default:
              # if the xbox is on, we make sure the source is set to the TV
              - choose:
                  - conditions: >
                      {{ not is_speaker_source_tv }}
                    sequence:
                        data: {}
                          entity_id: >-
                      - service: media_player.unjoin
                        data: {}
                          entity_id: >-
                      - service: media_player.select_source
                          source: TV
                          entity_id: >-
                default: []
              # and then send the remote command
              - service: remote.send_command
                  command: A
                  device_id: >-
                    {{ xbox_device_id }}
      - conditions:
        sequence:
          - choose:
              - conditions: >
                sequence:
                  # if the xbox isn't on, then we to go the next track
                  - service: media_player.media_next_track
                      entity_id: >-
                    data: {}
            default:
              # if the xbox is on then we make sure the source is set to the TV
              - choose:
                  - conditions: >
                    sequence:
                        data: {}
                          entity_id: >-
                        data: {}
                          entity_id: >-
                          source: TV
                          entity_id: >-
                default: []
              # and then send the command
                  command: B
                  device_id: >-
      - conditions:
        sequence:
          # raises volume, including grouped speakers as appropriate
          - choose:
              - conditions: >
                  {{ is_speaker_lonely }}
                sequence:
                  - service: media_player.volume_up
                      entity_id:
                    data: {}
            default:
                  entity_id: >-
                    {{ current_group_members }}
                data: {}
      - conditions:
        sequence:
          # lowers volume, including grouped speakers as appropriate
          - choose:
              - conditions: >
                sequence:
                  - service: media_player.volume_down
                      entity_id:
                    data: {}
            default:
                  entity_id: >-
                data: {}
      - conditions:
        sequence:
          - choose:
              - conditions: >
                  {{ false }}
                sequence: []
            default: !input favourite_action
    default: []
mode: single
max_exceeded: silent
Revisions
  • 2022-11-05: Initial release
Available Blueprints
While this script may seem super specific since it requires using a Lutron 5 button Pico remote, an Xbox and Sonos, I found this script to be very convenient for me (I use this script in two rooms) and ultimately I thought it may be interesting for others to play with even if they don’t have these exact devices.
I may also be able to make it not require Sonos if I knew how other speakers handle TV as a source input. If anyone has such details, please send over and I can see how I could incorporate.
