is this script still relevant with the latest Hassbian images? I think they re-did some of the scripts in the newer versions.
Anyone can confirm this works in HA 0.45.1 as it is using PyPi python based openzawe and not c++ OPENZAWE?
Mine still works after upgrading to 0.45.1
Nice, thanks for the reply.
I should have asked clearly earlier that anyone who can confirm that it was NOT working earlier and now started working in 0.45.1 without patching openzwave and compiling openzwave?
Unless I did something wrong, I’m still not seeing my garage door in HASS after I upgraded to 0.45.0.
This post indicates it’s not working.
I just gave it a shot and it didnt work.
Removed Linear Garage Door Opener from Smart Things
Factory reset device
Secure add via OZWCPL
Copy config to HASS folder
Add z wave cover platform to config
Restart
Just had the sensors and z wave node present. No Cover device.
Moving it back to Smart Things now.
This is my last device I need to migrate too. Not interesting in hacking together config files every time I upgrade so Ill just leave it for now until its confirmed to work in stable/stock versions.
Thanks all for confirming this. So I will leave mine to Wink hub 2 for now until HA supports it. I was hoping that latest HA update will do the magic. As @gregg098 mentioned, for me also this is last zwave device I have on Wink and getting tired of Wink issues so wanted to bring to aeon zstick.
After I refreshed the UI my ZWave cover control for the door is gone.
Need a little help here. I got mine to work in OZWCP, I can open and close and sensor is working correctly, but after adding zwave and cover in configuration.yaml, I don’t get any cover control. No matter what I do, it just won’t show up in HA. Is there any changes I need to make in HA? I’m running the latest version 0.46.1.
You probably saw this already but just in case. HASS uses its own OpenZwave files now from PyPi. It might be that your install is using those files and OZWCP is looking at your patched version. Do you have a “config_path” under your zwave entry inside of configuration.yaml? Make sure its pointing to the patched configuration directory.
On a side note, are you using Hassbian? I have been unsuccessful in trying to patch it to work with the Linear garage door opener (although I admit I haven’t tried very hard and just let it run on SmartThings). If you’re on Hassbian can you share your steps for this? Instructions in this thread and others are very old.
Thanks.
thanks for your reply. I do have a config_path in my configuration.yaml which is pointing to “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/libopenzwave-0.3.3-py3.4-linux-armv7l.egg/config” and that’s where my patched version is installed. After reading this thread, my understanding is that as long as I have it working under OZWCP, all I have to do is add proper settings in configuration.yaml for zwave and cover and the control should show up in HA. I don’t know what I’ve overlooked.
Sorry to say, I’m not using hassbian, I’ve tried, but with hassbian, I ended up with other issues when trying to compile python-openzwave/OZWCP, so I am running Jessie and AIO, this way, I could at least patch and compile python-openzwave/OZWCP.
I’m still curious in how you did this. Maybe I can figure it out on Hassbian. Just reluctant to try the steps in the really old threads in case the branches they reference are too out of date.
Thanks.
I was able to get this working again with the following modifications to the script:
#!/bin/bash
echo
echo "Open Z-Wave Installer for Hassbian"
echo "Modified by Landrash for use with Hassbian."
echo "Remodified by unt1tled for use with Linear NGDZ00-4 (barrier_operator)."
echo "Copyright(c) 2016 Dale Higgs <https://gitter.im/dale3h>"
echo
if [ "$(id -u)" != "0" ]; then
echo "This script must be run with sudo. Use \"sudo ${0} ${*}\"" 1>&2
exit 1
fi
echo "Running apt-get preparation"
apt-get update
apt-get upgrade -y
apt-get install -y make python3-dev libudev-dev python3-sphinx python3-setuptools libgnutlsxx28 libgnutls28-dev libssl-dev
echo "Changing to homeassistant user"
sudo -u homeassistant -H /bin/bash <<EOF
echo "Activating virtualenv"
source /srv/homeassistant/homeassistant_venv/bin/activate
echo "Installing latest version of cython"
### Currently locked to this version since build fails for later versions.
pip3 install --upgrade cython==0.24.1
echo "Creating source directory"
mkdir -p /srv/homeassistant/src
chown -R homeassistant:homeassistant /srv/homeassistant/src
echo "Cloning python-openzwave"
cd /srv/homeassistant/src
git clone https://github.com/OpenZWave/python-openzwave.git
chown homeassistant:homeassistant python-openzwave
cd python-openzwave
echo "Cloning openzwave"
git checkout python3
rm -rf openzwave
git clone git://github.com/OpenZWave/open-zwave.git openzwave
cd openzwave
echo "Changing to openzwave Dev branch to add barrier_operator support"
git checkout Dev
cd ..
