Was hoping the HA green would be an easy to use device but as soon as I’ve plugged it in I’ve had problems. I’ve tried fixing it but I really have no idea what I’m doing.
So I’ve gone to 8123 and It’s come up with a whole heap of errors, mostly around the supervisor to connect to the internet??
Where should I start and what info do you need? I have the logs.
Fair enough.
I’ve searched a heap on the net and tried a lot of solutions but I’m not certain I’ve done it right.
Goal is to set up HA green. I’ve done what it says to do but I’m stuck at the first hurdle as there’s errors in 8123. Says it’s updated to the latest hassos.
I’ve got a million lines of logs that say there’s an error. I’ll send the first lot as a screenshot.
Thanks, I have looked at those threads, I have changed the primary DNS on my router to 8.8.8.8, didn’t seem to work. I turned off IPv6.
Tried re-flashing the HA - I followed the guide but I don’t know if it flashed it properly because the HA green continued to flash in a heartbeat pattern - not as it shows on the guide. Not sure why it didn’t work.
Could this also be why it didn’t flash the HA green? because it says it needs to be connected to the internet for that to work too. I mean, it’s plugged in and on my network, router app has said it’s received and sent a few kbps when I had a quick look.
Make sure your router’s time/date is correctly synchronised to the real time (NTP) of your timezone. Login into your router’s configuration and check its time/date and correct if necessary. Then retry the installation.
I can connect to X - 8123 - thats where I got the logs? Logs are new.
When I plugged the HA green into a screen and when to “info” it did know my timezone (country and state) but I couldn’t update it like they could in other posts - probably my fault.
Can’t see a setting where I can change the date/time in my router app.
Oh, I plugged it in today but I have been trying for a few days - it’s the 20th here now - 2:55pm. Maybe they are old logs? I assumed unplugging and starting again would update it.
Australian Central Standard Time GMT+9:30
Thursday, 20 June 2024, 2:57 pm
I have Tp Link Deco mesh (x10)
Can you explain how to check the port 23?
Sorry I’m not great with IT, hence the HA green haha.
