[Custom Component] Tapo: Cameras Control
HomeAssistant - Tapo: Cameras Control
Custom component - Tapo: Cameras Control - to add Tapo cameras into Home Assistant
Installation
Copy contents of custom_components/tapo_control/ to custom_components/tapo_control/ in your Home Assistant config folder.
Installation using HACS
HACS is a community store for Home Assistant. You can install HACS and then install Tapo: Camera Control from the HACS store.
Requirements
Network
Following target TCP (v)LAN ports must be open in firewall for the camera to access your Tapo Camera from Home Assistant:
  • 443 - HTTPS for control of the camera (services)
  • 554 - RTSP to fetch video stream from the camera
  • 2020 - ONVIF to track detected movement via a binary sensor
These are not WAN ports, DO NOT OPEN WAN PORTS VIA PORT FORWARDING. You might need to open (v)lan ports only if you know what all of this means.
Usage
Add cameras via Integrations (search for Tapo) in Home Assistant UI. You can also simply click the button below if you have MyHomeAssistant redirects set up.
Open your Home Assistant instance and start setting up a new integration.
Cameras are also automatically discovered when they are (re)connected to WIFI.
To add multiple cameras, add integration multiple times.
See examples for lovelace cards.
Quick Start
This custom component creates:
  • Camera entities, one for HD and one for SD stream
  • Binary sensor for motion after the motion is detected for the first time
  • Light entity, if the camera supports a floodlight switch
  • Buttons for Calibrate, Format, Manual Alarm start & stop, Moving the camera, Reboot and syncing time
  • Switch entities for auto track, Flip setting, LED Indicator, Lens Distortion Correction and Privacy mode
  • Select entities for Automatic Alarm, Light Frequency, Motion Detection, Night Vision and Move to Preset
  • Number entity for Movement Angle
  • And finally 2 tapo_control.* services to control a camera
Use these services in following service calls.
tapo_control.save_preset
Saves the current PTZ position to a preset
  • name Required: Name of the preset. Cannot be empty or a number
tapo_control.delete_preset
Deletes a preset
  • preset Required: PTZ preset ID or a Name. See possible presets in entity attributes
Sound Detection
Integration is capable of analysing sound from camera microphone and expose noise detected via binary_sensor.
You need to enable this feature in integration options by checking “Enable sound threshold detection”. After enabling it, you can also set any other options starting with [Sound Detection]. You will need to restart Home Asssistant after doing any changes.
For more information and troubleshooting see Home Assistant ffmpeg documentation on which this feature is based on.
Troubleshooting | FAQ
Binary sensor for motion doesn't show up or work
Motion sensor is added only after a motion is detected for the first time.
  • Make sure the camera has motion detection turned on
  • Make sure the camera has privacy mode turned off
  • Make sure the camera can see you and your movement
  • Try walking in front of the camera
  • If above didn’t work, restart the camera and try again
Also make sure that:
  • binary sensor is not disabled via entity, check .storage/core.entity_registry for disabled entities, look for “disabled_by”: “user” on platform “tapo_control”. If it is, remove the whole entity or change to “disabled_by”: null, and restart HASS.
  • binary sensor is enabled in tapo integration options
  • onvif port 2020 on camera is opened
Big delay in camera stream
This is a known issue of Home Assistant.
There is an ability to disable usage of Home Assistant Stream component for the camera, which might lower the delay very significantly at cost of higher CPU usage.
You can choose to disable stream component when adding the camera, or via Options when camera has already been added. This change requires a restart of Home Assistant.
There might be some disadvantages to doing this, like losing option to control playback and a higher CPU usage.
Results depend on your hardware and future Home Assistant updates.
If you disable stream and your hardware is not up to the task, you will get artifacts, bigger delay and freezes.
If you wish, try it out and see what works best for you.
Another possibility is using WebRTC Camera by AlexxIT.
Example working configuration:
type: custom:webrtc-camera
entity: camera.bedroom_hd
No audio in camera stream
Supported audio codecs in Home Assistant are “aac”, “ac3” and “mp3”.
Tapo Cameras use PCM ALAW (alaw) which is not supported.
More details here.
You can get sound working using WebRTC Camera by AlexxIT.
Supported models
Users reported full functionality with following Tapo Cameras:
  • TC60
  • TC70
  • C100
  • C110
  • C200
  • C210
  • C310
  • C320WS
The integration should work with any other non-battery Tapo Cameras.
Battery cameras controlled via HUB are working only for control:
  • C420S2
If you had success with some other model, please report it via a new issue.
