No I found this one that appears in the drop down list of the energy configuration. I have lots that are Wh
Well then I have no idea why I can’t add any of the iotawatt entities to the Energy dashboard then. It’s odd because I’ve simply followed the HA docs… It was easier using the custom component
Yeah not sure sorry. Im not using the offical add-on… Maybe try the Iotawatt thread as you did before?
Yeah, I just didn’t want to spam it too much with issues relating to the core integration since that thread is for the custom one. Will try anyway
Is there a way to manually correct the data on Energy Management? I had some networks issues yesterday and my Shelly EM3 was offline and came online one yesterday and twice this morning. So my daily, weekly and monthly are quite a bit off now. See the screens:
Day before yesterday, when everything was ok:
Yesterday:
Today:
I would be ok, if i can delete those two spikes and no data for those two days.
Turned out it was caused by Shelly EM3. After restar sometimes it will be unavailable and because of that calculation that sums three phases will be 0 for a brief moment and then back to where it really was. Trick was to add availability_template to the template sensor. More here: Shelly 3EM 3-phases Energy sensor - #56 by arva
But now i need to delete those spikes and I don’t know where.
EDIT: Here is a solution how you can delete from the DB: Energy Management in Home Assistant - #455 by markss
Thanks for sharing the instructions!
My issue was that Shelly EM was unavailable few times after restarts and template sensor that sums up three phases went to 0 and theb back to real value.
When i investigated database with SQLite Web I saw the problem with some 0 rows and sum lines that were affected. I deleted the 0 rows and corrected the SUM values with UPDATE. Now everything in DB looks good, but Energy Dashboard still shows the wrong numbers.
Any ideas, where the Energy Management gets the (wrong) data?
EDIT: If anyone is using HA in a Docker stack, SQLite Web works neatly with Docker Compose:
sqliteweb:
image: tomdesinto/sqliteweb
ports:
- 8089:8080
volumes:
- ${USERDIR}/docker/homeassistant/home-assistant_v2.db:/db/home-assistant_v2.db
command: home-assistant_v2.db
I have posted a new topic in community forum to suggest to add Water Heating as new source/consumption of energy on the top of Grid, Solar and Gas, for those who are connected to district heating or have solar water panel.
I am not speaking about water consumption…
see Add Water Heating as source of Energy
Cheers
Hi such a problem and I can not find a solution
database - mariadb.
1.After restart, HA added the entire value of the entity to me, not just the measured hour. How to avoid it, is there a way?
2. Is it possible to remove this result from the database so as not to disturb the whole?
There is a nice topic about this.
I am struggling to monitor energy in KWh from Tuya wifi plug with energy monitor.
Home Assistant recognize the value of the plug without problem:
So I created this sensor to convert the value of “Power (W)” in KWh:
- platform: integration
source: sensor.fridge_power
unit_prefix: k
unit_time: h
round: 2
Then I personalized the entity adding two custom field: state_class and last_reset.
In the developers tools it looks like this:
state_class: measurement
source: sensor.frigo_power
unit_of_measurement: kWh
friendly_name: KWh Fridge
icon: mdi:chart-histogram
device_class: energy
last_reset: '2000-01-01T00:00:00'
The problem is that I saw the entity in “Energy Monitor” on Home Assistant but with wrong value because it shows me a daily consumption of 3 KWh instead on Smart Life app I saw a daily consumption of 0.54 KWh.
I tried to convert by myself the value of the watt in kwh and HA is 100% wrong. Even if I add “method: left” or “method: right” nothing changed.
What am I doing wrong ?
Thanks.
Anyone can help me build a dynamic price entity ?
Per invoicing period, first 40kWh * days (For example 62 days @ 40kWh = 2480kWh), the price is .06159$.
Remaining kWh are .09502$
And I have a “grid fee” of .41168$ per day
Anyone can help ? (This is Hydro-Quebec by the way)
Thanks !
I hope that i have understand this, but who can explain me, where i can configure this? I mean maybe the chnage from KWh to kWh.
If it isn’t defined in anything you have setup then you can use CONFIGURATION>>CUSTOMIZATION
Let’s see if anyone can understand what I wish for here
In the energy management, I get my data partly from a pulse reader, attached to my electricity meter that the electricity company uses for billing me. And partly from individual devices, connected to smart plugs.
I really like the visualisation with the bars, showing how much has been consumed per hour/day/week etc.
However, I want the bars to concist of what’s been consumed TOTALLY (read from my energy meter) and how much of these bars have been consumed by individual devices. If i add individual devices as “Grid consumption”, sure enough they show up, but they make the totally consumed energy statistics wrong. Since they are already being accounted for in the reading from my electricity meter, they don’t need to be “added to the bar” again as extra consumption. I only want the bar to be broken down. For example "Hour x, total consumption from electricity meter: 10kWh
These 10kWh concists of 1kWh from freezer, 1kWh from cooler, 1kWh from dishwasher, 7kWh from googling HA energy setup".
In this way, it will be way more graphical and intuitive too see what’s been pulling electricity and when.
The consumption of individual devices that are shown under “Sources” does not provide a good graphical visualization and makes it harder to see how much a given device has “contributed” to the total consumption. If the bars could include how much an individual device has “contributed” to it, it would be way better.
I try to add a picture, perhaps some good soul will understand what i’m trying to say
Don’t add your household devices to grid consumption, add them as individual devices.
Thank you for your reply. I do have the devices added individually, but their consumption does not show up graphically on the bars. Would be a really helpful functionality if it did. Perhaps it can be solved?
As I’m just a beginner in this area. I wonder if I could add entities which come from my e3dc System. I get the values out of a Modbus integration in my configutation.yaml. Is there a solution for that?
Entities look like sensor.e3dc_xxx
- name: e3dc
type: tcp
host: 192.168.1.159
port: 502
sensors:- name: E3DC Solar Hausdach
unit_of_measurement: W
address: 40067
slave: 1
device_class: power - name: E3DC Batterie
address: 40069
slave: 1
device_class: power - name: E3DC Wallbox
address: 40077
slave: 1
device_class: power - name: E3DC Hausbezug
address: 40071
slave: 1
device_class: power - name: E3DC Netzbezug
address: 40073
slave: 1
device_class: power - name: E3DC Solar extern Garage
address: 40075
slave: 1
device_class: power - name: E3DC Wallbox solar
address: 40079
slave: 1
device_class: power - name: E3DC Autarkie
data_type: uint
address: 40081
slave: 1 - name: E3DC Batterie Ladung
data_type: uint
address: 40082
slave: 1 - name: E3DC emergency power state
data_type: uint
address: 40083
slave: 1 - name: E3DC_emergency_state
data_type: uint
address: 40084
slave: 1 - name: E3DC_Leistungsmesser-L1
data_type: uint
address: 40105
slave: 1 - name: E3DC_Leistungsmesser-L2
data_type: uint
address: 40106
slave: 1 - name: E3DC_Leistungsmesser-L3
data_type: uint
address: 40107
slave: 1
