HA in docker: hassio & raspberry-pi: invalid config
Dear community,
a couple of days ago, I moved my HA-config-files from a raspberry pi to a docker container. I was surprised, how easily that was and that everything was working more or less at first try.
I do have two error messages, which cause is obvious, but I don’t know, how to get rid of them:
2023-01-06 23:41:24.302 ERROR (MainThread) [homeassistant.components.hassio] Missing SUPERVISOR environment variable
2023-01-06 23:41:24.304 ERROR (MainThread) [homeassistant.setup] Setup failed for hassio: Integration failed to initialize.
2023-01-06 23:41:26.725 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of raspberry_pi. Setup failed for dependencies: hassio
2023-01-06 23:41:26.725 ERROR (MainThread) [homeassistant.setup] Setup failed for raspberry_pi: (DependencyError(...), 'Could not setup dependencies: hassio')
I have deleted the raspberry pi integration, but the error seems to stay. Is there some configuration or code that I have to delete? Where?
Any help is very much appreciated.
Hi, anybody could help?
There are two other discussions about the same question. Both indicate a solution, without going into specific details.
I will try that and see, if I can provide some more details.
Container version doesn’t have supervisor so the hassio integration won’t load. Remove it.
Hi @petro,
thank you for your input. I have deleted the “integration” regarding raspberry (and hassio?), but the error keeps coming up. There must be something deeper down in the system.
The other two discussions implied to search through /config/.storage folder. I wanted to do a quick backup, before doing that. Or have you got a better idea?
Shouldn’t be anything else. Just restart your system and the rrrors should be gone
The errors are still there. I did a quick search through all files in the storage-folder. Is one of those entries responsible for the two errors?
Suche "hassio|rpi|rasp" (48 Treffer in 4 Dateien von 33 gesucht)
  C:\Users\schneich\Documents\Docker\HomeAssistant\config\storage\core.config_entries (3 Treffer)
	line  58:         "source": "hassio",
	line 377:         "domain": "raspberry_pi",
	line 378:         "title": "Raspberry Pi",
  C:\Users\schneich\Documents\Docker\HomeAssistant\config\storage\core.device_registry (9 Treffer)
	line 615:             "hassio",
	line 627:             "hassio",
	line 639:             "hassio",
	line 651:             "hassio",
	line 663:             "hassio",
	line 675:             "hassio",
	line 687:             "hassio",
	line 699:             "hassio",
	line 711:             "hassio",
  C:\Users\schneich\Documents\Docker\HomeAssistant\config\storage\hacs.repositories (34 Treffer)
	line  2033:         "name": "RPi Monitor Card",
	line  2034:         "filename": "rpi-monitor-card.js"
	line  2037:       "description": "A Raspberry Pi status display Card for Home Assistant Lovelace",
	line  2041:       "full_name": "ironsheep/lovelace-rpi-monitor-card",
	line  2047:         "raspberry-pi"
	line  6232:       "full_name": "And3rsL/VisonicAlarm-for-Hassio",
	line  6342:       "full_name": "Antoni-Czaplicki/vulcan-for-hassio",
	line  7872:       "description": "hassio support for Airthings Wave BLE environmental radon sensor.",
	line  9914:       "full_name": "GuilleGF/hassio-ovh",
	line 13376:         "hassio-integration",
	line 13611:         "raspberry-pi",
	line 15894:         "raspberry-pi",
	line 17896:         "hassio-integration",
	line 19659:         "name": "Raspberry Pi GPIO",
	line 19666:       "description": "Home Assistant Raspberry Pi GPIO Integration",
	line 19667:       "domain": "rpi_gpio",
	line 19669:       "full_name": "thecode/ha-rpi_gpio",
	line 19674:         "raspberry-pi",
	line 19675:         "rpi-gpio"
	line 20124:         "name": "Raspberry Pi RF",
	line 20131:       "description": "Home Assistant Raspberry Pi GPIO RF Integration",
	line 20132:       "domain": "rpi_rf",
	line 20134:       "full_name": "markvader/ha-rpi_rf",
	line 20139:         "rpi-gpio",
	line 20140:         "rpi-rf"
	line 21056:         "hassio-integration"
	line 21237:         "hassio-integration",
	line 21355:         "hassio-addons",
	line 21356:         "hassio-integration",
	line 21695:         "hassio-integration",
	line 21997:         "name": "Raspberry Pi 1-Wire via sysbus",
	line 22012:         "raspberry-pi"
	line 22743:         "hassio-integration",
	line 25291:         "hassio-integration",
  C:\Users\schneich\Documents\Docker\HomeAssistant\config\storage\hassio (2 Treffer)
	line 3:     "key": "hassio",
	line 5:         "hassio_user": "7739eb1286284c94..."
