@anon63427907 I didn’t reboot my Raspberry Pi since you’ve talked about this captcha thing…
is this still an issue If the add-on or other part are restarted?
I’m asking the question because there a HACS update… if I have to reboot my RPI after the installation, I prefer to wait until there’s a fix for eufy security.
Hi Everyone,
I am sorry if I jump into the discussion but I’d like to ask you what is the best process to follow (I can see that a few have been discussed here) to use my Dufy cam pan & tilt camera with home assistant. My main goal is to trigger an automation when the camera detects movements.
This topic is all about Eufy security integration which is mentioned in first post. There is another thread called Eufy Camera Integration which involves multiple solution, but not here.
Hey @anon63427907 , first of all great job for creating the integration!
I was able to follow all the instruction and got your integration installed. I can see my camera preview working properly. My main goal is to setup an automation that performs few tasks as soon as the camera recognise the motions. I tried to use “Camera triggers” and other triggers (like sounds) but the automation never really start. Any suggestion on where to look for?
I am trying to set this up for the first time, got my bell and cameras today.
I have followed the instruction but I am stuck at 6.3 install the integration
I have added the custom respiratory, but there is no install button anywhere and the integration dosent show up when I search for eufy. I have redownloaded the integratio, removed and restarted multiple times before and after all changes… What am I missing?
Home assistant integration list is cached by browser, you should just wait or clear cookies or try incognito mode. This is not a specific thing for this integration, rather related to home assistant itself
Just to recap: in the Eufy Camera Integration post I posted the folllowing:
The solution is the one below:
However, I have no idea in what JSON I should be adding these. I was hoping to derive it from the screenshots, but that particular HA instance is in Russian. It’s probably a basic thing, but I am not a very experienced user. Are there any guides on these types of (JSON?) implementations and how to call for them as well?
