I currently have the problem that my home assistant cannot reach the home assistant versions page.
I have already read several posts, but with them the problem is that home assistant cannot update. With me the update card is not there at all?
This is my logging when i reload the HassIO supervisor:
20-02-09 19:49:17 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-02-09 19:49:22 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://version.home-assistant.io/stable.json: Cannot connect to host version.home-assistant.io:443 ssl:None [Try again]
When i open the link wich is provided in the logging then i see the JSON file.
What i’ve already done is restart home assistant completely. Also shutdown all addons.
I also deleted all backups to free up any space. But according to the system, only 6.4% has been used. I have a 64 GB card in it. So this should not be the problem either.
Maybe 1 of you has an answer for this.
