BuildIng a Smart Light Automation with C4002 mmWave Radar and ESPHome in Home Assistant
Previous article: From PIR to mmWave: My Smart Lighting Automation in Home Assistant
Introduction
This tutorial guides you through building a presence-sensing light automation system using FireBeetle 2 ESP32-C6, the C4002 mmWave radar sensor, and Home Assistant. The system automatically turns on lights when someone is present and turns them off after the area is vacant.
You’ll learn ESPHome configuration, MQTT relay integration, and Home Assistant automation rules.
Software and Hardware Preparation
Software
Hardware
Step One: Connecting the C4002 for Human Presence Detection
Wiring Diagram
Connect ESP32-C6 and C4002 as shown below. For detailed instructions, refer to the C4002 Integration Tutorial.
C4002 Integration with ESPHome
Log in to Home Assistant and click ‘ESPHome Builder’ in the left sidebar.
Click + NEW DEVICE.
Click CONTINUE on the wizard page.
Enter a device name (e.g., Presence Sensor), then click NEXT.
Select ESP32‑C6 as the hardware model. When Configuration created appears, click SKIP.
Locate the newly created presence-sensor device in the ESPHome device list.
Click EDIT to open the YAML configuration file.
Paste the following configuration at the end of the YAML file:
# UART Configuration
uart:
  tx_pin: GPIO5
  rx_pin: GPIO4
  baud_rate: 115200
# External components
external_components:
  - source:
      type: git
      url: https://github.com/cdjq/esphome.git
      ref: dev
    components:
      - dfrobot_c4002
    refresh: 0s
# C4002 Component Configuration
dfrobot_c4002:
  uart_id: uart_bus
# Sensor Configuration
  - platform: dfrobot_c4002
    c4002_id: my_c4002
    movement_distance:
      name: "Motion Distance"
      unit_of_measurement: "m"
      accuracy_decimals: 2
      icon: "mdi:ruler"
      device_class: "distance"
      state_class: "measurement"
    existing_distance:
      name: "Presence Distance"
      icon: "mdi:account"
    movement_speed:
      unit_of_measurement: "m/s"
      icon: "mdi:speedometer"
      device_class: "speed"
    movement_direction:
      name: "Motion Direction"
      icon: "mdi:compass"
    target_status:
      icon: "mdi:target"
  # WiFi Signal Sensor
  - platform: wifi_signal
    name: "WiFi Signal Strength"
    update_interval: 30s
    unit_of_measurement: "dBm"
    accuracy_decimals: 0
    device_class: "signal_strength"
    entity_category: "diagnostic"
text_sensor:
    name: "Movement Direction Text"
    icon: "mdi:directions"
    lambda: |-
      if (id(movement_direction_sensor).has_state()) {
        int d = id(movement_direction_sensor).state;
        if (d == 0) return {"Approaching"};
        else if (d == 1) return {"No Direction"};
        else if (d == 2) return {"Away"};
        else return {"Unknown"};
      return {"No Data"};
    update_interval: 1s
    name: "Target Status Text"
    icon: "mdi:human-greeting"
    lambda: |-
      if (id(target_status_sensor).has_state()) {
        int d = id(target_status_sensor).state;
        if (d == 0) return {"No Target"};
        else if (d == 1) return {"Static Presence"};
        else if (d == 2) return {"Motion"};
      return {"No Data"};
    update_interval: 1s
    c4002_id: my_c4002
    c4002_text_sensor:
      icon: "mdi:message-text-outline"
# Switch Configuration
switch:
    c4002_id: my_c4002
    switch_out_led:
      name: "Out LED Switch"
      icon: "mdi:led-on"
    switch_run_led:
      name: "Run LED Switch"
      icon: "mdi:led-on"
    switch_factory_reset:
      icon: "mdi:restart"
      entity_category: "config"
    switch_environmental_calibration:
      name: "Sensor Calibration"
      icon: "mdi:calibration"
# Select Configuration
select:
    c4002_id: my_c4002
    operating_mode:
      icon: "mdi:account"
      options:
        - "Mode_1"
        - "Mode_2"
        - "Mode_3"
# Number Configuration
number:
    c4002_id: my_c4002
    max_range:
      name: "Max Detection Distance"
      icon: "mdi:ruler"
    min_range:
      name: "Min Detection Distance"
      icon: "mdi:ruler"
    light_threshold:
      name: "Light Threshold"
      unit_of_measurement: "lx"
      icon: "mdi:lightbulb"
    area1_min:
      name: "Area 1 Min"
      icon: "mdi:ruler"
    area1_max:
      name: "Area 1 Max"
      icon: "mdi:ruler"
    area2_min:
      name: "Area 2 Min"
      icon: "mdi:ruler"
    area2_max:
      name: "Area 2 Max"
      icon: "mdi:ruler"
    area3_min:
      name: "Area 3 Min"
      icon: "mdi:ruler"
    area3_max:
      name: "Area 3 Max"
      icon: "mdi:ruler"
    target_disappeard_delay_time:
      name: "Target Disappear Delay"
      unit_of_measurement: "s"
      icon: "mdi:timer"
Click INSTALL to compile the firmware.
