I ended up using a button card (also ported to a Mushroom chip for a different dashboard, but same general idea). The inclusion of error states was helpful when I was using the Zooz tilt sensors since occasionally they’d get in a weird state. Ultimately I moved to hardwired reed sensors (Tane 66) and have been much happier.
Doors Closed
Door Open
A tap on either door opens a confirmation dialog, and ultimately triggers the relay.
- type: horizontal-stack
cards:
- type: custom:button-card
entity: binary_sensor.garage_door_relay_sensor_state_door_1
show_name: false
state:
- value: 'off'
color: rgb(92,184,92)
icon: mdi:garage
- value: 'on'
color: rgb(255,193,7)
icon: mdi:garage-open
- value: unknown
color: rgb(217,83,79)
icon: mdi:garage-alert
styles:
card:
- animation: blink 2s ease infinite
- value: unavailable
styles:
card:
tap_action:
action: call-service
service: switch.toggle
entity_id: switch.garage_door_relay_1
confirmation:
text: Are you sure?
hold_action:
action: more-info
entity: binary_sensor.garage_door_relay_sensor_state_door_2
show_name: false
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
entity_id: switch.garage_door_relay_2
confirmation:
text: Are you sure?
hold_action:
action: more-info
Is this for 2 doors? I have 2 and would ideally like to have them both uniquely identified on the same card if possible. Would love to have some sort of status with the icon that can show if the door is in motion (opening/closing) if possible but not sure how that might be configured.
Basically the goal is to have a single card that lists both main and 3rd stall garage doors. The icon would change colors green for closed and red for open based on the sensor state. Clicking on the garage door icon would trigger the Zooz relay for the respective door and open or close it. Bonus points for the icon being able to show the door is opening or closing as well in some fashion.
Edited my original post to give you the code for two button cards nested in a horizontal stack.
Obviously, you’re going to have to change the entity names for both the button card state and the target of the service call. So change
to whatever you’ve named your ZSE43 entity
and
to whatever you’ve named your ZEN16’s relay(s)
Change the ‘on’ state color to something like rgb(217,83,79) if you want red for door open.
This should get you what you want, minus showing the door in motion which you might be able to do leveraging the tamper/shock entity the ZSE43 creates, but that always seemed like more trouble than it was worth when I was using the devices.
Thank you for this! When I paste this into the yaml editor with my sensors and relay entities it simply says configuration errors detected no type provided and won’t let me save. I’ve tried doing this starting with a Horizontal Stack Card from Add Card and also from Manual mode.
Code below. Please let me know what I might be missing. Thanks!
cards:
entity: binary_sensor.main_garage_sensor
show_name: false
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
entity_id: switch.main_garage_door
confirmation:
text: Are you sure?
hold_action:
action: more-info
entity: binary_sensor.3rd_stall_garage_door_sensor
show_name: false
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
color: rgb(217,193,7)
- value: unknown
styles:
card:
styles:
card:
tap_action:
entity_id: switch.3rd_stall_garage_door
confirmation:
text: Are you sure?
hold_action:
action: more-info
cards:
show_name: false
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
confirmation:
text: Are you sure?
hold_action:
action: more-info
show_name: false
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
confirmation:
text: Are you sure?
hold_action:
action: more-info
paste it like this
Its working!!! Greatly appreciate the help… Seems that I had a bit of a formatting issue however not exactly sure what it was but its working now.
Follow up question to tune this in a bit. How would I go about making the icons a bit smaller or similar look and feel to the standard HA mdi icon size and fonts?
Attached image of my old (myq) garage door card and the new one below. The up and down arrows aren’t so important to me but trying to keep things looking similar across the dash cards for now.
Add size: 3em
and adjust to your liking
cards:
show_name: false
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
confirmation:
text: Are you sure?
hold_action:
action: more-info
show_name: false
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
confirmation:
text: Are you sure?
hold_action:
action: more-info
Perfect! One more since we are on a roll here
How would I include the open/closed state below the door icon?
cards:
show_name: false
show_state: true
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
confirmation:
text: Are you sure?
hold_action:
action: more-info
show_name: false
show_state: true
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
confirmation:
text: Are you sure?
hold_action:
action: more-info
use show_state: true
Much appreciated. Is there a good place to validate/correct yaml inputs for HA?
I’ve tried a few yaml linters but never seem to get a perfect copy paste to work.
Not directly that I know of. I use Notepad+ for alignment on larger cards. The copy and paste can be an issue espicially with ‘tab’ spaced entries
I mean, what when you run home assistant instance, it have very powerful yaml validations, but when you post yaml in forum, where is no such validations. Maybe it will be possible to integrate some checks in website engine. Yes, it will take some calculation, but maybe in this case use power of running home assistant instances. To post yaml you should check it on it’s own local instance for example, and make this process integrated. So in feature, use code complete in this case, make home assist…
Copy! That did the trick. Can the font size be changed independently from the icon?
If I wanted the state “open/closed” to be a smaller font than “garage door”. I know I’m starting to get picky. Curious what the boundaries are here
Definitely can be different, Can you post what it looks like now?
cards:
show_name: null
show_state: true
name: Main Garage Door
state:
- value: 'off'
icon: mdi:garage-variant
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
confirmation:
text: Are you sure?
hold_action:
action: more-info
show_name: null
show_state: true
name: 3rd Stall Garage Door
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
confirmation:
text: Are you sure?
hold_action:
action: more-info
You can make your adjustments here. I added it to the bottom of each button card.
styles:
name:
- font-size: 15px
state:
- font-size: 10px
Full card code
cards:
show_name: true
show_state: true
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
confirmation:
text: Are you sure?
hold_action:
action: more-info
styles:
name:
- font-size: 15px
state:
- font-size: 10px
show_name: true
show_state: true
state:
- value: 'off'
icon: mdi:garage
- value: 'on'
- value: unknown
styles:
card:
styles:
card:
tap_action:
confirmation:
text: Are you sure?
hold_action:
action: more-info
styles:
name:
- font-size: 15px
state:
- font-size: 10px
Again for the win! Very much appreciate the help here.
Is there an easy place to soak up how to do all of this? Trying to not be the guy that constantly posts the easy questions. I’ve read a great deal of documentation and I come from an IT Engineering background. I want to learn the how and why as much as possible. The community here is nothing short of incredible.
I am curious how the basic entities card I was using with MyQ was able to show the door in an “opening” state briefly while transitioning from open to closed or vise versa. Outside of that, I think my garage door card is complete thanks to you all!
For button card the GitHub is very informative to understand it’s capabilities.
I always start with Github to understand HACs modules.
For card-mod start here. It’s an extensive guide.
MyQ had 4 states, Open, Closed, opening, closing. You are down to 2 with On and Off.
Another good link
Thank you so much! Glad I’m not the only one chomping away at this late on a weekend.