echo "Building python-openzwave with barrier_operator support\nStage 1..."
make build
make install
# Remove the 1.4 non-dev branched compile and replace with the 1.5 dev branch compiled version
rm -Rf openzwave-git/open-zwave-master/
cp -R openzwave/ openzwave-git/
mv openzwave-git/openzwave/ openzwave-git/open-zwave-master/
echo "Building stage 2..."
make install
echo "Deactivating virtualenv"
deactivate
EOF
echo "Creating libmicrohttpd directory"
mkdir libmicrohttpd
chown homeassistant:homeassistant libmicrohttpd
cd /srv/homeassistant/src/libmicrohttpd
echo "Downloading libmicrohttpd-0.9.19"
wget ftp://ftp.gnu.org/gnu/libmicrohttpd/libmicrohttpd-0.9.19.tar.gz
chown homeassistant:homeassistant libmicrohttpd-0.9.19.tar.gz
tar zxvf libmicrohttpd-0.9.19.tar.gz
echo "Building libmicrohttpd-0.9.19"
cd libmicrohttpd-0.9.19
./configure
make
make install
echo "Cloning open-zwave-control-panel"
git clone https://github.com/OpenZWave/open-zwave-control-panel.git
chown -R homeassistant:homeassistant open-zwave-control-panel
cd open-zwave-control-panel
echo "Replacing open-zwave-control-panel source files with barrier_operator support"
#wget -O zwavelib.cpp https://raw.githubusercontent.com/legrego/open-zwave-control-panel/0925251a566a36543e0c6b5cb0b2c1498bddfa68/zwavelib.cpp
echo "Building open-zwave-control-panel"
rm Makefile
wget https://raw.githubusercontent.com/home-assistant/fabric-home-assistant/master/Makefile
chown homeassistant:homeassistant Makefile
make
echo "Linking ozwcp config directory"
ln -sd /srv/homeassistant/lib/python3.*/site-packages/libopenzwave-0.*-linux*.egg/config
echo "Linking Home Assistant OpenZWave config directory"
cd /home/homeassistant/.homeassistant
sudo -u homeassistant ln -sd /srv/homeassistant/lib/python3.*/site-packages/libopenzwave-*-linux*.egg/config
chown -R homeassistant:homeassistant /home/homeassistant/.homeassistant
echo
echo "Installation done!"
echo
echo "If you have issues with this script, please contact @Landrash on gitter.im"
echo "Original script by @dale3h on gitter.im"
echo
Modifications to __init__.py need to be done in /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave
I made mine like this:
#REQUIREMENTS = ['pydispatcher==2.0.5', 'python_openzwave==0.4.0.31']
REQUIREMENTS = ['pydispatcher==2.0.5']
Make sure to clear `/home/homeassistant/.homeassistant/deps/` or just nuke the python_openzwave in there, either works.
Thanks. Going to give it a shot.
I am able to see the proper cover in HA now but openzwave changed the way it handles the door status:
<CommandClass id="102" name="COMMAND_CLASS_BARRIER_OPERATOR" version="1" issecured="true">
<Instance index="1" />
<Value type="list" genre="user" instance="1" index="1" label="Barrier State Label" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="$
<Item label="Closed" value="0" />
<Item label="Closing" value="1" />
<Item label="Stopped" value="2" />
<Item label="Opening" value="3" />
<Item label="Opened" value="4" />
<Item label="Unknown" value="5" />
</Value>
This causes it not to work in HA and this is as far as I’ve be able to get so far.
Out of curiosity, since 0.46 and above are using their own OpenZwave files, is it possible to just replace a few config files to make this work?
I’m not sure, I used information from this thread as well:
I actually just updated/added the files (4 in total) following Josh’s post and compiled/installed OZW again. I’m still haven’t issues with HA not showing the cover control, but everything is working like it should under OZWCP.
Does your OZW_Log.txt say Openzwave 1.4xxxxxxxxxx or 1.5xxxxxx ?
