Lightweight IOS version (for IOS 9.3.5
@nagubal thank you for posting. Waiting for something like that for a long time
Already charging :wink: my old iPad :smile:
Greez from vienna
@nagubal works better but not perfect - button card installed via HACS is not showing on the iPad 3 and saying Custom element doesn’t exist :frowning:
At least its connect which is a great start.
I have the same problem, my custom cards doesn’t show up, I hope it will be fixed soon.
Same here, seems lik a lot of custom scripts are not loaded.
Kiosk Mode also does not work on my old device
:white_check_mark: :white_check_mark: :white_check_mark:
Hello, I have found a solution for this problem.
I have an iPhone 4S with IOS 9.3.6.
To reinstall it you need to get a device compatible with the current update and download on this device (iphone / ipad under ios 13 at least). You must invite in your family the non compatible device in question.
All you have to do is go to your old device in the family section and find the home assistant app and download it.
I hope it will work even for future updates.
French greetings. :smiley: :smiley: :smiley:
nagubal
nila
Burningstone
themitchell
rswennen
craciunbogdan.m
David.a
Elisa9180
TensE
kenm
thoughton
crboffo
JZhass
mr_white
friendodevil
MatyasK
Romkabouter
That is a great idea, I will try it!
it work for me
I can indeed download a Home Assistant app on the old iPad.
Great workaround, however custom cards do not work
Same with me for custom cards. So glad it’s back and working to some level.
How can I default HA home page on a specific device ? I’m going to need to create a page with no custom cards :confused:
Also,
  • some entities just don’t display, do people have this on a standard entity card?
  • some badges aren’t displaying, i tried reordering but same as entity card… only some work
Mine won’t login. iPad 2 with 9.3.5, tells me wrong username/password every time when I can login just fine on my phone. Anybody has this working for them?
Hi, I downloaded Home Assistant app to my parents Ipad 2 like in you’r post - but the app keeps crashing when I try to open it. Anybody alse with this problem?
I have the same it always says that I typed the wrong password.
Any solution to use HA in IOS 9.3.5?
I use Chrome-VNC:
https://community.home-assistant.io/t/wall-mount-with-ipad-2/223520/14?u=dominikw
Same here. I was able to install it through the family sharing, but now it’s always saying there is an error with the password. Did you find a solution?
I just found one
give auth on config for ipad ip
homeassistant:
  auth_providers:
    - type: trusted_networks
      trusted_networks:
        - 192.168.x.xxx
        - ::1
      allow_bypass_login: true
    - type: homeassistant
Works for me!
I set this up exactly like this, but it seems not to work for me and it works for me (had a configuration error). While reading the explanation in the on-line help here: Authentication providers - Home Assistant
I see that this only works if your setup meets this requirement:
Assuming you have only the owner created though onboarding process, no other users ever created.
I have several users created in Home Assistant, so this will never work for me.
An alternative would be this, but I have not got this working yet, which now works for me:
Hey, can you explain it how did you do?
I’m trying to do the same and I’m lost
