HACC - Home Assistant Command Center
Hi all,
I wanted to give you a status update before the holidays arrive!
First, thank you @fishertimj for your support! I have been meaning to e-mail you but with the holidays things are a little crazy! :slight_smile: I promise I will though!
Second, I wanted to outline some goals for what would essentially be “HACC v1.0”.
Technical Goals
  • Upgrade project and Docker images to use .NET Core 3.1 (the latest LTS release of the platform)
  • Convert the Docker images to have multi-arch support so that we can release a single “HACC” image that works on amd64, armv7, armv8, etc.
  • Convert HACC from a polling-based architecture to instead utilize HA’s WebSocket API to receive real-time state updates (don’t ask why it wasn’t like this from the start :roll_eyes:)
Project Goals
  • Add support for Pages (this is actually already done and merged! Just need to test it!)
  • Finish up some of the other requested tiles and features in the Version 1.0 Milestone (Currently at 4/14 completed)
    • Not all of these will likely make it into v1.0 - due to the significant architecture changes that have to happen between upgrading the framework version, changing to websockets, and redoing the Docker images, we may have to push some of these back to v1.1 or later.
    • For this reason, you should thumbs up :+1: enhancements on GitHub that you want to see - I will use the votes to determine priority!
  • Set up a Themes page on GitHub to offer up some OOTB themes / community themes for download
  • Set up a website! (I own http://hacc.dev/ but it just redirects to GitHub right now.)
I am hoping to get some of this work done during the holidays and around the new year, and I will try and post some status updates in this thread as things are completed. I know that back-end architecture updates are not exactly exciting, but trust me when I say that HACC will be a lot better and a lot faster when v1.0 is released.
Thanks for your patience, and Happy Holidays! :santa: :christmas_tree:
Hey
Can’t get it to load up on my device, is it because of webview version 30? :frowning:
@CountParadox Check this compatibility table: https://developer.chrome.com/multidevice/webview/overview#does_the_new_webview_have_feature_parity_with_chrome_for_android_ (Not that HACC uses any of those technologies but just to demonstrate that it is not going to work well with newer web stuff.)
Seems like WebView 30 is super out of date. Can you update your device to use WebView 36 or somehow install a newer version of Chrome/Chromium?
I use a tablet at home that has Android Go installed on it and that works really well - I’m not super familiar with the whole Android ecosystem but perhaps you could update your OS to that as another option?
webview is built into android, not chrome (in this case) :frowning: it has the latest chrome installed…
I cant install a new android as theres none available for this device… rip
:frowning: Sorry about that. Maybe wait for v1.0 and see if that works - I will be refactoring some of the JavaScript on the frontend so it may work (no guarantees though).
I know buying new hardware is not a “solution”, but in case anyone is curious, this is the 8" tablet that I run for HACC. It works well. You could even go down to a 7" tablet for even cheaper.
I will see how it goes.
I have plenty of android tablets with more modern android, but this one has is designed to be always on and has PoE :’)
its very clean with no front or outer buttons, and has a wall mount built in…
wooo great ! Can’t wait to see the version 1.0 :slight_smile:
FYI, you can track the progress of the v1.0 work on the new GitHub project board I just created:
HACC v1.0 Project Board on GitHub
Get this error and therefore not possible to update
  File "/config/custom_components/hacs/hacsbase/__init__.py", line 304, in recuring_tasks_installed
    await self.factory.execute()
  File "/config/custom_components/hacs/hacsbase/task_factory.py", line 24, in execute
    await asyncio.gather(*self.tasks)
RuntimeError: cannot reuse already awaited coroutine
Hey @John_P I think you have the wrong thread! :slight_smile:
HACC = Home Assistant Command Center - tablet dashboard for HA (you are here :round_pushpin:)
HACS = Home Assistant Community Store - add-on store for HA
Please refer to this thread: Custom Component: HACS
This is a GREAT tool! Thank you for all of your work!
Might I suggest that the State tile allows custom “closed/open” states for door switches?
Thank you!
-Adrian
I have exactly the same problem, Base URL is set correctly to the external url for HA (in my case this is a reverse proxy), and it shows this in the /admin/technical page. Unfortunately HACC tries to source the image for entity_picture from:
url(“/local/me.jpg”)
and displays nothing, because it would need to use a different webserver.
If I change the entity_picture value to be fully qualified (ie https://myhome.com/local/me.jpg) then the picture loads, but only after I’m forced to authenticate past my reverse proxy. Its also not the ‘correct’ way of setting an entity_picture, so I wonder what else I might break
Hi @tseeley, as part of this PR, to be released in 1.0, I added support for an “Override Asset URL” which will allow you to override the base URL that is used for media and image assets. So in cases where it’s not able to resolve this correctly, you will be able to set “https://myhome.com” as the override asset URL and it should load your pictures properly.
Version 1.0 Update
I wanted to give everyone a brief update about Version 1.0. I know that many of you are eagerly awaiting it, however during testing, I discovered that the way I had set up communication between the app and Home Assistant would work for people generating their own long-lived access tokens, but would not work for people installing via the Supervisor Add-on interface due to the way tokens are handled. (This issue covers it in a bit more detail.)
So, I am currently working on updating the app to support installation as an add-on. Testing is difficult and slow because I have to fully compile the app and deploy it into an add-on container with every change I make. I am making progress though.
I will keep everyone posted as developments happen. Again, I know you are all eagerly awaiting 1.0 and I appreciate your patience!
any chance to add instructions for raspbian?
there are instructions only for docker
Docker works on raspbian.
@nickrout is correct - there are no special instructions for Raspbian specifically - you would just need to use Docker and match your system architecture (ARM32v7 or ARM64v8) - there are images for both.
Hi Jake!
I was having trouble with “too many redirect” messages in my original Docker installation of HASS. It was working fine until it wasn’t. :slight_smile: Not sure what happened.
Just removed the container and image and started over from scratch and now I’m getting a 500 error when I try to access the service at port 8095.
Any ideas?
