Latest Supervisor wont start
Can the HA team point to the exact debian 11 arm distro download they support along with the accepted arm hardware platforms?
Based on the comment I don’t believe there is any straight arm based Debian 11 that will run HA. In this thread it’s pointed out that you need to modify kernel parameters changing cgroup v2 (The default) to cgroup v1 in order for HA to work on any install of Debian 11. Thus a change is required. I run what I view as straight debian, as no debian packages are modified to make it work, on the odroid N2+. It does required a kernel build and kernel parameter configuration. In addition I have to set the interrupts for mmc, usb and eth0 to insure the interrupts for each of these hardware components are handled on one processor. This is inline with what Debian 11 would call a Debian 11 install. While armbian does a few more hardware specific modifications they utilize the standard Debian arm packages.
The best platform for a standalone HA controller install is the odroid N2+. I know a lot of people run on the raspberry Pi 4, but it’s under powered compared to the odroid N2+.
I previously posted these instruction for loading what I view to be a valid debian 11 build for the odroid N2+. Supervisor also reports it as supported. With a couple of configuration tweaks you can also build a raspberry Pi4 based system.
I would really love it if the HA team point to the exact debian 11 arm distro download they support along with the accepted arm hardware platforms?
Thanks for all the great work.
