Thanks. Is there any progress on this minor bug ? let me know if you have a beta version I could test if that can help you.
I can see, that not all have read this, even if it is quoted a few times… Please be patient, if you find bugs, open an issue on Github and meanwhile give people the chance to say, I’m out for a few days or weeks. Especially when these people say it upfront.
Hello
I’m struggling with centering my view buttons with CSS
(A nicey guy already tried to help me, but without luck: In this Thread)
I don’t know what to do next. Someone know how it could be done?
I would be very grateful for an answer: D
Hi
I’m lost.
Honestly.
Too many options with this custom header
Been trying all kind of mixed settings to reach my goal but none bring me so far.
Its so bad, that i cant get back to earlier things i had working.
What i want to reach:
- compact mode (only one line at top) containing:
- Alerts/notifications in my marquee
- a home button that brings me to my home page
- a menu button
All the rest , begone with it
My marquee is working, but compact mode isnt anymore (so its now disabled), and i cant get rid of my tabs anymore
My code:
background: var(--background-image)
custom_header:
background: 'rgba(155, 155, 155, 0.25)'
button_text: none
header_text: >-
<style>
#flipper {color:#999;}
#flip {height:24px;overflow:hidden;}
#flip > div > div {color:#fff;height:24px;margin-bottom:24px;display:inline-block;}
#flip div:first-child {animation: show 10s linear infinite;}
@keyframes show {
0% {margin-top:-144px;}
5% {margin-top:-96px;}
33% {margin-top:-96px;}
38% {margin-top:-48px;}
66% {margin-top:-48px;}
76% {margin-top:0px;}
100% {margin-top:0px;}}
#flipper p {position:fixed;color:#999; }
</style>
<div id=flipper><div id=flip><div><div>
Huidige buitentemperatuur: {{states('sensor.temperature')}}°C</div></div><div><div>
{{states('sensor.greeting')}}</div></div><div><div>
{{states('sensor.afval')}}</div></div><div><div>
compact_mode: false
reverse_tab_direction: true
reverse_button_direction: false
options_hide: true
show_tabs: false
shadow: false
title: Thuis
- !include lovelace/views/01-home.yaml
- !include lovelace/views/02-lichten.yaml
- !include lovelace/views/03-cameras.yaml
- !include lovelace/views/04-entertainment.yaml
- !include lovelace/views/05-cinema.yaml
- !include lovelace/views/06-automatisaties.yaml
- !include lovelace/views/13-server.yaml
- !include lovelace/views/14-network.yaml
- !include lovelace/views/15-energie.yaml
- !include lovelace/views/20-persoon1.yaml
- !include lovelace/views/21-persoon2.yaml
i dont use tabs to go to my views, cause i have buttons for that on my homepage “home” view
How it looks , even with compact view enabled:
Thanks in advance
Anyone? Really stuck here
I get errors in console too
custom-header.js:603 Uncaught TypeError: Cannot read property ‘shadowRoot’ of undefined
at styleHeader (custom-header.js:603)
at Function.processAndContinue (custom-header.js:603)
at unsub.subscribeRenderTemplate.template (custom-header.js:603)
at Object.r.subscribeMessage.type [as callback] (custom-header.js:1)
at l._handleMessage (connection.js:150)
at WebSocket. (connection.js:30)
edit: ok i found out why compact view didnt work, thats fixed (the line button_text was holding it back)
Now i still need to get the home button added
edit 2: i spoke too soon
my test pages shows only my message , like i want it to
custom_header:
header_text: >-
<style>
@keyframes show {
</style>
Herinnering: Vandaag {{states('sensor.ophaalkalender_vandaag')}} buiten zetten!</div></div><div><div>
compact_mode: true
reverse_tab_direction: false
options_hide: true
shadow: false
title: Thuis
- !include lovelace_test/views/01-Test.yaml
But my page which is online, doesnt show my messages but the tabs, i dont get it cause its the same code
custom_header:
header_text: >-
<style>
@keyframes show {
</style>
compact_mode: true
options_hide: true
shadow: false
title: Thuis
@mayker Can disabled_mode setting configured for each user?
I have the following snippet where default HA UI is shown based on input_boolean.ha_ui entity. But when I turned on this entity for User1 then default HA UI shows up for User2 (disabled_mode: true)
Is there any option to achieve this?
exceptions:
- conditions:
query_string: kiosk
config:
kiosk_mode: true
- conditions:
user: User1
config:
disable_sidebar: false
compact_mode: true
indicator_top: true
disabled_mode: '{{ states.input_boolean.ha_ui.state == "on" }}'
footer_mode: true
chevrons: false
menu_dropdown: true
button_text:
options: >-
<ha-icon icon='mdi:weather-{{
states.weather.dark_sky.state }}'></ha-icon> {{
states.weather.dark_sky.attributes.temperature }}°
<ha-icon style='padding-bottom: 3px' icon='mdi:numeric-{%if is_state('sensor.hacs', '0') -%}0-circle{% elif
is_state('sensor.hacs','1') -%}1-circle{% elif is_state('sensor.hacs',
'2') -%}2-circle {% elif is_state('sensor.hacs', '3') -%}3-circle {% elif
is_state('sensor.hacs','4') -%}4-circle{% elif is_state('sensor.hacs',
'5') -%}5-circle {%- else -%}{{states('sensor.hacs')}}{%- endif%}'></ha-icon>
- conditions:
user: User2
config:
hide_tabs: 1,2,3,4,5,6,7,8,9
default_tab: 0
hide_help: true
hide_config: true
hide_unused: true
voice_hide: true
menu_hide: true
disabled_mode: true
If i split up the custom header , its ± ok.