Have a comment or a suggestion?
Please open a new issue, or discuss on Home Assistant: Community Forum.
Join discussion on Discord.
Thank you
Buy Me A Coffee
Disclaimer
This integration is using python module Pytapo which is an unofficial module for achieving interoperability with Tapo cameras.
Author is in no way affiliated with Tp-Link or Tapo.
All the api requests used within the pytapo library are available and published on the internet (examples linked above) and the pytapo module is purely just a wrapper around those https requests.
Author does not guarantee functionality of this integration and is not responsible for any damage.
All product names, trademarks and registered trademarks in this repository, are property of their respective owners.
Spectacular - I have 3 Tapo camera’s (c100, 2 x c200) I’ll be trying this out on tonight. New to this HA lark but will do what I can to help out :slight_smile:
Some help for further development:
This is a Tp-Link C200, basic_info, info, and module_spec:
    "device_info": {
        "basic_info": {
            "device_type": "SMART.IPCAMERA",
            "device_model": "C200",
            "device_name": "C200 1.0",
            "device_info": "C200 1.0",
            "hw_version": "1.0",
            "sw_version": "1.0.14 Build 200720 Rel.38552n(4555)",
            "device_alias": "Tapo_Camera_XXXX",
            "features": "3",
            "barcode": "",
            "mac": "AA-BB-CC-DD-EE-00",
            "dev_id": "XXXXXXXXXXXXXXXXX",
            "oem_id": "XXXXXXXXXXXXXXXXXX",
            "hw_desc": "XXXXXXXXXXXXXXXXXXXXXX"
    "error_code": 0
    "device_info": {
        "info": {
            ".name": "info",
            ".type": "info",
            "fw_description": "C200 1.0",
            "product_id": "00c20000",
            "cur_isp_version": "14",
            "sensor": "SC2335",
            "sys_software_revision": "0x500a0100",
            "sys_software_revision_minor": "0x000e",
            "features": "3",
            "domain_name": "tplogin.cn",
            "language": "EN",
            "enable_dns": "1",
            "manufacturer_name": "TP-LINK",
            "friendly_name": "IPC",
            "model_description": "IPC",
            "manufacturer_url": "http://www.tp-link.com",
            "vendor_id": "0x00000001",
            "zone_code": "0x0",
            "roi_reg_num": "1",
            "cover_reg_num": "4",
            "md_reg_num": "32",
            "td_reg_num": "1",
            "plugin_obtain_way": "web",
            "product_type": "ipc",
            "up_fw_shared_prefix": "Tapo_C200v1",
            "unify_firmware_support": "1",
            "isp_version": "14"
    "error_code": 0
    "function": {
        "module_spec": {
            ".name": "module_spec",
            ".type": "module-spec",
            "app_version": "1.0.0",
            "led": "1",
            "change_password": "1",
            "local_storage": "1",
            "timing_reboot": "1",
            "motor": "1",
            "ota_upgrade": "1",
            "msg_push": "1",
            "msg_alarm": "1",
            "network": [
                "wifi"
            "events": [
                "motion",
                "tamper"
            "playback": [
                "local",
                "p2p",
                "relay"
            "preview": [
                "local",
                "p2p",
                "relay"
            "video_codec": [
                "h264"
            "audio": [
                "speaker",
                "microphone"
            "download": [
                "video"
            "record_type": [
                "timing",
                "motion"
            "record_max_slot_cnt": "10",
            "stream_max_sessions": "10",
            "streaming_support_versions": [
                "1.0"
            "relay_support_versions": [
                "1.3"
            "p2p_support_versions": [
                "1.1"
            "device_share": [
                "preview",
                "playback",
                "motor",
                "voice"
            "msg_alarm_list": [
                "sound",
                "light"
            "storage_api_version": "2.2",
            "playback_scale": "1",
            "lens_mask": "1",
            "target_track": "1",
            "wireless_hotspot": "1",
            "wifi_connection_info": "1",
            "video_detection_digital_sensitivity": "1",
            "client_info": "1",
            "ssl_cer_version": "1.0",
            "media_encrypt": "1",
            "multi_user": "0",
            "auth_encrypt": "1"
    "error_code": 0
This is a Tp-Link C100, basic_info , info , and module_spec :
    "device_info": {
        "basic_info": {
            "device_model": "C100",
            "device_name": "C100 1.0",