It would be the config entry
Dear @petro,
Yesterday, I had a closer look into that json (… .storage\core.config_entries) and deleted the respective entries. Well, HomeAssistant gave me some errors afterwards and stopped working.
Here are the relevant parts of that file: there is the new mqtt-configuration, which seem to reference “hassio”. Because the mqtt-app doesn’t work in docker, I have set up an external mqtt-broker on 192.168.70.4. So this is nothing, I want to delete? Or do I have to reconfigure it?
  "version": 1,
  "minor_version": 1,
  "key": "core.config_entries",
  "data": {
    "entries": [
        "entry_id": "6fec6457332d25e8931e528cdf7fxxxx",
        "version": 2,
        "domain": "openweathermap",
        "title": "OpenWeatherMap",
        "data": {
          "name": "OpenWeatherMap",
          "latitude": 47.xx,
          "longitude": 8.xx,
          "mode": "hourly",
          "language": "de",
          "api_key": "31f6e299e2c34cb5ee28f74bxxxxxxxx"
        "options": {
          "mode": "onecall_hourly",
          "language": "de"
        "pref_disable_new_entities": false,
        "pref_disable_polling": false,
        "source": "user",
        "unique_id": "47.xx-8.xx",
        "disabled_by": null
        "entry_id": "39720229beb8d8ed9a1105bee948xxxx",
        "version": 1,
        "domain": "mqtt",
        "title": "192.168.70.4",
        "data": {
          "broker": "192.168.70.4",
          "port": 1883,
          "username": "hamqxx",
          "password": "xxxx322f3afc506e70b6850201d85780a3fff5e0axxx",
          "discovery": true,
          "discovery_prefix": "homeassistant",
          "birth_message": {
            "topic": "homeassistant/status",
            "payload": "online",
            "qos": 0,
            "retain": false
          "will_message": {
            "payload": "offline",
            "qos": 0,
            "retain": false
        "options": {},
        "source": "hassio",
        "unique_id": null,
        "disabled_by": null
Then, later on in line 377 and 378 of the same file, there is the reference to the raspberry. This is probably something, I could easily remove?
        "entry_id": "8c6a9fc45ef3b35eac1eff5669e5729c",
        "version": 1,
        "data": {},
        "options": {},
        "source": "system",
        "unique_id": null,
        "disabled_by": null
All references to hassio in the core.device_registry are under the deleted devices. Can they stay there or should I remove those entries from that file?
What is the …storage\hassio file about? Should I remove the file or just its content?
    "version": 1,
    "key": "hassio",
    "data": {
        "hassio_user": "7739eb1286284c94xxx"
Thank you very much and best regards,
Chris
I did some more testing: deleting this entry did it (see below). No more errors relating to raspberry or hassio in the logs after booting the HomeAssistant Container.
…/.storage/core.config_entries
        "version": 1,
        "data": {},
        "options": {},
        "source": "system",
        "unique_id": null,
        "disabled_by": null
I’m having similar issues. How do I remove the hassio integration? It’s not listed on the Integrations page.
Hi @ehn ,
I did not have to remove hassio, but I went to the …storage/core.config_entries and deleted the reference to the Raspberry pi. That solved the issue and removed the hassio error as well.
Yeah, that worked. Thanks!
In my case, I was migrating from a Home Assistant Blue and had to look for occurrences of “odroid” and “hardkernel”.
