Custom Lovelace Card - Homekit style card
Hello @ DBuit,
thanks for your answer. I’m not that familiar with github, but I’ll try to leave a reminder entry there.
I am aware of the problem described above. If necessary, an implementation as described by you can be done.
Until then, my suggestion would be to leave out the background color for the type “custom tiles” (e.g. custom-button-card) and/or set it to transparent.
My problem is that if I set a light grey transparent background for the inactive state of a custom-button-card, this colour will always be overlaid by the main container (custom:homekit-card / <homekit-button></homekit-button>), i.e. an overlaying of transparent light grey with the colour white of the main container. So at the moment I can only use colors for the tile which have no transparency.
Example:
rgb(77, 90, 93) in custom-button-card -> ok
rgba(77, 90, 93, 0.5) in custom-button-card -> not ok because the white from main-container is in background. The result is a mix of that white and my color.
So if you just remove the background for custom-cards (your background parameters only for custom:homekit-card, else background none), i can do the rest with the options of the custom-card itself.
<homekit-button class="button on"> <!-- always white background -->
  <div class="button-inner">
    <card-maker ...>
      <button-card>
        <div>
          <ha-card ...> <!-- my custom card with my preferred, transparent background is overplayed by white from main-container -->
          </ha-card>
        </div>
     </button-card>
   </card-maker>
  </div>
</homekit-button>
No Background in main-container, problem solved.
Thanks getting blank tiles after the update
Weather card:
Camera’s using picture glance
Rolled back to 0.495 and working again.
Strange… you changed nothing to your config?
Any error in browser console?
No changes to config and did not see any console errors
Hey @DBuit how can we get the sliders in the card (so not from the popup)? I did slider: true and now its there, but invisible due to style. What style items can we change in the card? thanks!
thanks
check out this comment: Custom Lovelace Card - Homekit style card
V0.5 had a bug and tiles with another card in it would not load :frowning:
This is fixed now.
Added option for card and custom tiles to have an on/off state. Before they where always on.
Example:
                 - title: Wasmachine
                    entities:
                      - card: custom:mini-graph-card
                        entity: `here you set an entity and the state of this entity toggles the tile as on/off`
                        offStates: `Add a list of states that should display the tile as OFF al other states will be handled as ON`
                        noPadding: true
                        cardOptions:
                          entities:
                            - sensor.wasmachine_energieverbruik
@slipx06 can you update and let me know it is fixed for you?
@marschiaan i added the state option for card and custom tiles
@DBuit Weather card is working but my picture glance cards are still blank
Ok, thank you. I will give it a try this evening and send you my feedback. :smiley:
Strange can you share your config for the picture glance card?
Shared in my post above Custom Lovelace Card - Homekit style card
Good job. But on the mobile version there are white squares. It doesn’t seem to work properly.
and it doesn’t work on custom cards
Hey @DBuit the new update (051) doesnt work when using 2 cards in 1 (the thing you remotely helped me earlier) (here) when using row./column combination. If i revert to 050 it is working again:
0.51:
0.50 (WORKS!) But empty picture elements items or custom items in the square boxes…
I know you’re all doing this besides your job, work, family and such… Just wanna thank you once again for all your effort :slight_smile:
Good morning ,
Sorry i have an issue which i really i do not know how to fix , the cards got a strange behave , they do not get more yellow , and are only white , is there any cache somewhere hidden in HA to clean ?
on
off
and the configuration is this , which has no template no strange config, the light which have dimming , becomes whhite when on , the one which have no dim stay yellow , i would keep the yellow when on on every element.
what shoud i change ? what trigger light rgb in white , light normal in yellow ?