            "device_info": "C100 1.0",
            "sw_version": "1.0.2 Build 200306 Rel.41295n(4555)",
            "features": "3",
            "barcode": "",
    "error_code": 0
    "device_info": {
        "info": {
            ".name": "info",
            ".type": "info",
            "fw_description": "C100 1.0",
            "product_id": "00c10000",
            "cur_isp_version": "5",
            "sys_software_revision_minor": "0x0002",
            "features": "3",
            "language": "EN",
            "enable_dns": "1",
            "zone_code": "0x0",
            "roi_reg_num": "1",
            "md_reg_num": "32",
            "td_reg_num": "1",
            "up_fw_shared_prefix": "Tapo_C100v1",
            "isp_version": "5"
    "error_code": 0
    "function": {
        "module_spec": {
            "led": "1",
            "ota_upgrade": "1",
            "msg_push": "1",
            "msg_alarm": "1",
            "network": [
                "wifi"
            "events": [
                "motion",
                "tamper"
            "playback": [
                "local",
                "p2p",
                "relay"
            "preview": [
                "local",
                "p2p",
                "relay"
            "video_codec": [
                "h264"
            "audio": [
                "speaker",
                "microphone"
            "download": [
                "video"
            "record_type": [
                "timing",
                "motion"
                "1.0"
                "1.3"
                "1.1"
            "device_share": [
                "preview",
                "playback",
                "voice"
            "msg_alarm_list": [
                "sound",
                "light"
            "lens_mask": "1",
            "client_info": "1",
            "multi_user": "0",
            "auth_encrypt": "1"
    "error_code": 0
(I haven’t updated the firmware on this one yet.)
Version 1.0 has been released!
Initial release of Tapo: Cameras Control
New Features
  • Support for multiple cameras
  • Internal authentication does not expire and works even after reboot of a camera
  • Automatic update of all camera entities
  • Main attributes of camera for every entity, along with preset list
  • Full HACS compatibility
New services
  • tapo_control.ptz
  • tapo_control.set_privacy_mode
  • tapo_control.set_alarm_mode
  • tapo_control.set_led_mode
  • tapo_control.set_motion_detection_mode
  • tapo_control.set_auto_track_mode
  • tapo_control.reboot
  • tapo_control.save_preset
  • tapo_control.delete_preset
Details for services in readme.
Questions? Feedback? Bugs?
If you have any suggestions, questions or bug reports please open a new issue, or discuss on Home Assistant: Community Forum.
WOW! This works great, thank you for your good work!
Brilliant work. Thank you
VERSION 2.0 :tada:
It has been a few days since the first release, and I feel its a time for version 2.0 which is packed with a lot of awesome new features.
I would like to say special thank you to everyone who reported bugs or joined discussion on Home Assistant: Community Forum
New Features
  • Completely refactored the whole integration. Code is now a lot easier to read, simpler and up to current HASS standards.
  • Set up via Home Assistant Integrations UI, which also means, setup via configuration.yaml is no longer supported.
  • Automatically creates a new device in Home Assistant with its information like firmware, brand, model etc
  • Each device automatically creates 2 entities - HD and SD streams of camera platform
  • Camera stream is now available
  • Ability to format SD card of a camera
  • Better error handling and validation of service calls before they get executed
Minor updates
  • Integration now has an icon, brand and model
  • Added motion_detection and motion_detection_sensitivity attributes
  • Added privacy_mode attribute
  • Added alarm and alarm_mode attributes
  • Added led attribute
  • Added auto_track attribute
Breaking Changes
  • Integration is now set up via UI. You will need to remove tapo_control from configuration.yaml and set up integration using Home Assistant -> Configuration -> Integrations. Just search for tapo and add the cameras.
  • Entities of platform tapo_control are no longer created, camera platform is used instead.
  • Entity names now include _hd or _sd in the name. This does not affect services.
Great work! :pray:
Need to dig up my C200 from the junk again and try this!
Great work! Thank you!:+1:
Thanks for your great work!
How do you view and control your cameras inside the dashboard?
I created switches to use with a picture glance, but maybe there is are ways to optimize this, for example using some kind of joystick instead of switches for ptz.
