This is a generalized version of iOS Dark Mode Theme (this topic)!
This includes both Dark and Light Mode and 7 different HomeKit backgrounds.
Installing this theme adds 28 different themes:
to answer @vulcanjedi, I installed without HACS, just put the yaml file in the theme folder, then download all the images to your “www” folder, I matched the folder structure. Then you have to edit the yaml to replace “hacsfiles” with “local”
That would be my first request, can you auto generate one for non HACS as well so when we get updates we don’t have to do find/replace?
Also, not sure if you have many using this on an Android, but one thing is the header on the Android Companion App your background header does not work. You have…
With Android that has to be a HEX value, not an rgb or rgba value. This is to set the color at the top of the Android device when the app is open, the part that has time, open apps, signal, battery, etc…
So I guess could you also pick a color per theme and generate an android version as well that has a HEX value for that setting so it works on Android mobile?
Otherwise the weirdness I see is from custom-header which I posted over there, seems to have issues sometimes with multiple dashboards and background images, only on mobile
Another random request you can take or leave, but since you are auto generating, could you not also make a folder with each individual theme in it’s own folder? that way if someone really only liked one dark/light they could just place those in their theme folder so when someone goes to their profile to switch, or uses dropdowns like you suggested, it’s not so many options?
I have an issue, only with the light versions of the theme. When I chamge page or i open a popup of some card, the background become grey for a while. After that It return back to the theme background.