thanks
resources:
  - type: module
    url: /hacsfiles/bar-card/bar-card.js
  - type: module
    url: /hacsfiles/weather-card/weather-card.js
  - type: module
    url: /hacsfiles/lovelace-battery-entity/battery-entity.js
  - type: module
    url: /hacsfiles/button-card/button-card.js
  - type: module
    url: /hacsfiles/lovelace-card-mod/card-mod.js
  - type: module
    url: /hacsfiles/flex-table-card/flex-table-card.js
  - type: module
    url: /hacsfiles/lovelace-layout-card/layout-card.js
  - url: /hacsfiles/mini-media-player/mini-media-player-bundle.js
    type: module
  - type: module
    url: /hacsfiles/lovelace-slider-entity-row/slider-entity-row.js
  - type: module
    url: /hacsfiles/mini-graph-card/mini-graph-card-bundle.js
  - type: module
    url: /hacsfiles/upcoming-media-card/upcoming-media-card.js
  - type: module
    url: /hacsfiles/lovelace-darksky-card/lovelace-darksky-card.js
  - type: module
    url: /hacsfiles/vertical-stack-in-card/vertical-stack-in-card.js
  - type: module
    url: /hacsfiles/lovelace-auto-entities/auto-entities.js
  - type: module
    url: /hacsfiles/rgb-light-card/card.js
  - type: js
  - type: module
    url: /hacsfiles/custom-header/custom-header.js
  - url: https://cdn.jsdelivr.net/npm/rgb-light-card
    type: js
  - type: module
    url: /hacsfiles/simple-weather-card/simple-weather-card-bundle.js
    url: /hacsfiles/light-popup-card/light-popup-card.js
  - type: module
  - url: /hacsfiles/light-entity-card/light-entity-card.js
    type: module
  - url: /hacsfiles/decluttering-card/decluttering-card.js
    type: module
  - url: /hacsfiles/switch-popup-card/switch-popup-card.js
    type: module
  - url: /hacsfiles/swipe-card/swipe-card.js
    type: module
  - url: /hacsfiles/Homekit-panel-card/homekit-panel-card.js
    type: module
background: linear-gradient(32deg, rgba(131,58,180,1) 0%, rgba(55,127,226,1) 35%, rgba(255,137,137,1) 64%, rgba(252,176,69,1) 100%)
custom_header:
  background: 'rgba(0, 0, 0, 0.3);'
  compact_mode: true
  elements_color: rgba(10, 10, 10, 0.8)
  button_text:
    options: '{{ hours24 }}:{{ minutesLZ }}'
title: Home3
  # Here I'm defining the my View (my tab)
  - badges:
    icon: mdi:home
    cards:
      - type: "custom:homekit-card"
        useBrightness: true
        useTemperature: true
        titleColor: "#FFF"
        enableColumns: true
        statePositionTop: true
        tileHoldAnimation: true
        rows:
          - row: 1
            columns:
              - column: 1
                tileOnRow: 1
                entities:
                  - title: Test1
                    popup:
                      type: custom:light-popup-card
                      scenesInARow: 2
                      brightnessWidth: 130px
                      brightnessHeight: 350px
                      switchWidth: 110px
                      switchHeight: 300px
                    entities:
                      - entity: light.light1
                        icon: mdi:led-strip-variant
                        popupExtend:
                          actions:
                            - service: scene.turn_on
                              service_data:
                                entity_id: scene.bianco
                              color: "#FFF"
                        icon: mdi:lightbulb-group
                tileOnRow: 2 # Posizione
              - column: 2
                tileOnRow: 1
                entities:
                  - title: Test2
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                    entities:
                        icon: mdi:ceiling-light
                        popupExtend:
                          actions:
                              service_data:
                              color: "#FFF"
              - column: 3
                tileOnRow: 1
                entities:
                  - title: Test3
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                    entities:
                        popupExtend:
                          actions:
                              service_data:
                              color: "#FFF"
              - column: 4
                tileOnRow: 1
                entities:
                  - title: Test4
                    popup:
                      scenesInARow: 2
                      switchWidth: 110px
                      switchHeight: 300px
                    entities:
                      - entity: light.sonoff_sonoff
                        tap_action:
                          action: toggle
                          entity: group.all_lights
    panel: true
    path: home3
    title: home3
Just released V0.5.2 this should fix some white tiles with other cards.
I know the picture-glance card is not working for some reason :frowning:
Somehow the element is unkown so i won’t render the card really strange…
@martheijnen strange it is empty… can you try the new version? if it does not work can you check your console of the browser?
try to set the useBrightness and useTemperature to false
Hello everyone,
Just released V0.5.3 this should fix all the white card :slight_smile:
Thanks. Confirmed.
Yes, it works again
