Hi all – had posted as a separate topic but this probably belongs here! Can’t fix the redirect_uri_mismatch error…
I’ve followed instructions at https://www.home-assistant.io/integrations/nest/ . and https://developers.google.com/nest/device-access/get-started . Successfully registered in the DAC, enabled events, linked to GC platform, created OAuth 2.0 credentials, created a project, linked and authorised my account, configured the pub/sub pull subscription, got access/refresh tokens, listed devices thru curl, and made sure both google.com and my nabu casa URL are listed in the OAuth authorised redirects, etc etc. I can see messages (events) from my devices in the google cloud console fine and it all seems set up.
Where I’m falling down is the HA setup. I’ve added the client ID, secret, project and subscriber IDs to my config.yaml. When I try to set up the Nest integration, it asks me to choose a Google account, lists my devices with the permissions I’d previously selected, then when I click OK it dumps me to the redirect_uri_mismatch error:
I am using nabu casa and have tried my nabu casa address with and without port number, and with and without the /auth/external/callback. I can’t find any approach that works. I am accessing my HA instance using the external nabu casa URL to try and config.
Any hints on how I go about addressing this? Pun sorta intended
I notice the error message has a single “/” rather than “//” in “The redirect URI in the request, https:/xxxxxxxx/auth/external/callback” – Is that just from manually editing the url for including here?
You need to make sure the exact url in the redirect_uri_mismatch error is allowed in your oauth credentials that you created in the google console.
I tried to refresh my Nest integration and the thermostat still did not appear. I removed the Nest integration and readded it and it still did not appear. Any suggestions?
Thanks - this was just from editing out my nabu casa address.
I redid everything from scratch again, just in case I’d slipped up elsewhere, and I have no idea what I did differently but it now works - using the nabu casa address without port number and with the /auth/external/callback path appended
I was able to set up Google nest successfully following these instructions https://maartendamen.com/ha-nest-sdm, I can recommend it to everyone. everything worked fine. now I’ve read that some of them have also added the Google nest hub max in the HA … can someone explain to me how this is done? because mine were not recognized … only the nest doorbell was recognized.
My Hub’s camera was automatically detected and added, but crashes HA if I try and view a stream. I can see a still picture when the camera is active but I’m leaving it untouched until things progress further.
I was finally able to get my thermostat setup after following some of the detailed responses in here, thank you!
One question that I haven’t been able to find the answer to anywhere else: are additional temperature sensors supported? I have one additional sensor connected to my thermostat but it does not show up in HA under the Nest entities.
Still have issues with my Thermostat Card Updating. I can change it just fine, but the temp sensor doesnt seem to be changing. It only updates when I restart HA. Thoughts?
Not receiving updates is most likely a problem with the subscriber_id. The integration instructions have been updated to make that more clear that it needs to be the full subscription name including the path.