Only thing is, if i watch it on mobile phone, the top and bottom header stay at there place… is there a way to fix it?
say if i scroll down, the top isnt visible anymore, when im at bottom and i see the bottom header, its ok, if i scroll up, the bottom should stay at the bottom, now it goes up too
Is that possible?
Cause it disturbs the other stuff now
Hello, how do you hide the menu sidebar on a particular device? I use full kiosk browser.
Thank you in advance
Sorry, I overlooked this !
Morning Ryan. Sure you’ll be thrilled to know 0.110.0b0 has broken this. I get no menu at all at the top with this. Just a heads up.
https://Domain/hacsfiles/custom-header/custom-header.js:1:16344 TypeError: null is not an object (evaluating 'o[e].querySelector("paper-icon-button").style')
It looks like you have two unclosed <div>
tags at the end of your header_text option. This is likely to be breaking the formatting of the header.
I think those should either be removed or replaced with </div>
(hard to tell from my phone, but looks like the first two tags may not be closed off).
wont probably solve your tab issue, but are you sure your marquee flipper is working properly? you should have the first and last line to be identical, otherwise it wont flip fluently, and skip/jump irregular to the first line.
like this:
<div style='float: left'>Ha Rpi4: {{viewTitle}}: </div>
Summary - {{states('sensor.dark_sky_summary')}}</div></div><div><div>
Daily - {{states('sensor.dark_sky_daily_summary')}}</div></div><div><div>
Hourly - {{states('sensor.dark_sky_hourly_summary')}}</div></div><div><div>
as part of a bigger template:
header_text: >-
{% if is_state('input_boolean.ch_use_header_text_template','on') %}
{% if is_state('input_boolean.ch_vertical_marquee_up','on') %}
{% set keyframe = "@keyframes show {
100% {margin-top:-144px;}
83% {margin-top:-96px;}
67% {margin-top:-96px;}
50% {margin-top:-48px;}
33% {margin-top:-48px;}
17% {margin-top:0px;}
0% {margin-top:0px;}}" %}
17% {margin-top:-96px;}
67% {margin-top:-48px;}
83% {margin-top:0px;}
100% {margin-top:0px;}}" %}
<style>
#flipper{color:#999;}
#flip > div > div {color:var(--primary-text-color);height:24px;margin-bottom:24px;display:inline-block;text-overflow: clip;white-space: nowrap;}
{{keyframe}}
</style>
{% if is_state('input_select.mode','Developer') %}
<div style='float: left'>Ha Rpi4: </div>
User: {{user}},User_id: {{userID}}, Admin: {{isAdmin}}, Owner: {{isOwner}}</div></div><div><div>
User agent: {{userAgent|truncate(80)}}</div></div><div><div>
Device_id: {{deviceID}}, Title: {{viewTitle}}, Path: {{viewPath}}, Index: {{viewIndex}}</div></div><div><div>
{% else %}Ha Rpi4: {{viewTitle}}
Hey! how cool this app, supper tnx for building and maintenance. Recently I have been learning quickly how HassIo works and I came across this app when I started drafting a tablet for one music. I am now trying to set it up so that the tablet runs in kiosk and my main user still has normal UI: Per user / device configs I think. only now I can not get it to work and if I create a user without admin rights I can not set the app and if I assign admin rights to my Tablet account that changes over my UI. what am I doing wrong?
cheers Luuk
Will this allow me to change the blue header colour to an image per view ? For example i have the following at the top Home, Living Room , Bathroom etc and I’d like to have a different header background image for each different view . Hope this makes sense ?
Couldn’t tell you without seeing the config you are trying to use.
@JustineSmithies Yes, using header styling & header text inside per tab exceptions.
sorry, oke in the meen time i found time and had a look how this system works, I mest up the UI but think that now Im getting their:
custom_header:
compact_mode: true
exceptions:
- conditions:
user: Tablet
config:
background: 'rgba(255, 0, 0, 0)'
hide_help: true
menu_dropdown: true
show_tabs: true
default_tab: '5'
hide_tabs: '1 to 9, 0, home'
kiosk_mode: true
- conditions:
user: Tablet
user_agent: Mobile
media_query: '(max-width: 600px)'
config:
footer_mode: true
reverse_button_direction: true
- conditions:
query_string: kiosk
config:
kiosk_mode: true
title: UI
@mayker tnx for the help
@mayker
Welcome back, hope your RL situation has calmed down a little, and all your family is well and healthy!
Thanks! Things are still crazy, but starting to ease up a bit. We’re all fairly stressed, but doing well.
We all can only hope, that things ease up soon. Unfortunately i wouldn’t bet on that! Stay safe in these uncertain times!
Custom Header does not seem to work with HA 0.110.0 - No header showing - Had to use 1?disable_ch to restore original header.
