Fresh Installation Stuck on Preparing HA
After flashing the drive and installing I’m able to see the Welcome message and the URL info on RaspberryPi 4, but after waiting for “Preparing Home Assistant” I only get this message:
22-03-11 04:37:38 WARNING (MainThread) [supervisor.jobs] ‘Updater.fetch_data’ blocked from execution, no supervisor internet connection
22-03-11 04:37:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec´
I checked the config for Supervisor (supervisor_internet) is false, but I cant seem to find a way of changing it.
Help please.
Can anyone help me which ports I may need to open in the firwewall? Because I’m using a ISP provider router and it may be blocking some
We are talking about egress connections here: HA device → Internet. It should be just tcp port 80 and/or tcp port 443 and udp port 53 for domain name resloution which are almost certainly not blocked by your ISP.
Maybe you want to take a look at a List of TCP and UDP port numbers?
Thank you for the reply.
I tried pinging from it and even on DNS like google.com it says “alive” but it always shows on logs:
What HA installation type did you use for the RPI4? There must be more in the logs about the error than just the two lines you have posted. Try to dig deeper into the logs.
Sure there is the log before, but it keeps reloading for that previous message
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[07:35:13] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[07:35:13] INFO: Starting local supervisor watchdog...
22-03-11 07:35:20 INFO (MainThread) [__main__] Initializing Supervisor setup
22-03-11 07:35:20 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
22-03-11 07:35:20 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-03-11 07:35:20 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi4-64
22-03-11 07:35:20 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/aarch64-hassio-supervisor with version 2022.07.0
22-03-11 07:35:20 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
22-03-11 07:35:20 WARNING (SyncWorker_1) [supervisor.docker.interface] Can't find homeassistant/aarch64-hassio-supervisor for cleanup
22-03-11 07:35:20 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-03-11 07:35:20 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-11 07:35:20 INFO (MainThread) [__main__] Setting up Supervisor
22-03-11 07:35:21 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-03-11 07:35:21 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-03-11 07:35:21 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-03-11 07:35:21 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-03-11 07:35:21 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-03-11 07:35:21 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-03-11 07:35:21 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-03-11 07:35:21 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-03-11 07:35:21 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-03-11 07:35:21 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-03-11 07:35:21 INFO (MainThread) [supervisor.host.info] Updating local host information
22-03-11 07:35:22 INFO (MainThread) [supervisor.host.services] Updating service information
22-03-11 07:35:22 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-03-11 07:35:22 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-03-11 07:35:22 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-11 07:35:23 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-11 07:35:24 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-03-11 07:35:24 WARNING (MainThread) [supervisor.utils.whoami] Whoami service failed with SSL verification: Cannot connect to host services.home-assistant.io:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1129)')]
22-03-11 04:35:24 WARNING (MainThread) [supervisor.core] System time/date shift over more as 7days found!
22-03-11 04:35:24 INFO (MainThread) [supervisor.host.control] Setting new host datetime: 2022-08-02T16:20:10+00:00
22-03-11 04:35:24 CRITICAL (MainThread) [supervisor.core] Fatal error happening on load Task <coroutine object Core._adjust_system_datetime at 0x7fb58870c0>: DBus INT32 type "i" must be between -2147483648 and 2147483647
22-03-11 04:35:24 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2022.06.0'>]
22-03-11 04:35:24 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.06.0
22-03-11 04:35:24 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
22-03-11 04:35:27 INFO (SyncWorker_1) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.06.0 - 172.30.32.5
22-03-11 04:35:27 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2022.04.1'>]
22-03-11 04:35:27 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1
22-03-11 04:35:28 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
22-03-11 04:35:29 INFO (SyncWorker_1) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1 - 172.30.32.3
22-03-11 04:35:29 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-03-11 04:35:29 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2022.05.0'>]
22-03-11 04:35:29 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.05.0
22-03-11 04:35:29 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
22-03-11 04:35:31 INFO (SyncWorker_1) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.05.0 - 172.30.32.4
22-03-11 04:35:31 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2021.10.0'>]
22-03-11 04:35:31 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0
22-03-11 04:35:32 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
22-03-11 04:35:34 INFO (SyncWorker_1) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0 - 172.30.32.6
22-03-11 04:35:34 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2022.02.0'>]
22-03-11 04:35:34 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0
22-03-11 04:35:34 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
22-03-11 04:35:36 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0 - Host
22-03-11 04:35:36 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:35:36 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
22-03-11 04:35:36 INFO (SyncWorker_0) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi4-64-homeassistant
22-03-11 04:35:36 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant found.