2e174a29036b43c6a6624b216cc34e41
Select Plug into this computer, then click Download project.
After compilation, click Download project, select Factory format, and download the firmware file (presence-sensor.factory.bin).
Click Open ESPHome Web.
Connect the FireBeetle 2 ESP32‑C6 to your computer via USB.
Click CONNECT on the flashing tool page.
Select the ESP32‑C6 serial port, then click Connect.
Once connected, click INSTALL.
Click Choose File, select the firmware file, then click INSTALL.
Wait for the flashing to complete.
Disconnect USB, then connect the battery pack, ESP32‑C6, and C4002 following the wiring diagram.
Return to Home Assistant - the presence sensor device should be online.
On the Overview page, click the three-dot icon and select Edit Dashboard.
Click + ADD CARD.
Select Entities card, then choose C4002-related entities (e.g., Motion Distance).
Customize the card name and icon, then click Save.
The Entities card will display real-time data from the C4002.
You can choose different card types for diverse visualization.
Step Two: Connecting the Relay to Control the Lights
Wiring Diagram for ESP32-C6 and Relay
Complete the wiring between ESP32-C6, relay, and USB light as shown:
Relay Integration via MQTT
Home Assistant has built-in MQTT integration for communication with ESP32-C6.
First, install the Mosquitto Broker add-on. Go to Settings → Add-ons.
Click Add-on store, search for and install Mosquitto broker.
Enable Start on boot and Watchdog.
Create an MQTT login account: Go to Settings → People, add a new user. This username/password will be used in the ESP32 program.
Write MQTT client code in Arduino IDE for WiFi connection, MQTT communication, and relay control. Note: ESP32-C6 and Home Assistant must be on the same WiFi network.
Open Arduino IDE:
Copy and paste the following code:
#include <WiFi.h>
#include <PubSubClient.h>
/* ================== WiFi Configuration ================== */
const char* ssid     = "YOUR_WIFI_SSID";
const char* password = "YOUR_WIFI_PASSWORD";
/* ================== MQTT Configuration ================== */
const char* mqtt_server = "YOUR_MQTT_BROKER_IP";
const char* mqtt_user   = "YOUR_MQTT_USERNAME";
const char* mqtt_pass   = "YOUR_MQTT_PASSWORD";
/* ================== MQTT Topics ================== */
#define TOPIC_STATUS        "c4002/status"
#define TOPIC_RELAY_SET     "c4002/relay/set"
#define TOPIC_RELAY_STATE   "c4002/relay/state"
/* ================== Relay Configuration ================== */
#define RELAY_PIN 14
#define RELAY_ON  LOW
#define RELAY_OFF HIGH
/* ================== MQTT Client ================== */
WiFiClient espClient;
PubSubClient client(espClient);
   MQTT Message Callback Function
void callback(char* topic, byte* payload, unsigned int length) {
  char msg[20];
  memcpy(msg, payload, length);
  msg[length] = '\0';
  Serial.print("MQTT Received: ");
  Serial.println(msg);
  if (strcmp(topic, TOPIC_RELAY_SET) == 0) {
    if (strcmp(msg, "ON") == 0) {
      digitalWrite(RELAY_PIN, RELAY_ON);
      client.publish(TOPIC_RELAY_STATE, "ON", true);
      Serial.println("Relay turned ON");
    else if (strcmp(msg, "OFF") == 0) {
      digitalWrite(RELAY_PIN, RELAY_OFF);
      client.publish(TOPIC_RELAY_STATE, "OFF", true);
      Serial.println("Relay turned OFF");
   Connect to WiFi Network
void setup_wifi() {
  Serial.print("Connecting to WiFi");
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("\nWiFi connected");
  Serial.print("IP Address: ");
  Serial.println(WiFi.localIP());
   Reconnect to MQTT Broker
void reconnect() {
  while (!client.connected()) {
    Serial.print("Connecting to MQTT...");
    if (client.connect("esp32_relay_client",
                       mqtt_user,
                       mqtt_pass,
                       TOPIC_STATUS,
                       0,
                       true,
                       "offline")) {
      Serial.println("MQTT Connected");
      client.publish(TOPIC_STATUS, "online", true);
      client.subscribe(TOPIC_RELAY_SET);
    else {
      Serial.println("MQTT connection failed, retrying in 2 seconds...");
      delay(2000);
   Setup Function
void setup() {
  Serial.begin(115200);
  delay(2000);
  pinMode(RELAY_PIN, OUTPUT);
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  Serial.println("Relay system initialization completed");
   Main Loop
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
Modify these items according to your setup:
  • Replace YOUR_WIFI_SSID and YOUR_WIFI_PASSWORD with your WiFi credentials
  • Replace YOUR_MQTT_BROKER_IP with your Home Assistant IP (found in Settings → System → Network)
  • Replace YOUR_MQTT_USERNAME and YOUR_MQTT_PASSWORD with the MQTT user you created
In Arduino IDE, select Tools → Board → DFRobot FireBeetle 2 ESP32-C6, then Tools → Port and select the correct serial port.