Here are my switches:
    switches:
      camera_preset_default:
        value_template: "on"
        unique_id: cam1_preset_default
        turn_on:
          service: tapo_control.ptz
          data_template:
            preset: 1
            entity_id: camera.cam1_hd
        turn_off:
          data_template:
            preset: 1
    switches:
      camera_preset_down:
        unique_id: cam1_preset_down
        turn_on:
          data_template:
            preset: 2
        turn_off:
          data_template:
            preset: 2
    switches:
      camera_preset_up:
        unique_id: cam1_preset_up
        turn_on:
          data_template:
            preset: 3
        turn_off:
          data_template:
            preset: 3
    switches:
      camera_up:
        unique_id: cam1_up
        turn_on:
          data_template:
            tilt: UP
            distance: 0.1
        turn_off:
          data_template:
            tilt: UP
            distance: 0.1
    switches:
      camera_down:
        unique_id: cam1_down
        turn_on:
          data_template:
            tilt: DOWN
            distance: 0.1
        turn_off:
          data_template:
            tilt: DOWN
            distance: 0.1
    switches:
      camera_left:
        unique_id: cam1_left
        turn_on:
          data_template:
            pan: LEFT
            distance: 0.1
        turn_off:
          data_template:
            pan: LEFT
            distance: 0.1
    switches:
      camera_right:
        unique_id: cam1_right
        turn_on:
          data_template:
            pan: RIGHT
            distance: 0.1
        turn_off:
          data_template:
            pan: RIGHT
            distance: 0.1
    switches:
      camera_privacy:
        value_template: "{{ is_state_attr('camera.cam1_hd','privacy_mode' ,'on') }}"
        unique_id: cam1_privacy
        turn_on:
          service: tapo_control.set_privacy_mode
          data_template:
            privacy_mode: 'on'
        turn_off:
          data_template:
            privacy_mode: 'off'
I have tried to use the service to toggle privacy mode on and off but can only get it to toggle on
The command for toggle off doesn´t seem to work ?
Trying this via the Developer tools
How are you testing this? The app is buggy, you need to restart it, or not use at all (watch stream in hass instead). See this discussion, maybe you are dealing with the same thing.
You can also use something like this:
camera_image: camera.bedroom_hd
camera_view: live
entities:
  - entity: camera.bedroom_hd
    icon: 'mdi:palm-tree'
    tap_action:
      action: call-service
      service: script.set_bedroom_camera_away
    icon: 'mdi:home'
    tap_action:
      service: script.set_bedroom_camera_home
hold_action:
  service: python_script.set_camera
  service_data:
    entity_id: sensor.show_camera
    state: '70'
tap_action:
  action: more-info
title: Bedroom
type: picture-glance
Until someone creates a new lovelace component I think solution like these are the best we can get.
You where right. I was watching in the Tapo app and when restarting the app all was good.
Also checked in Hass and it workes great
am I correct in thinking that motion sensing state is not currently supported but camera feeds are? I assume I can combine T:CC with ONVIF to get both. If so what would people recomend as the preferred video source, stream via ONVIF or stream via T:CC?
@JurajNyiri - superb work sir :slight_smile:
Thank you :slight_smile:
Yes you are correct. It is planned for 2.1 as onvif is able to get the status, I should be able to replicate the logic inside this integration.
I have created many more feature requests I plan to implement in the future, I need help with this one specifically.
As in which stream to use, I have just checked onvif integration and internal code works exactly the same.
Version 2.1 has been released! :running_man:
New Features
Motion sensor
The first time your camera detects a motion it creates a new binary sensor. This sensor is updated in real time whenever there is a motion to on or off state.
After the next Home Assistant reboot, this sensor is restored with unavailable state until it detects motion again.
Motion sensor should recover from any reboots or disconnects of the camera automatically.
See the new troubleshooting section in readme if you have any questions regarding motion sensor before creating a new issue.
Camera image
Component now also provides an image of the current stream.
It generates it from the current stream on Home Assistant. While this is a common practice in other integrations too, we could do better and get the image directly from the camera instead. See this feature request if you would like to help.
New update coordinator
This release includes a rewrite of how updates are handled, resulting in 2 times reduction of number of requests outgoing camera while not affecting update speed.
Other minor updates
  • support for services camera.disable_motion_detection and camera.enable_motion_detection
  • support for services camera.turn_on camera.turn_off
Final remarks
If you need help…
Please open a new issue or a feature request, or discuss and ask for help on Home Assistant: Community Forum.
If you would like to help…
Join the discussion or see issues marked with help wanted.
There are already some examples going around with requests for more.
I would love to see what people already created with this camera on lovelace, so please open a PR and let’s share!
Created Discord server for support, research and discussion. Feel free to join! :slight_smile:
Would be possible to have those services implemented as entities where possible? Like motion detection being on or off could be a switch and the value would be updated by polling.