22-03-11 04:35:36 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
22-03-11 04:35:36 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
22-03-11 04:35:36 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
22-03-11 04:35:36 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
22-03-11 04:35:38 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
22-03-11 04:35:38 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 8.4 / BootSlot A
22-03-11 04:35:38 INFO (MainThread) [supervisor.jobs] 'StoreManager.update_repositories' blocked from execution, no supervisor internet connection
22-03-11 04:35:38 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-03-11 04:35:38 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-03-11 04:35:38 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-03-11 04:35:38 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-11 04:35:38 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
22-03-11 04:35:38 INFO (MainThread) [__main__] Running Supervisor
22-03-11 04:35:38 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
22-03-11 04:35:38 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-03-11 04:35:38 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-03-11 04:35:38 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-03-11 04:35:38 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
22-03-11 04:35:38 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-03-11 04:35:38 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
22-03-11 04:35:38 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-03-11 04:35:38 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-03-11 04:35:38 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
22-03-11 04:35:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:35:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:35:38 INFO (MainThread) [supervisor.host.info] Updating local host information
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-03-11 04:35:38 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6Errors.run_check' blocked from execution, no supervisor internet connection
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-03-11 04:35:38 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-03-11 04:35:38 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerFailures.run_check' blocked from execution, no supervisor internet connection
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-03-11 04:35:38 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-11 04:35:38 INFO (MainThread) [supervisor.host.services] Updating service information
22-03-11 04:35:38 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-11 04:35:38 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-03-11 04:35:39 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-03-11 04:35:41 WARNING (MainThread) [supervisor.utils.codenotary] rpc error: code = Unavailable desc = connection error: desc = "transport: authentication handshake failed: x509: certificate has expired or is not yet valid: current time 2022-03-11T07:35:40Z is before 2022-07-29T07:23:35Z"
22-03-11 04:35:41 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.TRUST - ContextType.SYSTEM / None
22-03-11 04:35:41 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_INTEGRITY - ContextType.SYSTEM / None
22-03-11 04:35:41 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-11 04:35:41 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
22-03-11 04:36:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:36:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:36:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:36:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:37:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:37:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:37:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:38:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:38:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:38:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:38:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:39:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:39:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:39:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:39:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:40:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:40:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:40:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:40:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:41:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:41:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:41:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:41:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:42:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:42:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:42:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:42:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:43:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:43:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:43:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:43:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:44:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:44:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:44:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:44:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:45:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:45:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:45:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:45:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:46:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:46:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:46:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:46:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:47:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:47:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:47:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:47:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:48:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:48:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:48:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:48:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:49:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:49:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:49:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:49:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:50:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:50:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:50:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:50:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:50:39 INFO (MainThread) [supervisor.plugins.dns] Restarting CoreDNS plugin
22-03-11 04:50:39 INFO (SyncWorker_4) [supervisor.docker.interface] Restarting ghcr.io/home-assistant/aarch64-hassio-dns
22-03-11 04:50:45 INFO (MainThread) [supervisor.plugins.dns] Restarting CoreDNS plugin
22-03-11 04:50:45 INFO (SyncWorker_0) [supervisor.docker.interface] Restarting ghcr.io/home-assistant/aarch64-hassio-dns
22-03-11 04:51:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:51:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:51:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:51:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:52:08 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:52:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:52:38 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:52:38 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
You might want to check the date/time set on your RPI.
Sorry I didn’t answer, I use the official guide ( Home Assistant Operating System .), I flashed the newest version into the SD and turned it on.
I’m able to see the CLI but because supervisor has no connection the instalation is not successful
I’m sorry for my noobness,
But I’m trying to change the Timezone with timedatectl set-timezone "America/Sao_Paulo" but it says the file is read only.
When I try using sudo it says it doesn’t exists :frowning:
Are you using the SSH Client Addon for this?
What is
timedatectl | grep Time
saying?
I will just say the stpes i’m doing to be sure it’s the SSH Client Addon.
The Raspberrypi 4 booted into the SD then I can see the promt ha>, I type “login” then the command to update.
timedatectl | grep Time says: /bin/ash: can't create grep: Read-only file system
Is your Pi by any chance connected to your LAN through WiFi only? If so, continue tempoary by using cabled LAN. After the whole installion process has finished successfully you can continue through WiFi.
BTW, you marked your thread as resolved (Solution). Is it? :thinking:
I’m sorry I didn’t mean to mask as resolved, it’s still not solved.
It’s connected by cable
Read-only file system doesn’t sound good. I suspect this is the culprit of the errors you experience. Could be a faulty SD card. Use the search function of this forum with the keywords “Read-only file system”. You’ll find plenty of threads regarding the latter.
I’m afraid I have to pass at this point. I have plenty of experience with HA Supervised but less when it comes to HA OS. Maybe another community member can jump in?
Thank you Tamsy.
Just if you could advise me in which SD card would be a good one to buy?
Suggestion is avoid using SD cards; use SSD disks instead. SD cards are OK for casual burst writing (e.g. photography, videography), but not good for long term OS usage.