Click Upload to compile and flash. Do not disconnect USB during flashing.
After successful upload, create an MQTT switch entity. Open configuration.yaml via File editor.
switch:
  - name: "C4002 Relay"
    unique_id: c4002_relay
    command_topic: "c4002/relay/set"
    state_topic: "c4002/relay/state"
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
Save, then restart Home Assistant: Settings → System → Restart Home Assistant.
Go to Settings → Devices & services → MQTT to see the relay switch entity.
Return to Overview, click Edit Dashboard.
Click + ADD CARD and select Switch.
Select C4002 Relay entity, set name to light, click Save.
You can now control the light via the dashboard switch.
When set to ON, Home Assistant sends command via MQTT → ESP32-C6 closes relay → light turns on → state updates to dashboard.
When set to OFF, relay disconnects and light turns off.
Step Three: Writing Automation Rules
The automation trigger should be “room occupancy status”. The entity sensor.esp32_c6_target_status_text returns three states. Convert it to a binary sensor for easier automation use.
Add this binary sensor configuration:
template:
  - binary_sensor:
      - name: "Room Occupancy"
        unique_id: room_occupancy_binary
        device_class: occupancy
        state: >
          {{ is_state('sensor.esp32_c6_target_status_text', 'Motion')
             or is_state('sensor.esp32_c6_target_status_text', 'Static Presence') }}
Save and restart Home Assistant.
Go to Settings → Developer tools → States, search for binary_sensor.room_occupancy. ‘on’ = occupied, ‘off’ = unoccupied.
Add to dashboard: Edit Dashboard → + Add Card → Entities Card → select Room Occupancy.
Create automation: Settings → Automations & Scenes → Automations → + Add Automation → Start with an empty automation.
Click ADD trigger → Entity → State.
Set Entity to Room Occupancy, To to Detected, For to 00:01:00. Trigger name: ‘when room occupancy changes to detected for 1m’.
Add condition to prevent false triggers (C4002 may detect people outside the room). Only activate when target is < 2 meters away.
Click Add condition → Template.
Enter:
{% set p = states('sensor.esp32_c6_motion_distance') | float(99) %}
{% set m = states('sensor.esp32_c6_presence_distance') | float(99) %}
{{ p < 2 or m < 2 }}
Click Add Action → Switch → Turn on, select C4002 Relay.
For auto light-off: + Add Automation → Start with an empty automation.
Trigger: Entity → State, Room Occupancy, To = Clear, For = 00:01:00.
Condition: Entity → State, C4002 Relay = On.
Action: Switch → Turn off, select C4002 Relay.
Click Trace to track automation execution.
On the dashboard, when someone enters: Room Occupancy changes from off → on. After 1 minute delay, relay closes and light turns on.
When room is unoccupied for 1 minute and light is on: relay turns off, light switches off.
Great absolute-beginner level guide !
I was with you until you mentioned MQTT. While MQTT does work … and I wouldn’t try to tell users already familiar with MQTT that they should change … for new users MQTT and arduino IDE are not necessary, and add extra complications.
Of course at this point I should say “fortunately I recently bought a mmWave radar so I will document the relevant section using the ESPHome’s Native API” … except that I want to get my current project finished before taking on another distraction :frowning_face:
Yes, in this setup I’m using a very basic off-the-shelf relay module that doesn’t have native support in ESPHome, so I integrated it into Home Assistant via MQTT. You can absolutely replace it with a smart switch that connects directly to Home Assistant, which means you won’t need MQTT or the Arduino IDE at all.
I also have another tutorial specifically on how to connect the C4002 to Home Assistant:Building a Native Home Assistant mmWave Presence Sensor with ESPHome on ESP32-C6 —hope that helps!
Hi @RoyLeo
Can you explain what the Area 1 through 3 Min & Max is for?
And what is Out Mode ?
DFRobot really sucks when it comes to documentation!
Made new fully functional external ESPhome component for DFRobot C4002 (SEN0691) based on official DFRobot library and listed here ESPhome component example by cdjq
Feel free to test and use it. I also exploring it as possible ld2410 replacement for my appt.
Here are all entities included:
Gates whose centre lies inside that range are disabled for both Move and Still detection.
Motion, Presene, Motion & Presence
I’ve named them user friendly in my ESPcomponent
