Yeah I see that message, and I also see that itās both āSettingā¦ā and āGetting state via online APIā when I click the slider.
Iāve changed the log setting to Debug. Here are the debug logs after āSettingā¦ā
2018-08-05 09:59:41 INFO (SyncWorker_6) [pywink.api] Setting state via online API
2018-08-05 09:59:42 DEBUG (SyncWorker_6) [pywink.api] {'data': {'object_type': '
binary_switch', 'object_id': '805077', 'uuid': '68b63aab-92d4-4bdf-9019-863bee02
70a9', 'created_at': 1533441782, 'updated_at': 1533442414, 'icon_id': '258',
'icon_code': 'binary_switch-ihome_smartplug', 'desired_state': {'powered': False},
'last_reading': {'connection': True, 'connection_updated_at': 1533441782.9732275
, 'powered': True, 'powered_updated_at': 1533441782.9732275, 'desired_powered':
False, 'desired_powered_updated_at': 1533484782.0335011, 'connection_changed_at':
1533441782.7954407, 'powered_changed_at': 1533441782.9732275, 'desired_powered
_changed_at': 1533484782.0335011}, 'subscription': {'pubnub': {'subscribe_key':
'sub-c-f7bf7f7e-0542-11e3-a5e8-02ee2ddab7fe', 'channel': '54ba64bfc32b44ce6c5673
b43a03831b9a5e4e68|binary_switch-805077|user-910251'}}, 'binary_switch_id': '805
077', 'name': 'Back Porch Lights', 'locale': 'en_us', 'units': {}, 'hidden_at':
None, 'capabilities': {'fields': [{'type': 'boolean', 'field': 'connection',
'mutability': 'read-only'}, {'type': 'boolean', 'field': 'powered', 'mutability':
'read-write'}]}, 'triggers': [], 'manufacturer_device_model': 'ihome_i_sp100',
'manufacturer_device_id': 'UpgggxA8GDQeVewRw4Q8ym7c', 'device_manufacturer':
'ihome', 'model_name': 'SmartPlug', 'upc_id': '1213', 'upc_code': 'ihome_UGUsr6pMeD8w
9pRRahWr9Pcq', 'primary_upc_code': 'ihome_isp100_smartplug', 'gang_id': None,
'hub_id': None, 'local_id': None, 'radio_type': None, 'linked_service_id': '1098872',
'current_budget': None, 'lat_lng': [None, None], 'location': '', 'order': 0}
, 'errors': [], 'pagination': {}}
And here are the logs after āGettingā¦ā
2018-08-05 09:59:42 INFO (SyncWorker_13) [pywink.api] Getting state via online API
2018-08-05 09:59:42 DEBUG (SyncWorker_13) [pywink.api] {'data': {'object_type':
'binary_switch', 'object_id': '805077', 'uuid': '68b63aab-92d4-4bdf-9019-863bee0270a9',
'created_at': 1533441782, 'updated_at': 1533442414, 'icon_id': '258', 'icon_code':
'binary_switch-ihome_smartplug', 'desired_state': {'powered': False}, 'last_reading':
{'connection': True, 'connection_updated_at': 1533441782.9732275, 'powered': True,
'powered_updated_at': 1533441782.9732275, 'desired_powered': False,
'desired_powered_changed_at': 1533484782.0335011}, 'subscription': {'pubnub':
{'subscribe_key': 'sub-c-f7bf7f7e-0542-11e3-a5e8-02ee2ddab7fe', 'channel':
'54ba64bfc32b44ce6c5673b43a03831b9a5e4e68|binary_switch-805077|user-910251'}},
'binary_switch_id': '805077', 'name': 'Back Porch Lights', 'locale': 'en_us', 'units': {},
'hidden_at': None, 'capabilities': {'fields': [{'type': 'boolean', 'field': 'connection', 'mutability':
'read-only'}, {'type': 'boolean', 'field': 'powered', 'mutability': 'read-write'}]}, 'triggers': [],
'manufacturer_device_model': 'ihome_i_sp100', 'manufacturer_device_id':
'UpgggxA8GDQeVewRw4Q8ym7c', 'device_manufacturer': 'ihome', 'model_name':
'SmartPlug', 'upc_id': '1213', 'upc_code': 'ihome_UGUsr6pMeD8w9pRRahWr9Pcq',
'primary_upc_code': 'ihome_isp100_smartplug', 'gang_id': None, 'hub_id': None, 'local_id':
None, 'radio_type': None, 'linked_service_id': '1098872', 'current_budget': None, 'lat_lng':
[None, None], 'location': '', 'order': 0}, 'errors': [], 'pagination': {}}