Thank you I will try using a SSD
I flashed the new installation into a SSD and the same error continues
22-03-11 07:35:22 INFO (MainThread) [__main__] Initializing Supervisor setup
22-03-11 07:35:22 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
22-03-11 07:35:22 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-03-11 07:35:22 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi4-64
22-03-11 07:35:22 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/aarch64-hassio-supervisor with version 2022.07.0
22-03-11 07:35:22 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
22-03-11 07:35:23 WARNING (SyncWorker_0) [supervisor.docker.interface] Can't find homeassistant/aarch64-hassio-supervisor for cleanup
22-03-11 07:35:23 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-03-11 07:35:23 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-11 07:35:23 INFO (MainThread) [__main__] Setting up Supervisor
22-03-11 07:35:23 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-03-11 07:35:23 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-03-11 07:35:23 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-03-11 07:35:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-03-11 07:35:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-03-11 07:35:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-03-11 07:35:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-03-11 07:35:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-03-11 07:35:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-03-11 07:35:24 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-03-11 07:35:24 INFO (MainThread) [supervisor.host.info] Updating local host information
22-03-11 07:35:24 INFO (MainThread) [supervisor.host.services] Updating service information
22-03-11 07:35:24 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-03-11 07:35:25 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-03-11 07:35:25 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-11 07:35:26 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-11 07:35:27 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-03-11 07:35:27 WARNING (MainThread) [supervisor.utils.whoami] Whoami service failed with SSL verification: Cannot connect to host services.home-assistant.io:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1129)')]
22-03-11 04:35:27 WARNING (MainThread) [supervisor.core] System time/date shift over more as 7days found!
22-03-11 04:35:27 INFO (MainThread) [supervisor.host.control] Setting new host datetime: 2022-08-05T18:11:43+00:00
22-03-11 04:35:27 CRITICAL (MainThread) [supervisor.core] Fatal error happening on load Task <coroutine object Core._adjust_system_datetime at 0x7f8bc470c0>: DBus INT32 type "i" must be between -2147483648 and 2147483647
22-03-11 04:35:27 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2022.06.0'>]
22-03-11 04:35:27 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.06.0
22-03-11 04:35:27 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
22-03-11 04:35:28 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.06.0 - 172.30.32.5
22-03-11 04:35:28 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2022.04.1'>]
22-03-11 04:35:28 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1
22-03-11 04:35:30 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1 - 172.30.32.3
22-03-11 04:35:30 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-03-11 04:35:30 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2022.05.0'>]
22-03-11 04:35:30 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.05.0
22-03-11 04:35:30 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
22-03-11 04:35:32 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.05.0 - 172.30.32.4
22-03-11 04:35:32 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2021.10.0'>]
22-03-11 04:35:32 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0
22-03-11 04:35:35 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0 - 172.30.32.6
22-03-11 04:35:35 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2022.02.0'>]
22-03-11 04:35:35 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0
22-03-11 04:35:35 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
22-03-11 04:35:36 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0 - Host
22-03-11 04:35:37 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
22-03-11 04:35:37 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
22-03-11 04:35:37 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
22-03-11 04:35:37 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
22-03-11 04:35:39 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
22-03-11 04:35:40 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 8.4 / BootSlot A
22-03-11 04:35:40 INFO (MainThread) [supervisor.jobs] 'StoreManager.update_repositories' blocked from execution, no supervisor internet connection
22-03-11 04:35:40 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-03-11 04:35:40 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-03-11 04:35:40 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-03-11 04:35:40 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-11 04:35:40 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
22-03-11 04:35:40 INFO (MainThread) [__main__] Running Supervisor
22-03-11 04:35:40 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
22-03-11 04:35:40 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-03-11 04:35:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-03-11 04:35:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-03-11 04:35:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
22-03-11 04:35:40 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-03-11 04:35:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
22-03-11 04:35:40 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-03-11 04:35:40 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-03-11 04:35:40 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
22-03-11 04:35:40 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:35:40 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:35:40 INFO (MainThread) [supervisor.host.info] Updating local host information
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-03-11 04:35:40 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6Errors.run_check' blocked from execution, no supervisor internet connection
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-03-11 04:35:40 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-03-11 04:35:40 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerFailures.run_check' blocked from execution, no supervisor internet connection
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-03-11 04:35:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-11 04:35:40 INFO (MainThread) [supervisor.host.services] Updating service information
22-03-11 04:35:40 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-11 04:35:40 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-03-11 04:35:40 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-03-11 04:35:43 WARNING (MainThread) [supervisor.utils.codenotary] rpc error: code = Unavailable desc = connection error: desc = "transport: authentication handshake failed: x509: certificate has expired or is not yet valid: current time 2022-03-11T07:35:42Z is before 2022-07-29T07:23:35Z"
22-03-11 04:35:43 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.TRUST - ContextType.SYSTEM / None
22-03-11 04:35:43 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_INTEGRITY - ContextType.SYSTEM / None
22-03-11 04:35:43 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-11 04:35:43 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy
22-03-11 04:36:10 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:36:10 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-03-11 04:36:40 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
22-03-11 04:36:40 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
I Looked into the error before the critical one,
Maybe it’s the 11:43+00:00 that is wrong? Cause i is usually minutes right? So it should be 11:43:00?
I can use timedatectl | grep Time now, it says Time one: Etc/UTC (UTC,+0000)
