Daily ZNP Zigbee Coordinator Backup Blueprint
You’ll be able to do a daily backup of your ZNP Coordinator data.
That may be usefull to restore your network to another Coordinator when it fails for some unfortunate reason.
DAILY BACKUP OF ZNP DONGLE: Open your Home Assistant instance and show the Daily Backup Blueprint pre-filled. which facilitates installation of zha_custom/backup_znp.yaml at 34e5a5013759d9b00adaf1aaeda702ad608d62b0 · mdeweerd/zha_custom · GitHub .
You need to install the zha_custom component providing the backup service GitHub - mdeweerd/zha_custom: "zha_custom" component for Home Assistant. Zigpy commands service wrapper .
Does this run even with zha running? Or does zha need to be stopped?
Backup runs with ZHA running. Restoring with ZHA running also works (but a restart is required after that).
The backup ran for me this night at 4AM and I used the blueprint to set this up.
The main difference between the backups I made already is the frame counter.
Daily backups will also help determine by how much the frame counter normally increases to set a better offset during restore. Mine increased about 50000 in one day.
If the frame counter is too far back it will take longer on restore for the network to get set up?
I suppose that it will restore eventuelly when the expected frame counter is reached.
I am not 100% sure, but I think it is there to protect from replays, so if the router or end device is expecting a minimum value, then your coordinator has to send at least as many packets before the target accepts the packet. That could be longer than a day as the coordinator might be sending less messages in case of communication issues.
I’m a little surprised this is not blown up yet I didn’t try it but this is something people were asking for and it doesn’t appear to be gaining traction.
You mean that the HA system should break because of the backup.
Anyway, I am using it in two locations and happily backup daily.
[core-ssh local]$ diff nwk_backup_10.json  nwk_backup_11.json
--- nwk_backup_10.json
+++ nwk_backup_11.json
@@ -4,7 +4,7 @@
         "format": "zigpy/open-coordinator-backup",
         "source": "[email protected]",
         "internal": {
-            "creation_time": "2022-01-10T04:00:02+01:00",
+            "creation_time": "2022-01-11T04:00:03+01:00",
             "zstack": {
                 "version": 3.0
@@ -22,7 +22,7 @@
     "network_key": {
         "key": "d232aca2c434309bd0e0dae5c074315c",
         "sequence_number": 0,
-        "frame_counter": 4741430
+        "frame_counter": 4791727
     "devices": [
Blown up as in a ton of comments that people are going to use it not broken whoops lol that was a bad choice of words. I am going to set this up today.
I didn’t realize there was another post with nearly 500 views I thought this was the only one.
I just set it up and it ran its first backup.
If I wanted to restore the configuration to another stick do I use the nwk_backup or the nvram_backup? When would I use either of those?
To restore, the nwk_backup is better IMHO. There is a parameter that allows increasing the TX Counter.
It’s also the method that was tested successfully, while the NVRAM restore did not work perfectly.
I am mainly backing up both because we can and you never know what kind of information can be useful.
500 views on the zha_custom post is not too bad, but with hindsight I expected the component to be used “more”. I dropped a message about the blueprint here so that things are annonced where you might look for them - proof is that you didn’t see the other post earlier !
Sounds good I just wasn’t sure if the Nvram was better as I never did an Nvram restore when switching between znp coordinators.
Yep I didn’t see the other post until days later. I’m glad I saw this though as this will be very helpful to restore backups if the coordinator dies which I have had quite a few hiccups with my sonoff ZigBee 3.0 coordinator. It will be especially helpful because zha does not have to be stopped in order for a backup to be performed which is a massive plus. I ended up getting 4 coordinators as backups in case a dongle dies as I rely on ZigBee for all of my lighting. Over 100 devices.
When I try to import the blueprint, i get an error “Unsupported domain” and it will not import.
I am on HA Blue, 2021.12.8. Any suggestions? I have never tried to import a blueprint before.
AFAIK Zigbee provides the possibility to have more than one coordinator in the network.
That should be to ensure coordinator redundancy - but it’s not something I see supported in the current (public) implementations.
I think that you need to install the zha_custom component first.
Each (custom) component is considered a domain.
I never knew that. I wonder how that works? When would one take over to avoid interference?
Thanks, I did try this(installing zha_custom first) as well. Not really sure why it would not work, so I manually added the automation, from looking at your blueprint. I’ll work on figuring out the why later, after I get some coffee… Thanks for the work on this, the first backup ran successfully.
[Solved] Adding (automation: !include automations.yaml) to my configuration.yaml was the issue. I had several automations in my automations.yaml, but they did not show up when going to Configure. After restarting, all the automations show up, and I am able to import a blueprint.
When you look here and there on the web you’ll read that multiple coordinators in a Zigbee network is not possible, but the Zigbee Spericiation (2.3.2.3.6 MAC Capability Flags Fields) indicates there is a bit "Alternate PAN Coordinator “this node is capable of becoming a PAN coordinator.”
So in full, there is only one PAN Coordinator at at time but it looks like there can be devices that could be come the coordinator.
Possibly this is a MAC sub-layer requirement and this was not specified for the Zigbee network.
I could not yet find an official document explaining how that works, but there was mention of it in microchip’s code.
So I assumed it’s possible because of that mention in the specification.
(Un)fortunately there is a paper about it though.
This suggests that there is no official method, but that it’s not impossible to do.
I had a quick look and it proposes to have a second device which acts as “backup router” that “pings” the coordinator and takes over after several unsuccessful pings.
The coordinator also sends network settings to the backup on a regular basis.
The switch implies that the backup “restarts” to the coordinator software and reuses the coordinator’s IEEE address.
So based on that, the Zigbee 2008 specification did not define how an “online” backup would work. And I do not think that has changed in the latest documents.
So there is no official method for a backup coordinator, but there is a proposal for what could be called a hack.
Interesting I’m certainly not a developer I wonder if puddly the zha developer in the future can work on that functionality.
If the restore functionnality can be done just with the service, then an automation might (almost) suffice:
  • Very regular backups of the original key;
  • Some method for monitoring - trigger in case of failure;
When triggered:
  • Ensure communication is disbled on the old key;
  • Change the port configuration;
  • Restore to the new key, already installed (but disabled);
  • Do the appropriate actions to enable the key key (could imply a restart of the core).
