In SSH running HA HW INFO the Conbee is on : - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1997160-if00
But cheking the addon logs i can see that it say it found on /dev/ttyACM0/
16:50:02:817 COM: /dev/ttyACM0 / serialno: DE1997160
16:50:02:817 COM: --dev: /dev/ttyACM0 (ConBee II)
Normally , my xiaomi motion sensors are in “not detected” state after 2 minutes of no movement… Now it takes 5 … Also in phoscon I see movement detected… What can be the cause? Battery failing? It’s only one sensor behaving like that, others are fine…
It’s still reporting 100% as battery state…
Thnx
EDIT: created an issue here, seems another user also confirming this issue after update to .74 ?
When I acess local to HA I can see all devices, but when I access from outside of my network (via duckdns or VPN - Wireguard) all my devices became unavailable.
Is there somewhere in deconz possible to see existing bindings between for instance a on/off switch and a lamp? I understand such bindings are stored in the switch, but I have found no way to verify that there is a binding but try to unbind a cluster and see what response I get.
You mean bindings configured in deCONZ? Because you can’t keep a binding when pairing them to deCONZ. You have groups created for all remotes which I guess are the bindings you are looking for?
When someone buy an Ikea roller blind and it is already paired with the switch that is included in the packaging, this pairing is then deleted when both are reset and included into deconz?
Yes, I know they get reset. But I wondered if this factory pairing could survive a reset. Reason I ask is that I have 3 blinds which works perfect when controlled from the UI in home assistant. I have also included one of the switches and on the deconz event from this switch, I set the position on all 3 blinds. But one of them behaves differently than the two others so I start wondering if the factory pairing is still there.
Not with the too little info you have provided. Just a simple question like WHERE are the lights not available? Phoscon? Home Assistant States page? Logs?
Are you sure it is only the deconz zigbee devices that are unavailable?
I don’t think your problem is related to deCONZ. I cannot see how it would be. The javascript running in your browser get the states from Home Assistant. Are you sure you are not just seeing the HA UI in browser cache and in reality have no connection at all?
I hope someone can help me out. I’m running HA in docker and Deconz installed as addon (docker img)
I’m trying to use the ‘node-red-contrib-deconz’ but i can’t figure out how to connect to the server.
I’ve tried to use the LAN ip of the machine running the docker, the docker IP of Home Assistant, the IP of the Deconz docker… i’ve tried ‘core-deconz’ as IP, but all i get is this;
That is a very strange problem you have. I have no clue. I see my zigbee device both with a normal open port through my router (with reverse proxy for the SSL layer) and I use Wireguard. I have never seen anything like you describe
