mahk8
(Mahk8)
October 20, 2018, 2:21am
1
Since the latest 0.80.x versions, the history graph component takes a very long to display on my PCs (using chrome). It doesn’t even display on my macbook (using chrome). I think eventually times-out trying.
Just wondering if anyone else is seeing the same behaviour.
I am using the latest 0.80.3.
finity
October 20, 2018, 2:39am
2
I just tried it using Windows & Chrome browser on HA V0.80.1 and it locked up my whole frontend. I had to close it out & re-open to get it working again.
I think it’s definitely broken.
tom_l
October 21, 2018, 2:43am
3
None of my history graphs load since updating to 80.3.
Tried deleting the database. No change.
Mine seem to load albeit slowly…
nickrout
(Nick Rout)
October 21, 2018, 3:15am
5
I assume you mean 0.80.3 - if so this version fixes the history graphs.
tom_l
October 21, 2018, 3:27am
6
Yeah I just dropped the redundant 0.
And it is far from fixed.
Edit 2: Actually some are loading, incredibly slowly as noted above.
tom_l
October 21, 2018, 3:35am
8
There is nothing relevant in the logs.
fernandex00
(Fernando Tapia S)
October 23, 2018, 1:11am
9
It takes more time to load, since 0.8.3
tom_l
October 23, 2018, 3:07am
10
That’s an understatement. It takes for ever to load the simplest graphs. Some graphs with lots of sensors never load.
nickrout
(Nick Rout)
October 23, 2018, 3:47am
11
Yeah it is still definitely not right, even in 0.80.3. (I am surprised that someone is running 0.8.3, that must be ancient.)
it’s even worse in the 0.81.0b0
allan
(Allan)
October 23, 2018, 5:24am
13
Out of interest, what DB are you all running? I’m just getting ready to upgrade from 0.80.1 to 0.80.3 I use the MariaDB addon as it made things faster in the past. Just wondering if this is impacting all DB types or just a subset.
nickrout
(Nick Rout)
October 23, 2018, 5:26am
14
I am running the default sqlite database.
wojked
(Wojked)
October 23, 2018, 6:20am
15
I confirm I have similar issues- history graph loads „sometimes” since the 0.80->0.80.3 update.
Cannot find anything Interesting in logs.
Using MariaDB on external host, dropping DB did not help.
Tried also the local SQLite with a new file, same negative result.
Downgrading to 0.80.1 helped.
wojked
(Wojked)
October 23, 2018, 6:22am
16
I upgraded to 0.80.3 yesterday, advising to postpone your update.
(Used SQLite then switched to MariaDB to get the charts queries)
baz123
(Brian)
October 23, 2018, 8:10am
17
For me the issue also remained in 0.80.3. Rolling back to 0.80.1 solved the issue for me so far…
tom_l
October 28, 2018, 1:58am
19
Has this been fixed in 0.81.0?
nickrout
(Nick Rout)
October 28, 2018, 2:02am
20
Yes. (Well I hope I haven’t spoken to soon!)
