ctreu
(Christian)
May 17, 2019, 7:40am
42
Good morning,
Can somebody help with the mqtt integration?
“mqttenabled”: true,
“mqtturl”: “mqtt://192.168.178.57//MYmqttUser:MYmqttPassword@homeassistant”,
This way doesn’t seem to be right but I have no clue how to hand over the credentials for my mqtt sever.
Has anybody an idea?
ctreu
(Christian)
May 17, 2019, 3:04pm
43
Ok got it:
it is just: “mqtturl”: “mqtt://MYmqttUser:MYmqttPassword@homeassistant”,
without the IP
gapg1990
(Guillermo)
May 23, 2019, 11:33am
44
Just to confirm it works with my landroid M 2019 (WR143E). First, MQTT needs to be enabled in the addon configuration (together with the correct mqtturl information). Once the addon is connected succesfully to your MQTT broker, you can create sensors as follows:
platform: mqtt
state_topic: “landroid/status/statusDescription”
The addon logs tell what other topics can be read.
Msv1
May 31, 2019, 7:01pm
45
MrDje
(MrDje)
June 4, 2019, 7:32am
48
Ok so now everything is working fine, my Landroid S is recognized correctly and I can run it through the webUI, but does anybody know how to integrate it with homeassistant?
Like creating a button or sensor…?
Precision: I’m NOT using MQTT
gekomax
(Gekomax)
June 24, 2019, 9:13am
49
dvbit:
landroid bridge
How have you got installed and working?
zlax
(Andreas Svensson)
June 24, 2019, 10:44am
50
Hi, can some help me with my problem?
I am using the Landroid S addon from slaheij .
When I start the addon I get an error Mqtt url: undefined
[2019-06-23T07:35:15.464] [INFO] server.ts - Starting Landroid Bridge...
[2019-06-23T07:35:15.928] [INFO] server.ts - Setting port to 3000...
[2019-06-23T07:35:16.096] [INFO] Mqtt - Connecting to MQTT Broker...
[2019-06-23T07:35:16.108] [INFO] App - Adding static files path /usr/src/landroid-bridge/www
[2019-06-23T07:35:16.118] [INFO] Scheduler - Creating SQLite database at /data/scheduler.db
[2019-06-23T07:35:16.584] [INFO] LandroidS - Initializing Landroid Cloud Service...
Mqtt url: undefined
[2019-06-23T07:35:18.007] [INFO] IoBrokerAdapter - mower 0 selected
[2019-06-23T07:35:18.941] [INFO] LandroidS - First cloud update received, finishing initialization
[2019-06-23T07:35:18.942] [INFO] ScheduledTasks - Initializing scheduled tasks...
My config file look like this
"email": "[email protected] ",
"pwd": "9UVcEa2MEKySkmC",
"mqttenabled": true,
"mqtturl": "mqtt://user:password@homeassistant",
"mqtttopic": "landroid",
"loglevel": "info",
"scheduler_enabled": true,
"cron": false,
"weather_provider": "darksky",
"apikey": "733aa285cab887589cffc311a19aa7c4",
"latitude": 59.4686,
"longitude": 15.364,
"earliest_start": 7,
"latest_stop": 22,
"start_early": false,
"off_days": 2,
"square_meters": 300,
"per_hour": 50,
"mow_time": 75,
"charge_time": 75,
"days_for_total_cut": 2,
"rain_delay": 120,
"threshold": 30
Can anyone see what the problem is?
Is this the real config file? If so: you would have to insert the hostname or IP address of your MQTT server (instead of @homeassistant ).
zlax
(Andreas Svensson)
June 24, 2019, 11:52am
52
This is the config i can edit in hassio for the add-on.
after @ have tried to use my local IP and just typing in localhost but I get the same error.
like this “mqtturl”: “mqtt://user:[email protected] ”, and “mqtturl”: “mqtt://user:password@localhost”
dvbit
(Dvbit)
June 30, 2019, 8:35am
53
Yes but since then i sold the landroid
beejay
(Björn)
July 11, 2019, 9:01am
54
How to access Landroid Bridge HTTP REST Api?
steno
(Stefano)
July 24, 2019, 11:29pm
55
Ok sorry for the delay…actually nothing is showing in the frontend but you can use mqtt in order to show something
juice
(Juice)
August 8, 2019, 8:58pm
56
Did someone ever managed to get something into frontend?
Maybe someone would share their config?
As Msv1 posted, there is a project, that packages the worx landroid component:
DEPRECATED. This is old package that’s working with landroid_cloud integration version < 2.0.4
If you want a new custom landroid card, you can find it here
Hi all.
I make config for Worx Landroid M500 WR141E based on based on Landroid Cloud by @BlackChart
For details see here:
[Preview] [Preview] [Preview]
Update (02.11.2021):
Added support for:
Party Mode
Lock/Unlock
Edgecut service
Multizone support (not tested)
Please update images too
[/quote]
[- red text -]
Hi all.
I make …
The Sourcecode can be found here:
If you only want the thing to show up in your HA instance:
https://raw.githubusercontent.com/Barma-lej/halandroid/master/packages/worx_landroid.yaml
Regards,
Jakob
beejay
(Björn)
August 26, 2019, 12:16pm
58
I did.
First you have to enable accessing it via network by entering a port:
Afterwards you can access all values as you can see on Readings page and use them inside a rest sensor, e.g.
And you can even start or stop it via rest_commands:
Small hint: Within my start command I check whether my automation was already executed on the current day. So just for the first time my robot does the edge cut.
@beejay
Can you elaborate a little bit more as I am not sure how you did this on the api…?
I am using hass.io …
Did you use the bridge or not?
Or can somebody help me to install this the hassio version as I get an error.
Can anyone help me on installing this in hass.io ?
I get the following error when installing this in out of the store.
[hassio.docker.addon] Can’t build ceecc69e/amd64-addon-landroids:0.71: The command ‘/bin/ash -o pipefail -c npm run build-prod’ returned a non-zero code: 3
Anyone?
beejay
(Björn)
August 27, 2019, 7:49am
61
beejay
(Björn)
August 27, 2019, 7:50am
62
Did you restart your system? When I installed the hass.io addon I had some troubles and after some tries/restarts it worked
Thanks for the quick reply…
Yes I saw that post of “restarting”…did not help
And the error is pointing “nowhere” on google so I really need to solve this add-on to progress
Any help welcome
